Need to know the output impedence ie 8 ohms 16 ohms or outout voltage 25 volts, 70 volts
4 Suggested Answers
SOURCE: Denon AVR-2307 Protection Circuit Activated permenantly
The speakers are 4 ohm speakers, a guy on another chat site sent me a link to the impedance curves http://www.audioholics.com/reviews/s...t-v2-fs/page-4
He agreed to that there was a mismatch as the unit has plenty of fresh air around it, plus all the speaker cables have been tested and installed correctly.
So, off to the store where I got it from tomorrow.
Posted on Jan 04, 2009
  • 3 Answers
SOURCE: Sony STR-DB940 Receiver Speaker Impedance Question
Whats the rating on the Plasma? How many watts at 4 ohms? If the plasma is rated 100 w at 8 ohm... hanging a 3.4 ohm load would put a lot of strain on the plasma's output amp. At 3.4 ohm the amp would be trying to delive close to 200 watts at full power. But it depends on how hot you normally run the volumn. Remember an amplifier output is AC volts. 1 ohm of resistance is close to a dead short. The amplifier would have to work its *** off to supply that type of power and would probably burn the output op-amps. If the outputs burn & it pumps any DC current through the speaker wire..the speakers would be toast...if not catch on fire. Try to keep the speaker load at or very cloe to the plasma's output load rating. Also if the plasma doesn't state it will handle loads down to 2 ohms...It probably won't.
Gene
Posted on Mar 03, 2009
  • 3 Answers
SOURCE: can I mix 6 and 8 ohm speakers?
Most Yamaha HTR's are high current receivers so setting the receiver to 8 ohms and running the 6 ohm speakers shouldn't be a huge problem. I wouldn't crank the volume though if i were you but at a decent level you should be fine.
Posted on Feb 28, 2010
Y does my technics sug88 say low imp beside the a and b speakers
Because you've done something with the speaker connections that's too low impedance for the amp.
Amps need a certain level of resistance from the speakers otherwise there's a risk of the amp blowing itself up. Impedance is the name for resistance that varies with audio frequency. If the speakers you connected are any good, then there'll be label on the back telling you their impedance in Ohms.
When running a single set of speakers only then the amp would prefer an 8 Ohm load but it will accept a 4 Ohm load. If you plan to run speakers in both the A and B sockets, then both sets of speakers have to be 8 Ohms and no less. It also tells you this on the printing directly above the speaker sockets on the amp.
The amp is trying to protect itself from an overload situation where it would blow its output transistors and possibly kill your speakers too.
Oct 19, 2014 | Audio Players & Recorders
The speaker has a low power output
The output of a speaker primarily depends on system design (obviously) However, perhaps you have sourced a replacement or 'upgrade' speaker for an existing system. In that case, perhaps you have an impedance mismatch. If your amplifier is designed to drive, say, an 8 ohm speaker, and you connect a speaker of 16 ohms impedance, then your sound will be softer. On the other hand, you may have connected more than one speaker to one power amplifier output. If you connected in series you add the impedances. If connect in parallel you work out the impedance using this formula:
1/Answer= 1/Speaker A impedance + 1/Speaker B impedance + 1/Speaker C impedance etc. So if you connect three speakers in parallel, each of 8 ohm impedance:
1/Answer=1/8 + 1/8 + 1/8 = 3/8
3X Answer=8
Answer = 8/3 = a little less than 3 ohms.
Reducing the load like this makes the sound louder, but risks distortion or even damage. Check your manual for amplifier tolerances. Cheers, Don.
Dec 13, 2013 | Audio Players & Recorders
How do you change from 4 to 8 ohm output on a phonic 1860 mixer
Stereo and bridged mode selects automatically. Stereo mode gives 4-16 ohms per side. Bridged mode is only from 8-16 ohms. This impedance match is created by the combination of speakers you use. If you link any speakers, the wiring is usually going to be in parallel because of the sockets wiring in the cabs. Any time you link 2 speakers in parallel, it cuts the impedance in half. Remember that in bridged mode, do not link 2 8 ohm sets together because this will create a 4 ohm circuit which it will not allow. This can only be done in stereo mode. It is ok to use speaker combinations of higher impedance, but never go lower as it would cause damage to the power amp.
Apr 03, 2013 | Music
250W, 8 Ohms speakers on 150W, 6-16 Ohms Amplifier.. What is the effect of this?
If your amp states that it will support a range of 6 - 16 ohms, an 8 Ohm speaker will work fine on it. If the speakers you hook up to it are lower than 6 ohms, it may work until you turn it up, then it will either shut down or burn out the finals. If you hook up a speaker that has a higher than 16 ohm, it will not get very loud, and it shouldn't hurt the amp.
Feb 14, 2012 | Concept Car Audio & Video
How do you switch the behringer 3000 to bridged mode,what settings do you use to get 1200 watts out of it.
Well... you probably won't like this, but here is some info: In bridged mode, a different Speakon to speaker cable is required from only the B... it is wired differently and you can only use one of the plugs. The speaker or speaker system CANNOT be less than 8 ohms in bridged mode... this precludes using speakers in parallel or multiple speakers that are less than 16 ohm impedance... such speakers are NOT commonly available as most are either 4 or 8 ohm. There is a slide switch for bridged mode on the face of the mixer. Next thing you won't like... The 1200 Watts specification is PEAK power, NOT RMS... You can get 400 watts RMS per side USING 4 ohm speakers. If you use 8 ohm speakers, each of those will get 200 watts. I use this mixer myself and ALSO repair them. The voltage swing at the outputs is about +/-60 volts MAX (peak). This is about 40 volts RMS by the time the circuit LOSSES are taken into account. Across a 4 ohm speaker you get 10 amps times the 40 volts or 400 watts. Across an 8 ohm you get 5 amps or 200 watts. The voltage rails in the switching amp are +/-70 volts DC so these are reasonable values. Bridged mode just uses both sides of the amp driven in opposite directions for higher voltage out BUT you have to use no less than a single 8 ohm speaker so there is NO advantage to bridged mode power wise. IF YOU NEED more power, use extra speakers from an additonal amp driven by the 1/4 TRS mains output jacks OR use additonal POWERED speakers driven from the same jacks. Please read my tip about the hazard regarding the SLEEVE of the cahnnel A cable when using Speakon to 1/4 plug cables being the HOT and the tip being the cold for channel A. Ground the sleeve accidentally and goodbye channel A amp...
May 10, 2011 | Behringer Pmp3000 16 Channel Audio Mixer
I have the TOA 906MK2 and do not know how to hook up 2 JBL 8 ohm speakers to it. I am unsure about the connections int he back (25v or 70v). How do I make this connection?
you should not connect any regular spks to the 25/70 line o/ps use the direct 8ohms connections if they exist, this amp is normally used for what used to be called 100V line and produces real AC volts on the 25/70 outputs this will damage any normal non transfomer type speaker.
Hope this helps
Thanks for using FixYa
Aug 10, 2010 | TOA Electronics P-924MK2 Amplifier
How to activate 70v line of crest audio cki 800v
First of all the 70 volt line is used when we are dragging long lengths of speaker wires. hence to counter the drop we use a high voltage line brring it further down without any remarkable drop and use a step down matching transformer to power the speaker according to the impedance of the speaker to the secondary of the transformer. Connect the 70 volt to the 70 volt output in the amplifier. Now connect the other end of the wires tto the primary of the 70 volt transformer. Use the secondary output to connect to the speaker using the tap most suitable..2, 4,6,8 ohms . Check the phasing when you connect or reverse if the bass quality is less.
Hope this helps. Good day
Jun 29, 2010 | Crest Audio CKi 800v Amplifier
Speaker compatibility ( Just got this new reciever with 120 volts power requirement of the receiver, but in the philippines voltage standard supply is 220. can i use 110 voltage supply instead? and I dnt...
The most likely answer is no. Unless the power transformer is of the multi tap type and has a voltage selector window on the back panel... Most speakers today have an impedance of 8 ohms. The impedance is all you need to worry about when matching speakers. You can fit 8 ohm speakers to a 4 ohm system, but you cannot fit 4 ohm speakers to an 8 ohm system. It would overload your oputput stages and cause them to fail. It's best to match 4 ohm with 4 ohm, 8 ohm with 8 ohms.etc.
Mar 19, 2010 | Audio Players & Recorders
Gene
Mar 02, 2009 | Sony STR-DB940 Receiver
Adding speakers to Fender Passpost 500 Amp system
If you add 8 ohm speakers in parallel then you would be running the amps into a 4 ohm load ...which will overheat and possibly damage them ...... if you wire series then the amps would be loaded to 16 ohms ...which would be ok ..but you will only develop 70 % of the total output power
IE a 100watt would be down to 70 watts
much better to add some seperate powered speakers
Jan 27, 2009 | Fender Passport Deluxe 500watt Sound...
 Grubhead
Grubhead
