Question about Samsung LE40R74BDX 40 in. LCD Television
How do I attach the TV to the base stand. The holes from the stand guide do not seem to match up to the holes of the TV
  • 734 Answers
Drill extra holes to match the TV?
Posted on Aug 26, 2010
REMOVEABLE BASE STAND
I think this aftermarket stand will work. The reviews mention a couple of people using this with heavier lcd/plasma screens with no problems. Hope this helps!
http://www.amazon.com/Universal-Stand-Base-Wall-Mount/dp/B00DZVPFGU/ref=sr_1_5?ie=UTF8&qid=1399529274&sr=8-5&keywords=50+inch+universal+tv+stand
Apr 18, 2014 | Polaroid PLA-5048 50 in. HDTV Plasma...
I need instructions to put Wilton's 3 tier party stand together
According to Wilton:
You should have 8" plate, 10" plate and 12" plate
Match the sizes with rings and legs on table.
Attach legs to serving rings,twist threaded end securely into housing on each serving ring. Tighten using wrench.
Attach 8 1/4 Serving ring to Center Footed Base Ring -Position serving ring with footed leg out. Line up the other 2 legs with the correct housing on the base ring, the width between housing should be same as that between legs.. Insert end of legs into housing.
Next attach 10 1/4 Serving ring to Base Ring, You will need to move clockwise around base ring to attach this ring. line up legs and insert legs and tighten.
Attach 12 1/4 serving ring to base ring. Insert legs into last pair of housing on the base ring.
Position plates so lip edge rests inside serving ring.
Apr 16, 2013 | Wilton WHITE 3-TIER CUPCAKE STAND...
I need a Panasonic TV TH-42PD25 base stand! I've searched ebay, no luck. This might sound dumb, but can I use base stands from any of the other Panasonic 42" models?
You maybe lucky, but make sure the mounting holes on the stand matches your TV.
Alternately you can use a wall mounting and these have mounting holes that suit most TVs.
Nov 30, 2012 | Televison & Video
Screw size for attaching stand for Sony Bravia LCD TV model# 46W4500
while the owner manual does not specify the length etc of bolts it does show there are 4 of them---look like find thread machine bolt---may be able to buy a few at the hardware sore or Home Depot---if the threads are inside the base take it with you as a guide.
http://download.sony-asia.com/consumer/IM/4106869131.pdf
pretty stupid as owner manual has everything including dimensions and weight etc but no list of bolts size.
May 20, 2012 | Sony BRAVIA KDL-40S2000 40 in. LCD HDTV
How do you assemble the stand to the tv
This is a pretty easy job.U have the four Philip screws that came with the tv base stand wright?U have a Phillip screw driver wright?Just put the base stand into the tv make sure all the screws holes lines up between the tv and the base stand holes.Than just tighten the Phillip screws with the Philip screws driver,than u are done.
Jul 14, 2011 | Samsung LA40A450 40 in. LCD TV
I bought a new Vizzio M22OVA and have been trying literally for days to attach the base stand. I even called Vizio customer service and they were no help. I'm at a total loss. I really love the design of...
The stand has 8 small tabs that protrude from the top of the stand. There is also a larger clip that sticks up a little in the center. Purpose of large tab is to snap into place to keep stand from coming off. Just place stand on bottom of tv so the tabs on the stand go into the holes in bottom of tv.
Then just slide stand forward or backward till it snaps into place. I think 2 screws go into the bottom of stand after it is snapped in place to hold it. Just be careful and don't put any undue pressure on the screen. Actually works better with one person holding the tv upside down while another snaps base in place.
Jul 04, 2017 | Televison & Video
TV tilts forward on base about 15 degrees, TV will pivot left or right but won't remain perpendicular or upright.
The only things I could think of causing this would be either the hardware not tightened up properly or defective base (stand.) Make sure all the screws are tightened securely in the bottom of the base and in the back of the tv where the base attaches. Someone may have used the wrong screw holes to attach the base but there really should only be 4 holes to use to screw the base to the tv. This may need returend to the retailer for an exchance of the base.
  1. Oh, the last thing to check is that someone did not put the base on in reverse. Most have a small alightment tab that makes sure the front of the base goes to the front of the tv and if it is put on backwards the tv would tilt forward a few degrees.
Mar 09, 2011 | LG 42LC2D 42 in. LCD HDTV
Need to know how to attach the stand, I have the parts that came with the TV but no instructions.
Very easy to attach the base.Just put in the base in long square whole matches up all the screws holes and put in like 4 Philip screws in and tighten it with a Philip screw driver that should have the base stable and hold the tv.
Jul 07, 2010 | Insignia LCDTV26 26 in. Television
I need to remove tv stand from my Soyo DYLT032D to mount on wall, Also what screws do you remove in back of TV? Thanks...
Remove Back plate screws and match up the holes on the wall mount device with the holes on the back of your television. Attach the television to mounting devise, Then mount both to the wall. Hope this helps you with your problem.
May 09, 2009 | Soyo DYLT032D 32 in. LCD Television
Samsung LE40R74BDX 40 in. LCD Television Logo
122 people viewed this question
Henry  Thomas
Henry Thomas
