Question about Refrigerators
My fridge stinks while running And exhaut is sooting up real bad Any ideas ? Thanks Jon
    President:
  • 3,773 Answers
<P>There are many reasons for smell. </P><P>But one sooty problem is the defrost heater may have burned out</P><P>Remove the inside back panel in the freezer and look for a black burnout</P><P>of the defrost heater.(around the bottom half of the coils. It looks like a stove bake element or its a glass heater</P><P>Replace the heater if it doesn't ohm out or if it is burned</P><P>&nbsp;</P><P>&nbsp;</P><P>If this was helpful please rate me.<BR>Leo Ponder Appliance-Tyler,Texas<BR><A rel='nofollow' href="mailto:imufo2@sbcglobal.net">imufo2@sbcglobal.net</A> </P>
Posted on Aug 26, 2010
2001 KIA Sportage shows a P0650 MIL Ind Lamp malfunction (control circuit) is the PCM bad? light does not come on ever.or is there some test to try ? I would appreciate any and all ideas. thanks
IS it 2000cc 2 liter engine?
Chek for intake manifold gasket leak, hissing sound put engine o?l and check for blue smoke at exhaut, also check at injector o ring with oil
Dec 06, 2014 | 2001 Kia Sportage
Fridge freezer exposed to fire smoke and not cooling down
Sounds like you may possibly have caused some damage when you cleaned it up - can you talk us through exactly what you did to it and how badly it needed "cleaning" - was it caked in soot etc. How hot do you think it got during the fire? if it got much above 60 celcius for any length of time what can happen is that the refrigerant gas boils enough that it will overwhelm all the seals. only real way to check is get a fridge repair guy to test it for leaks and refrigerant content, be careful not to run it too much in case this is the problem - can be fixed but running it won't do it any favours. Hope this helps, please post back with a bit more detail and hopefully we will have more of an idea what the problem could be :)
Jun 26, 2007 | LG LRBC22544 Bottom Freezer Refrigerator
Misfire going up hill at hgihway speeds in passing gear.
Hi Jon Jon, Did you also replace the spark plug? Changing all would be a good idea. Regards John
Sep 08, 2012 | Chevrolet S 10 Cars & Trucks
Is it allright to burn part deisel with kerosine in a Toyo laser ignited heating stove?
Only if you want to stink up the house (more than just what the kerosene does) and don't mind dealing with a little soot on the walls and ceiling.
I wouldn't. But the choice is yours to make.
hope this helped you in some way. Please let me know. Thanks.
Jun 09, 2011 | Rinnai Toyostove Direct Vent Heater:...
I have a dynaglo RMC 95-ca and it stinks.How should I clean it and what is the proper wick height. I do not have manual. Thanks for your help.
Stinks? Are you using old Kerosene? Have you replaced the wick recently? Is there soot on the inside or around the top of the heater? If you answered 'Yes' to the first question, then you know what the the solution is. If the unit has soot on or around it, then the problem is with the wick. It may need to be replaced or if it's fairly new, just trimming the top with a pair of scissors may be enough. As the wick height is concerned, it depends on how much heat you're looking for. Generally, the wick height shouldn't exceed 1/2" from the top of the adjustment mantle. Of course, it can be turned down some, once the area heats to the desired comfort level. The final question about the odor or it's cause. Have you painted, stained or cleaned your carpeting recently.? If you have, the heater is picking up the residual odors from those things and making it 50 times worse.
Hope this all helped solve your problem. Please let me know.
Mar 11, 2011 | Heating & Cooling
GE GSS25QGTA Side by side fridge not cooling, no digital display, no ice or water dispensing, lights in freezer abd fridge work. Any ideas?
did you plug the fridge in and connect and turn the water pipes leading from the fridge to an outlet and water outlet, if you didn't you should
Dec 02, 2009 | Dryers
My new Whirlpool Refrigerator the water and ice still stink
Change the supply line to the plastic tube line or copper. Do not use a braided plastic or metal braided line these will make the water taste bad. Changed mine to the plastic line and cured mine, no filters needed.
Dec 19, 2008 | Whirlpool 25.6 cu. ft. Side-by-Side...
Dryer body very hot, loud squeking, soot from ball in back
I would replace the high limit control and the thermostat to be on the safe side. There is a real danger of burning the house down.
Nov 25, 2008 | Kenmore 62602 Electric Dryer
Howling Refrigerator
I am having the same problem with my GE 2005 refrigerator. Anyone find a solution yet?
Apr 17, 2008 | Refrigerators
Not cooling after smoke damage
Assuming that the motor is running, my best guess would be that the condenser (a large grid of thin piping) was covered in soot, and should be THOUROUGHLY cleaned, preferably with compressed air.... The condenser will either be underneath the unit, behind a small panel in the front bottom of the unit, or at the back behind a cover at the bottom of the fridge which runs the whoile width. Make sure the fan at the back near the compressor is also running....if the condenser fan is not running when the compressor is running, it won't cool. If the condenser is excessively dirty, it won't cool!
Jun 26, 2007 | Frigidaire PLHS269ZC Side by Side...
Refrigerators Logo
47 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
Brian Coughlan
