Question about Xerox WorkCentre Pro 412 All-In-One Laser Printer
I was faxing with my workcentre when too many pages got jammed up in the fax feeder. I could not pull them out and the feeder continued to just run and run so I unplugged the machine pulled out the paper cleared the jam and plugged the machine back in and nothing happened no power what happened to my workcentre, is there a fuse or swith or something I need do look for?
  • 1,110 Answers
Did you pull the power cord from the wall outlet or the back of the copier? I have seen the removable cords come loose from the back of the copier so check that. There are fuses on the power supply that could have blown so those can be checked as well. Power failures such as you initiated can always blow a power supply as the machine is drawing current while running and when the power to the supply gets cut off it can cause a very short term high current draw on the power supply causing components to fail. Next time something like this happens just use the on/off switch to eliminate power supply damage.
Good Luck and Thank You for using Fixya.
Posted on Aug 26, 2010
Xerox WorkCentre 7120 error code
Chain Description 001 Cover and Door Interlocks 002 Touch Screen / Control Panel 003, 041, 045, 123 Machine Communications 004 Drives 005 Duplex Automatic Document Feeder (DADF) 061, 062 Scanner, DADF and ROS 007 Paper Supply 008 Paper Feed 009, 089 Xerographics 010, 011 Fuser, Copy Exit 012, 013, 047, 112 Finisher 016, 124, 127 Configuration, Software, Memory, Hard Drives, Color Server, DFE 018 Network Communications 020 Fax, Software 021, 121 Foreign Interface 022 Job Timers 024, 026, 027, 033 Job Parameters 034, 035, 036, 133, 134 Fax Communication 042 Motor, Fan, Sensor 071 Tray 1 Misfeed 072 Tray 2 Misfeed 073 Tray 3 Misfeed 074 Tray 4 Misfeed 075 Tray 5 Misfeed (Bypass Tray) 077 Paper Path Jam 078 High Capacity Feeder 083, 084 Fax Jobs 091 Drum Cartridge 092, 093 ATC, ADC, Toner 094 IBT, BTR 102 Job Queue 103, 116 Software
Aug 23, 2014 | Xerox Office Equipment & Supplies
Document feeder jam
Try cleaning the rollers with a bit of rubbing alcohol/water solution, equal parts. There should be a pair of them, one on each side of where the paper is fed.
Feb 24, 2012 | Office Equipment & Supplies
Paper jams
Paper jams - Kodak Printers
Feb 19, 2011 | Kodak Office Equipment & Supplies
Up to two pages can be force fed through before the machine stops taking the pages and a paper jam error report is generated.
Inside the document feeder are two small levers near the middle of the paper path. One will be near the first roller to tell the machine that there's a sheet waiting to be pulled. The other will be an inch or two farther in, to tell it the paper has reached the scanner glass. If one of those levers is sticky, the machine will "think" it's feeding a very long continuous sheet. After a couple of feet or so, it reaches its programed limit and gives up to prevent tying up the phone line on an endless fax call when the document is jammed.
Open the feeder, find those levers, and make sure they move at the slightest touch. If one won't pop back up every time, it will give the symptoms you described. It may be as simple as a tiny scrap of paper wrapped over it, jamming it in its slot.
If the levers move freely, you may have a bad optical sensor underneath.
Oct 22, 2010 | Panasonic KX-FL511 Plain Paper Laser Fax
My fax is having a problem feeding pages through the document feeder, it doesn't always grad the page, and if it doesn't get it, it acts like it has a paper jam, what is causing this?
Open the document feeder. Inside you will find a grey feed roller. Cleaning this roller with a cloth dampened with water will help with these paper jams in the document feeder.
Sep 29, 2010 | Brother IntelliFAX 4750 Plain Paper Laser...
Xerox WorkCentre 4150, 3 vertical white lines in all feeder scans
the problem is in the scanner, open it up and see if you can find any smudges, and clean any obstruction, any ink, liquid eraser residuals, can cause this part to appear as lines on your copied faxed image.
dont concentrate on the printer this is a scanner problem
Jul 28, 2009 | Xerox WorkCentre 4150/X Laser Printer
Blocked Feeder
unplug machine and remove catch bin and reach under and pull jammed paper from the bottom and the top ..Good Luck
May 02, 2009 | Office Equipment & Supplies
Officejet 7310
Sounds like there is something going on with the paper sensor flag that resides in the top cover of the automatic document feeder. Need to make sure it is moving freely. It is spring loaded so it should move freely and spring back in to place. Sounds like your may be sticking in the up position after a few sheets. When the ADF lid is down these sensor flags should go in to holes in the bottom of the ADF. Hope this helps..
Inkworks
May 19, 2008 | HP OfficeJet 7310 All-In-One InkJet...
Document jam
There is most likely a very small piece of paper in the document feeder.
What you can do is take a minella folder or some card stock, open the document feeder cover and shove the folder or card stock through the feeder to dislodge whatever is stuck in there.
The document sensor itself may be knocked out of position.
It can't be the copy paper path since you can print.
May 16, 2008 | Xerox WorkCentre PE120 All-In-One Laser...
Scanning / faxing problem
you will need to replace the adf assembly or the portion of adf roller which was dameged.
typically one should open th ecover and take out the jam inth direction of papermovement only
happy faxing
omnipresent
Oct 17, 2007 | Samsung SCX-4216F All-In-One Laser Printer
Xerox WorkCentre Pro 412 All-In-One Laser Printer Logo
Top Xerox Office Equipment & Supplies Experts
Xeroxrep
Level 1 Expert
Philip Hughes
CheckitRight
CheckitRight
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
