Question about Singer 7422
My thread (not bobbin thread) is bunching excessively on my singer 7422 and can't figure out why.
  • Anonymous Jun 18, 2008
    Just bought this same machine this weekend. I am having the exact same problem. The top thread is looping on the back of the fabric. I have adjusted the tension every which it can go. I can't get it to work. The machine is threaded correctly, but I can't sew 5 inches before it bunches up at the bobbin and all the lights on the machine go nuts.
I just recently had the same problem and couldn't figure it out til a second ago. My problem had nothing to do with the tension but with the fact that my TOP THREAD wasn't threaded right. If you look on page 18 of your manual, I discovered I didn't have my thread through the take-up (C#4 image) properly. I hope that helps.
Posted on Oct 07, 2008
    Novelist:
  • 77 Answers
Hi Tammy,
The problem seems to be with the thred tension adjustment lever/screw (it looks something like 2 inverted disc washers clamping each other thru which a section of your thred passes before going to the puller and then subsequently to the needle guide and then the needle. The fundamental principle of all sewing machins ae the same. Check for the tension. It may have become loose. Also check for the rocker on the inside where you place your bobbin. Are the rocker arriving in syncronisation when the needle is at its maximum in side the knotting hole. If not then there must have been a slight play in the assembly. You alone may not be able to solve all these things. But atleast you know what are the possibilities. I suggest you try only what you can do on the outside. As for the rest, you should refer it to an authorised service person.
Good luck tammy.
Posted on May 06, 2008
Singer advance 7422 bobbin jumps
Did you get it fixed? Here is a video that may help.
Mar 20, 2014 | Singer Advance 7422 Electronic Sewing...
7422 singer will not pick up the bobbin thread
try changing the needle
rethread the machine top & bobbin
use every thread guide
here's a link for a free manual
http://www.singerco.com/uploads/download/465_7442_efs.pdf
if these suggestions don't help then it's possible that the machine could
be out of time
Apr 22, 2012 | Singer 7422
My bottom stitches are bunching up every 10-15 stitches. I cleaned my bobbin area.
Check the bobbin tension and that the thread is tight around the bobbin. Make sure that the bobbin is in the right way around - the bobbin thread should double back on itself coming out of the bobbin holder.
Feb 22, 2011 | Singer 7422
Thread jams on the bobbin
upper part of machine not threaded correctly. no needle tension = bunching underneath
Apr 21, 2009 | Singer 7422
Bobbin tension is too loose
"Birdnesting" occurs when there is no tension on the needle thread to pull the bobbin thread. This is easily corrected by rethreading the machine, following the threading path carefully and making sure the thread is fully engaged in the tension mechanism.
Dec 08, 2008 | Singer 7422
Singer advance 7422
My Singer 7422 seems to be jammed. When I start to make a stitch, the thread from the needle gets caught on something on the bottom and the thread goes over the bobbin.
Jul 16, 2008 | Singer 7442 Mechanical Sewing Machine
Singer 7422
Make sure you have the machine threaded for the bobbin and not threaded through the sewing path. Also, check to make sure that the bobbin is pushed directly against the post as far as possible.
Apr 13, 2008 | Singer 7422
Singer 7422 bobbin thread bunching up
I assume you checked to see there are no needle bits in the bobbin case holder.
Without looking at the machine it is difficult to diagnose the problem. It could be any one or a combination of problems, timing, needle bar height, damage to the hook and base etc.
I strongly suggest you have it looked at by a sewing machine tech.
Mar 29, 2008 | Singer 7422
Thread getting stuck in the bottom.
Mine is also doing this, but it has an auto tension and doesn't have those numbers on it. It is the 7422 Advance. I just bought this machine and have yet to be able to do anything with it. Very disappointed. Taking it back ASAP and never buying Singer again. Machine locks up for nothing, have to turn off and back on and it works, then the thread bunches up at bobbin and I have checked everything. And it was suppose to be able to accomodate a little bulk, (doing a quilted christmas stocking), however the fabric will not feed and it just starts to bunch up. Good luck
Jan 04, 2008 | Singer 7422
Singer 7422 Logo
184 people viewed this question
Top Singer Sewing Machines Experts
Tally Girl
Tally Girl
mystery_soul
Are you a Singer Sewing Machine Expert? Answer questions, earn points and help others
