Question about Intex 2000 GPH Salt Water Filtration Pump with Saltwater Chlorine Generator
I have an Intex Krystal Clear saltwater system I installed in May on a easyset 48" X 18' pool. It has performed perfectly until recently when I noticed that the water clouds up and appears green each time I set the system to chlorinate. Thinking I had a fluke on my hands, I ran it on boost for two days. The appearance worsened rather than improving. Chlorine, ph, alkalinity, and copper ppm show mid range on the test strip charts that came with the system. How to I tell if I have a defective system??
SOURCE: my intex saltwater chlorine generator & filter beeping forever!!!
hello our pool chlorinator keeps comming up low salt 91 no matter how much salt we put in this is frustrating why is this happening ,,,please help
Posted on Jul 01, 2009
  • 297 Answers
SOURCE: My saltwater system produces chlorine but disappears fast
first of all your problem is a few things combined.
First lets learn what consumes chlorine
Heat,sun,rain,sun tan oil 3 of swimmers
you may need to run your generator 12 hours some nights it all depends on what kind of day it was and what the chlorine was to start with
Also if you do not have your salt as close to 3000ppm as you can then you are also not generating enough chlorine even if you are not triggering an alarm for low salt
you can not be below 2800 and no higher than 3800ppm
a test kit is available get the strips that reads #'s not the color strips for salt reading
Also you should be using a chlorine stabilizer to help hold the chlorine level this is only a help situation. it will not completly remidy your chlorine level going low if all the elements I mentioned are happening at the same time
Also be carefull not using the pool that is the worst thing you can do. You may go green quick without people in it stiring it up
I also recommend you use a non foaming algaecide every 5-7 days just follow directions for your gallons of water
By the way bromine tests are really not for pools they are designed to work with the hot water and chlorine level of a hot tub
your ph is fine, about in the middle alkalinity is what drives your ph so worry about the ph level and chlorine and you are good to go
Posted on Jul 09, 2010
  • 8404 Answers
SOURCE: I have a krystal clear
IMHO, stay what ever setup you have. It it is salt with a working cell, stay salt as salt is cheaper. If it is CL, you will have possibly add the cell and power supply needed to turn the salt into CL. CL is cheaper than the equipment you may have to add.
How big is your pool? If you use salt, you will have to keep the level between 2800 and 3200 PPM and you will have to add cynauric acid to protect your freshly made CL. If you use dry CL, that normally comes with built in cyanuric acid. Salt water in your back yard will not be good for your grass ... just a thought. Salt will also attack all metal near by. But on the other hand, CL will also attack metal. Salt and CL are very closely related.
I wouldn't invest a lot of $ to convert from one to the other ... these devices don't necessarily have a long life. When what ever you have quits you will have to buy new ... decide which system you want at that time. BTW ... remember, you are currently using "free" equipment. Why make it 'expensive'?
Further questions? Post to this comment which will generate a e-mail to me to come back ... OK?
Posted on Jun 05, 2011
Testimonial: "thanks alot, you surely gave me alot of information. I think that I'll stick with what I have."
  • 17 Answers
SOURCE: my pool is cloudy I
How long has it been since you cleaned the cartridge in the filter? If it's been a while, I'd recommend cleaning it thoroughly with a filter cleaner (degreaser). This will help to filter out any small particles that can cause cloudiness. I'd also recommend that you increase the salt production on your salt system. The normal range for chlorine is 1-3 ppm. You're too low at 0.2. If all of these things are done and the pool is still cloudy, I would add a clarifier. FYI: too much is not better when adding clarifier!
Posted on Jun 16, 2011
briones93
  • 119 Answers
SOURCE: We have a Krystal Clear
You should always follow the instructions on the manual .. I have a 18X33X4 oval and had to start with over 350 lbs of salt and ran the pump without the chlorinator for 24 hours to properly disolve the salt. Then, I started with 12 hrs pump cycle with 10 hrs of chlorination in between the 12 hrs. Keep checking the chlorine level and adjust time from there. Currently at temperatures of 85 to 100, I run the system at 10 hrs pump with 8 hrs chrlorinator and water is Crystal Clear... In the 2 years with the intex system, I have not added any chemicals to my pool. I once had an issue when the water level went low while I was on vacation, when I came back, the chrolinator had turned off due to low flow and my pool water was green.. As soon as I re-started the cycle, a few days later, Crystal Clear again... NO CHEMICALS OR SHOCK added.... Hope this helps....
Posted on Jul 15, 2011
Why is my saltwater pool turning green?
balance the water with chlorine super shock it once in balance your chlorinator should maintain a chlorine reading if you have a heavy bather load you must shock manually
Jul 29, 2014 | Intex Krystal Clear Saltwater System Pool...
How do i fix my saltwater pool its green?
it sounds like your chems are off, check you chlorine and PH, I go for a 3.0 to 5.0 on the chlorine side and 7.2 to 7.5 on ph,
Jul 29, 2014 | Intex 2500 GPH Filter Pump Krystal Clear...
Why is my intex pool water turning green even with the saltwater chlorniator
enough salt? too much salt?
running enough hours per day?
adequate flow to activate salt cell? (cf dirty filter)
Salt cell clogged with calcium deposit?
Jun 21, 2012 | Intex Krystal Clear Saltwater System...
Can i use a sand filter with the intex krystal clear saltwater system?
Yes you can.
The saltwater chlorinator is connect to the outlet water pipe from the sand filter before the water returns to the pool.
Depending upon the model of the saltwater chlorinator It may need to be mounted horizontally or vertically, check with the installation instructions..
Apr 11, 2012 | Pool & Spa
Have no owners manual and can't figure out how to set the timer!
code 88
Is the Setup/Start up Code. it is displayed until you set the timer. which you do so by holding down the down arrow till you hear a beep, then hold down the up arrow till you here a beep. from there you can set the time and then to lock it in repeat the process
If you need the manual you can email Intex at www.email.intexstore.com
Or you can buy the manual on this link below.
http://home-and-garden.become.com/intex-krystal-clear-deluxe-saltwater-system-salt-in-pool-model-8110-owners-manual--compare-prices--sc906782580
Good Luck and please rate 4 thumbs up for the free answer.
Jul 05, 2010 | Intex Automatic Salt Water System for ...
I have installed my Intex Krystal Clear Saltwater system for my above ground pool and have run it for 12 hours. I want to run it another 12 hours. How do I start the system again instead of waiting on the...
First of all you should not have set it to generat chlorine until straight filtering for 24 hours. unplug then plug it back in
88 will appear let your salt disolve by filtering only for the 24 hours then proceed to generate chlorine
It may look disolve but there are many hot spots that need to get distributed eveny
Jun 07, 2010 | Intex Automatic Salt Water System for ...
Intex 2000 GPH Salt Water Filtration Pump with Saltwater Chlorine Generator Logo
60 people viewed this question
Top Intex Pool & Spa Experts
avionik99
Level 1 Expert
Jay Finke
Jay Finke
Mike
Are you an Intex Pool and Spa Expert? Answer questions, earn points and help others
