Question about Cameras
Take up reel won't move - Cameras
  • 6,831 Answers
Hello
Unfortunately you do not specify what the question is. Please be more specific.
Kind regards
Andrea
Posted on Aug 26, 2010
The level wind guide moves when reeling in but does not move when the line is running out what is wrong
There may not be anything wrong.
some levelwindays reels disengage the line guide during casting or when releasing line.
Sep 23, 2014 | Fishing
Poor casting ability
Remove the left side plate and set the little plastic things ( I think they are yellow) so they are against the inside..they should kinda snap inwards and stay there...
Found a video ( not well made but it shows how to access the brake system).. you will see the SIX little yellow plastic brake adjusters... start with moving FOUR (4) - opposites of each other - of them inwards towards the spool shaft.. they should "click" inwards and stay there...CAST carefully the next time.
.. how to access brakes on abu garcia orra sx and revo lp baitcast reels
Jul 16, 2017 | Abu Garcia REVO STX Generation 3 Casting...
Brake not working
Did you try to calibrate the drag by spinning the top part of the reel.
Jun 05, 2013 | Fishing
My reel deal casino masters edition won't play on my pc
Does your computer meet the requirements to run this game?
If so, It could be an error with the disk
If no, you need to get a new computer
Dec 09, 2012 | Samsung 300E5A-A03 laptop
Magnavox dv220mw9 the vcr player won't play
Someone will have to open the unit to see what is happening---either tape is not loading all the way or when FF or Rewind hit not moving the reels----could be as simple as a belt or a bad drive idler (most use either a rubber wheel or gears to move the tape in Play, FF, and Rewind.
Dec 03, 2012 | GoVideo VR4940 DVD Player/VCR
Teac A-7010 take up reel not pulling
If this is a direct drive deck, the takeup reel motor may be ng
Jul 04, 2012 | Teac Audio Players & Recorders
My line won't rewind on my Shakespeare Encore reel. After casting, the bail snaps in place, but when I reel in, the line won't reel in. The spool turns with the bail, but doesn't retriev
Your line is on the wrong side of the bail. Rethread the line so its over the bail so that after the cast you flip it up it catches the line and retracts it.
May 05, 2012 | Sport & Outdoor - Others
I have a sony TC-660 reel to reel player, it had been in great condition, and i love using it. All of a sudden however, the reels will ONLY move in one direction (clockwise for the left, and counter...
In order to maintain tape control and tension the reels always pull lightly in opposite directions during PLAY mode. The capstan moves the tape in the desired direction at a precise speed. If the capstan doesn't engage the tape BETWEEN itself and the pinch roller you'll get the reels battling over control of the tape. Check the tape routing.
May 25, 2010 | Quantegy 456 Reel-To-Reel Recording Tape
Threading reel to reel
Depending on which brand of recorder you have, most do have a general threading scheme. As you are facing the unit, the supply (full) reel would be on the your left and the take-up (empty) would be to the right. Position the supply reel so that the leader end of the tape will be on the outside. Pull the tape end around the shut off sensor lever so that it moves freely. Now pull the tape leader between the rubber pinch roller and capstan (in the case the unit has dual capstans). If it has a single roller on the right side, pull the tape between the heads and then between the roller/capstan. If unit has dual shut off sensor levers, pull tape around this sensor as you did the first, making sure it moves freely. Then thread the tape leader into the take-up reel slot. Press play. Both reels should turn counter clockwise.
Aug 01, 2008 | Audio Players & Recorders
Tascam 22-2 no sound
Yes you need to hook it up to an amplifier and speakers through RCA cable on the back. And or you can use headphones if there is a headphone jack?
Also make sure there is something recorded on the reel tape in the first place. You can do a test recording of something like a CD from your CD player or record something, then play it back, make sure you turn the record input volume knob up and make the RCA connections on the back of the reel unit and connect to your playback source you want to record. When you playback the reel tape, the db meters should be moving on the front of the reel deck, if they move then you most likely have some sound recorded on the reel tape.
If you still can't hear any sound and the db meters are moving, then check all your connections again and volume output knob on the reel deck. Hope this helps?
Sep 26, 2007 | Quantegy 456 Tape Reel(1/2 in. x 10 1/2...
Cameras Logo
12 people viewed this question
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
