Question about Kitchen Ranges
Have a 5 hp 230 v emerson definite purpose air compressor motor ,model t63bxbpn1040 mfg no.g301b frame 56 type t,3450 rpm .i want to make sure taps are correct before wiring since there is no wiring diagram,splices are #1with red and orange,2nd splice is #4 and 5 and blue off of reset button
jsrock516
  • 5911 Answers
SOURCE: oven bake element
If you're talking about the wires attached to the BAKE element, normally RED is on the RIGHT and YELLOW is on the LEFT, but it really doesn't matter. Theoretically, this is a resistive heating coil and it will work with the wires connected in either direction. Normally, its fairly easy to determine how these wires reconnect, because the lengths are normally only sufficient enough to connect them one way.
The RED wire connects from the BAKE element to the terminal block, to one side of the BROIL element. The YELLOW wire is connected to one end of the BAKE element and runs to the electronic oven control (EOC) board.
I hope this clarifies this for you.
Posted on Aug 23, 2008
SOURCE: motor for my vulcan convection range was
Red wires are usually the in and out for the centrifugal switch. the black wire that goes to the panel inside the motor is likely the 120 connection, the panel is the start switch for the start winding of the motor. This black wire should be connected to the 120 (from inside oven) and one of the red wires (three wires together). The other black wire of the motor should be connected to nuetral (you will have to determine which of the wires you have left coming from the oven is nuetral) the other red wire should be connected to the wire that feeds back into the oven for gas valve/thermostat controls (you may be able to trace this wire by hand to see if it goes to thermostat and gas valves). Hope this helps.
Posted on May 03, 2009
Maytag317
  • 1136 Answers
SOURCE: Broiler element needs to be replaced
Hi, UNPLUG or turn off the breaker. Remove the screws that hold the element in place. Hopefully there is enough wire that you can pull it out far enough. There are screws that hold the wire to the element. Just remove the screws and put the new element in place.
I hope this has helped you. Please let me know if I can assist you further.
Thanks
Vic
Posted on May 23, 2009
  • 41 Answers
SOURCE: fan motor replacement
with the model number the supplier shoud be able to tell you what you need but some sell universal variable speed motors with long shafts so trim to fit might come in to play
Posted on Nov 21, 2009
ftw1952
  • 10319 Answers
SOURCE: Model MES5770AAB Serial 11517659WK The single
Ten to one the elements will have to be changed also. Call or email Maytag about your dilema. You can simply reject to pay me also on this one
Posted on Jan 24, 2010
Won't start
power 120 volt cannot to supply to 230 volt, maximum correction factor for voltage is 15%
Apr 04, 2014 | AO Smith 5 HP 3450rpm R56Y Frame 208-230...
Someone cut the plug from a 230V Craftsman Compressor and wired on a 120V plug and plugged it in. What type of damage could have occured?
You should be okay. It just ran at half speed while it was on. If had been the other way around (hooking up 120v motor to 240v socket) that would have killed the motor.
Jan 30, 2013 | Pool & Spa
Century single phase 2 hp 3450 rpm type cs motor Frame f56
the motor is on 220 volts ,i like hook that up on 120 volts ,,thanks
May 10, 2012 | Air Tools & Compressors
Can you put a bigger Hp and a smalll plully onit
There are quite a few variations of motor and pulley combinations. You can change the motor and pulley based on your needs, however do not over-clock the recommended rpm or the pump. Check the specifications of the pump to determine the max rpm . Usually the pulley on the motor will depend on the rpm of the motor. Check the rpm of the present motor to determing the rpm of the pump with current set-up, and compare to the motor you are considering. Motor rpm vary from around 850 to 3450 so pulley size is quite important. Good holidays
Dec 18, 2010 | Ingersoll Rand Type 30 Reciprocating Air...
Need to know how to put the wires in the right order on a AO Smith 5.0 56 spa pump red white and black
Red and Black should each be connected to the individual power legs, for 230 V operation. The white wire should be connected to ground.
Nov 25, 2010 | AO Smith 2 Hp Spl 3450rpm M56 Frame...
Fan motor replacement. getting the correct replacement motor. I have a model no.,frame no.,,RPM,mfg no etc. but forgot to physically measure the shaft and diameter of the motor. Emerson fan motor model no....
Nov 20, 2009 | Heating & Cooling
I wish to rewire a single phase electric motor with compositor's that is currently setup for 230 VAC to 115 VAC. The motor is a Ingersoll-Rand Air Compressor motor with the following nomenclacher. Single...
The motor itself should have a sticker which describes the wiring for 115. It is a small change involving a single wire moving from one pole to another inside the motor starter cap (the bump on the motor itself).
Aug 26, 2009 | Air Tools & Compressors
Kitchen Ranges Logo
174 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
