I'm looking for a manual for a Philips VS55405T 380 Resolution Quad Security TV.
  • 6,993 Answers
unfortunately, the manual for this particular Philips brand that you are requesting for is not available anywhere online.
I wen further by searching and couldn't find any.
The best option you have now is to contact Philips directly and order for the manual or call their customer care via the phone.
Visit the below link in order to contact Philips:
http://www.support.philips.com/support/catalog_selector.jsp?COOKIE=off
After the link opens, select your continent, language and proceed.
Good luck.
Posted on Aug 27, 2010
Can you adjust resolution on a Philips 60pp9202/17f
Your tv goes up to 1080i. But it will only display the resolution its given, such as a (DVR,Cable,Satelite,GameConsole(wii,ps,xbox)) has its own resolution and whatever resolution it is at is what the tv gets and displays. Same if it runs thru a Surround sound that only supports certain video resolutions such as 480 or 720 and not 1080 then it will not display a 1080 resolution even if your tv can. The only way you would change the resolution on the tv is if you did it in the first place for some reason or a old school antenna mix up (unlikely). Also just in case the aspect ratio is not the same as resolution so just in case your trying to get rid of black bars or have cut off image or to get a rectangle or square image thats not the same and usually can be adjusted.
Feb 21, 2015 | Philips Televison & Video
Bad resolution when i plug in my xbox 360 to my philips 32PFL3606H/12 tv
You may have to go into your settings on your xbox and try to manually change the resolution settings.
Apr 21, 2014 | Philips 52PFL7422D/37 TV
Philips tv smokes
Do this only if you are a qualified service technician:
This problem can come if any moisture has entered or is formed inside the TV.
Switch of the power outlet, and remove the plug. Open the back cover and check what are the parts burnt visibly. If it is in the SMPS area, you may require a thorough check on the load and replace all the burnt parts by looking through a Service Manual. Anyhow, this might require attention by a qualified service technician.
Jul 11, 2012 | Philips 47PFL5603D/27 Flat Widescreen TV...
Philips 37 TV smart sercurity unblock?
Either read the owner manual or CALL philips customer service with the model number to get help
May 28, 2012 | Philips TP2784C TV
My Philips 42FD9934 on win7 64 can not keep resolution 1280x1024 in normal mode.Only in safe mode.
In safe mode laptops/pc's use a basic 800X600 video. Maybe your TV is not accepting that high resolution. Check your TV manual for the specs. and set your pc accordingly.
Dec 24, 2010 | Philips 42FD9934 42 in. HD-Ready Plasma...
Video resolution not supported, but the audio is playing
There should be a way to adjust the resolution on the DVD player, check on the front of the unit for a button that will turn it down to 480i, or anything less than what it is at. You may need to consult the manual, or hook it up to another TV so you can adjust the resolution, then re-attach it to this TV.
Sep 14, 2010 | Philips DVP3982 DVD Player
How do you connect my pc to the hdtv?
First, with your pc connected to your current monitor, change the resolution to 800x600, turn off the pc, connect it to your tv via VGA or DVI, and turn on the pc, check your tv manual, seek the highest resolution supported and configure it ON PC. If the resolution is higher than your tv supports, will be no image.
Nov 29, 2009 | Philips 50PFP5332D 50 in. Plasma...
How can i change the resolution on my tv?
i am pluging up my playstaion 3 up to my philips flat screen in the hdmi cable slot and it is telling me to change the source resloution
Nov 03, 2009 | Philips 52PFL7422D/37 TV
I need the service mode sequence for my philips 51pp9100d/37 so I can manually change the resolution on my tv. The resolution somehow was changed and when I HDMI my laptop to the tv it wont display t
I suspect that you may be using a cable or sat box rather than that set's internal atsc tuner.
Sometimes these boxes are not set up properly or reset themselves to a lower resolution.
Go into your box's settings menu nd look for the resolution settings. Verify that all of the modes or at least the maximum resolution for your set is enabled.
May 02, 2009 | Televison & Video
Ssl2006
I looked at the manual. YES YOU NEED A CONVERTER. This unit does not have a digital tuner. It is a fairly nice, low-resolution (not high-def) TV with an analog tuner..
Dec 30, 2008 | F5 Networking (F5-ADD-BIG-SSL5000)...
Televison & Video Logo
32 people viewed this question
Top Televison & Video Experts
Electro Med Services...
