The thermocouple will not stay lit even after putting on a new one
    President:
  • 1,796 Answers
Hi!!
If thermocouple is OK, then your problem is fuel delivery, check fuel supply, if OK, the thermostat unit, it is probably defective.
Good Luck!! Don't forget to rate this post!!
Posted on Aug 26, 2010
We bought new natural gas logs would not stay lit put a regulator on 3 to 6 they lit stayed lit about five minutes turned off to place logs on now willnnot relight
sounds like you might have a thermocouple problem. we can not diagnose it from here call a local gas repair serviceman
Feb 06, 2017 | Heating & Cooling
Tip
I have a standing pilot that wont stay lit.
If you have a standing pilot that wont stay lit and you have to keep relighting it, it can only be a couple of things that will do this.<br /> 1. Try tighting the thermocouple at the gas valve. (this is a thin copper line that goes from the gas valve and goes to the pilot light.)<br /> 2. Make sure that the tip of the thermocouple is in the pilot light flame.<br /> 3. Make sure that the thermocouple is clean.<br /> <br /> if you have done these and it still doesnt stay lit, buy a new thermocouple.
on Mar 14, 2011 | Heating & Cooling
We have a Chesterfield Cannon double oven (gas) the top oven would not stay lit after holding in the control knob in for several seconds, the engineer came out and fitted 2 new thermocouples but the t
Swap the two thermocouples to see if problem switches. If it does bad thermocouple on one that does not work. If it is the same somethng is wrong with the gas vave itself. The holding coil leading to that burners thermocouple is most likely bad.
Sep 06, 2014 | Heating & Cooling
Pilot light wont stay lit on gas logs
If the pilot lite comes on, but will not stay on after it has had enough time to heat the thermocouple, you got a bad or the wrong thermocouple. It does take some time to heat that thermocouple.
Nov 26, 2013 | Woodland Direct CD Vent Free Gas Log Set...
Pilot lite won't stay lit
Thermostat flame sensor. Do you see a little rod next to the pilot? That is what tells the main gas valve that the pilot is lit and it is safe to give gas. Easy swap, and you can usually just pick up a generic one.
Apr 14, 2013 | Heating & Cooling
Water heater pilot light will not stay lit. changed the thermocouple, and still won't stay lit.
Hold the pilot button down for a full minute after it lights, then release. If this does not work then the thermocouple is not adjusted where the flame is heating it or you just have a faulty new thermocouple.
Sep 06, 2011 | Heating & Cooling
I have a few issues with an old probably dinosaur Coleman Presidential III 7995a-856 Heating unit. I've had 3 different repairmen look at it and they're clueless. The main pilot will light and stay lit...
if the pilot is clean and and strong then this should play on to the thermocouple , i take it you have changed the thermocouple , and the connection is good at the gas valve , then if this going out could be 1, powerunit on gas valve not holding at thermocouple connection
2. Hole in heatexchanger blowing out pilot when blower comes on
I take it the pilot stays on untill fan comes on and keeps going out , I would think about not putting any more money in to this and get new if sounds as the heater has had its day ,
Dec 17, 2010 | Coleman Heating & Cooling
Pilot light will not stay lit
your thermocouple needs to be replaced. they are available at any hardware store.
Sep 16, 2009 | Water Heaters
Outdoor patio heater won't stay lit
I'm told by Charmglow that the problem is the Thermocouple. iHowever,it took me several calls to get someone to admit this. They are sending a new thermocoupler. My heater is less than a year old and under warranty--but it's a shame things like this happen.
Originally I was told it could'nt be the thermocoupler as they normally last at least 5 years.
Try it--as it may solve your problem as well.
Sep 21, 2008 | Heating & Cooling
Burner will not stay lit
Presuming the flame is touching the thermocouple, try putting slightly more pressure on the knob and hold for a few seconds longer. If this doesn't work try going through the same process with the knob removed - if this works you need to put a small piece of packing in the shaft of the knob ( a small piece paper might do). If this fails you need a new thermocouple.
Nov 10, 2007 | Miele 20 in. KM405 Gas Cooktop
Heating & Cooling Logo
14 people viewed this question
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
