Question about Rl Flowmaster Garden
I have an RI Proflo Model 014.3L, which like the previous one will not pick up liquid from the tank. Instead of having to push down to pressurize no force is required down but there is some resistance when the lever is pulled up and no pressure occurs in the tank/spray nozzle. I took the previous one apart and could find nothing wrong but needed something right away (kudzu was/is getting ahead of me) so I bought another one and figured on fixing the previous one later after growing season. Now I have two broken sprayers, one virtually new and one only a season or so old. Any suggestions as to how I could fix this thing? Robert Branch Walls, MS
  • rebranch Aug 26, 2010
    It is not a clogged nozzle but something in the pump. This is a back pack sprayer, nominal 2 gallons. Do you know where I can find a manual that would have trouble shooting instructions and a description/layout of the pump mechanism? That is where the problem is, perhaps a seal but, if so, how do I change it? It is not old enough for the seal to have deteriorated so it may have slipped out of place or something, hard to tell from looking at it. Nothing appears to be out of place or missing.
    REB
  • rebranch Aug 27, 2010
    Thanks, glad to know what they call these things but everything on this site appears to apply to a different model than the one I have. Mine is a 4 gallon or so backpack sprayer and the only model number on it is 014L. Looking at it again it just could not be 19 something which appears to be the model on all these sites. On the Home Depot site there is a picture of it but no model number on or near the picture. The problem is definitely in the pump, probably a seal but I do not see how to get to it for replacement. It is virtually new so doubt the seal could be deteriorated but it may have slipped out of position or something. Do you know if the FloMaster manufacturer has a web site or where I could find a manyal or instructions on how to get at and replace a seal? I have another one that possibly had the same problem. Also do you know if the "kit" has anything other than the seal in it? I looked at several of these sites, thru about page four, and none lest exactly what is in the kit and none mention an instruction sheet it the kit. Do you know if there is such a sheet in the kit? At lease you have provided some usuful information. The first "expert" was totally useless.
    Robert Branch
  • 3,083 Answers
It's probably either a clogged nozzle or a bad gasket/o-ring. Here is a web page that talks about some things that go wrong and fixes:
http://www.epinions.com/review/Flo_Master_3_Gallon_Polyethylene_Sprayer_with_Buna_Seals_Incl_Extension_Wand_And_Nozzle_Ea/content_458124594820
Maybe it will be a simple fix, sure hope so.
Posted on Aug 26, 2010
Uneven burner
I apologize I've not logged in for some time and do not know what "everyone else" has had issues with.
I can tell you as a grill repair company we get 4-5 calls every week from clients complaining of poor flames, poor heat. The problem has a very simple solution and the problem is not the burners or other parts and (almost never) the regulator.
There are 3 safety features in an LP cylinder. One is a check valve that gauges pressure leaving the tank. This is a swing-arm pressed up by escaping LP. When the gas fills the manifold and gas line (because the BBQ valves all Must Be Off when the cylinder is turned on) the pressure pushes this swing-arm back into position.
The problem usually occurs with newly filled tanks because with the tank full and the OPD float displacing liquid pressure the gas "hits" the check valve swing-arm too hard so instead of registering the pressure leaving the tank the swing-arm is pressed too far and the back-pressure does not reseat it correctly.
The mechanics of the tank are designed to read higher pressure leaving and lower pressure returning as a leak and shuts-down. We still get some flow because of the OPD pushing but the tank will not allow gas flow at the necessary BTU's.
Reset: Turn off everything on the BBQ and the LP cylinder. Disconnect the cylinder and turn the BBQ valves all to "high".
Wait 5 minutes.
Turn everything off again -- and be sure every valve is completely off so no pressure is released.
Reattach the LP cylinder to the regulator and turn the tank on -- very, vert slow for the first full rotation so the gas pressure leaks through slow and cannot "hit" the check valve too hard.
Once the cylinder os all the way on light the BBQ and it will be fine.
Please let us know how it goes.
If I had one dollar for every time someone contacted us to buy burners, regulator, etc only to fix their BBQ while on the telephone with us ... I would retire!
Feb 09, 2014 | Jenn-Air Grilling
Aqua Pro RV Water System siphon kit, #27910 - i followed the instructions and installed the kit, valve right way, arrow pointing the right way. It does not suck the antifreeze out, it blows air or liquid...
The valve should be closed while siphoning from the antifreeze. This allows the RV pump to draw it from the jug instead of the holding tank.
You can not use city water or other pressure to move it.
If all else fails and you are using RV antifreeze imply place the antifreeze in the holding tank. turn the valve open and use the faucets normally until you get liquid out of them.
Come summer you can simply add 1/4 cup of non-phosphours bleach to every 5 gallons of water to clean and purify tour lines and tank again.
Oct 19, 2013 | AquaPRO AQUA PRO 27910 - Aqua Pro Siphon...
1992 geo ran out of gas
Sometimes the pump will overheat when the gas tank is low, and sometimes the sock filter in the tank will pick up junk from the bottom of the tank.
Fuel pumps are designed to run in liquid gasoline to keep them cool and lubed.
You may want to replace the inline filter and check fuel pressure.
Jul 18, 2013 | Cars & Trucks
My Bissel is putting liquid into the carpet but not sucking it out
I have found a website that says
Repair a cleaner that is not picking up solution. Ensure the nozzle attaches properly. Press down firmly on the gasket to verify that it is positioned correctly. Make sure the tank lid is installed the right way. If it is not, remove it and reinstall. Verify that the hand tools are positioned properly when in use. Change the angle of the attachment and apply downward pressure. Check the water level of the tank-in-tank. Empty and replace if necessary.
the website was ehow.com
hope this helps
Mar 02, 2011 | Bissell ProHeat Turbo Deep Cleaner Upright...
The cyan isn'r printing. I cleaned and changed the cartridge. If clogged is there a way for me to unclog the nozzle?
Use a syringe filled with a liquid head cleaner. Add tip syringe with flexible hose (like the hose on the outlet head cleaning mechanic). Remove the ink tanks. Hose into the nozzle.Give the pressure slowly until the liquid head cleaner in the syringe out. Make sure no liquid is spilled in the vicinity of the nozzle. Replace the ink tanks, nozzle check and head cleaning. Is there a change from the nozzle check from the previous?
Sep 29, 2010 | Epson Artisan 700 InkJet Printer
Truck wont run as there is no fuel pressure at the rail. When I turn on the front fuel pump it appears to fill the back tank and come out the filler tube. I turn on the back fuel pump and it does the same,...
the switching valve has gone bad forgot exactly what ford called it but it might be tank isolater what is does is block which ever tank that is not in use to prevent what is happening to you the valve is stuck in neutral position causing no restriction liquid follows path of least resistance cut front tank on pump pushes fuel out gets to valve and instead of going to engine and building pressure it just runs over in the rear tank path of least resistance this valve should be frame mounted some where between tanks have seen on rear crossmember to
Aug 05, 2010 | 1992 Ford F250
My refilled 60 # propane tank leaked and then stopped flowing.
Rick, if the tank is normally plumbed for a horizontal position, and you have it standing vertically, then you are feeding liquid propane to your pilot light, hence the frosted hose etc., and a tendency for the pilot light to go out as it has too rich of a fuel to burn. There should be no vent to allow air in as propane is pressurized, and only attains zero pressure at 40 below zero farenheit. The valve you speak of should have been the liquid vent valve which is used during filling only, and is closed during any other use. Your supply valve should be in the wide open position. The pressure relief valve is only operational when the tank has been overfilled or overheated. You should have a pressure regulator between the tank and the appliance you are trying operate. Hope this helped. Marvin
Jan 04, 2010 | Bosch AquaStar 125FXKIT-LP 125FX Liquid...
Echo model 650evl. fuel dumps through carb
Make sure the fuel tank air vent is open. If this has a Walbro brand carburetor, open the lower cover (4-screws) and check that the fulcrum lever in the body is engaged with the fuel check-valve-needle end, and also that there is a tiny spring under the fulcrum bump. Push down on the fulcrum and observe that it picks the needle up and pushes it back when pressure is released. Check the diaphragm for pliability and that it is installed next to the carburetor body with the pin side in, the thick gasket next, finally the cover. Good luck!
Aug 31, 2009 | Garden
Electric Air compressor
check the valves. They could be breathing in and out and not sealling.
Oct 30, 2008 | Air Tools & Compressors
Garden Logo
151 people viewed this question
Top Rl Flowmaster Garden Experts
andy just round the...
Level 1 Expert
Nick Olsen
Are you a Rl Flowmaster Garden Expert? Answer questions, earn points and help others
