You will need to remove from the bottom of the oven but make sure that you hae not damaged the magnetron with the dry run.
You can try to get the part from a salvaged set as many arre available, junked when the magnetron fails.
Bothe plate and shaft can be sourced like this and will worrk outt cheaper only if you try sources of workshops.
