Question about Frigidaire FEF366 Electric Kitchen Range
CANT GET THE GLASS TOP OFF - Frigidaire FEF366 Electric Kitchen Range
    Problem Solver:
  • 14 Answers
Yes ,Best place is at repairclinic.com
Posted on Sep 04, 2010
How do i separate the old glass from the convertible top on a 2010 mustang
Glass is bonded to top cloth. You must replace entire rear cloth section and sew it to the top. Requires top removal and upholstery sewing machine. Farm this job out.
Jun 16, 2015 | 2010 Ford Mustang
I cant clean my glass on my stove where do i take it apart. i tryed the 3 screws on top put i still cant take it out ( the glass part)
put the door down, and unscrew all the screws inside the oven door. Be prepared for the door to come apart as you come to the last few screws.
Nov 18, 2009 | Frigidaire 30" Self-Cleaning Freestanding...
How do you remove the glass from the rear side window regulator
Remove the door panel
  1. Remove the side impact bolster.
  1. Detach the door speaker (if equipped).
  1. Disconnect the speaker electrical connector and remove the door speaker (if equipped).
  1. Detach the door latch release handle.
  1. ani_caut.gif CAUTION: Do not touch the adhesive surface as re-bonding will be impaired.
    Detach the watershield.
    • Using a suitable plastic knife (disposable cutlery), cut through the Butyl strip to enable the watershield to be peeled back.
  1. Remove the door glass top run retainer.
Vehicles with manual windows
  1. Install the window regulator handle.
Vehicles with power windows
  1. Connect the door glass operating switch electrical connector.
All Vehicles
  1. Align the regulator clamp with the access hole (power window shown).
  1. NOTE: Position the regulator operating cable to one side when drilling the retaining pin, in order to prevent damage.
    Detach the door glass from the regulator clamp.
    1. Using a suitable electric hand drill and a drill bit 8 mm, remove the retaining pin.
    1. Push out the retaining sleeve.
    1. Remove the door glass from the regulator clamp.
    • Discard the retaining sleeve.
  1. Support the glass, lower the glass and regulator to the lowest position.
  1. Position the lower part of the door glass top run outside the door.
  1. NOTE: To aid removal of the door glass, stand on the inner side of the door. Make sure the glass is removed from the inside of the door.
    Remove the window glass.
Installation
All vehicles
  1. ani_caut.gif CAUTION: Make sure vise jaw protectors are used.
    NOTE: Make sure that the retaining sleeve is central in the door glass.
    Attach a new retaining sleeve and retaining pin to the door glass.
    1. Position the retaining sleeve in the door glass.
    1. Using a suitable vise, press the retaining pin into the retaining sleeve.
  1. Install the window glass in the door.
  1. Attach the door glass to the regulator clamp.
    • Push the door glass firmly down to engage the retaining pin and retaining sleeve into the regulator clamp.
  1. Position the lower part of the door glass top run on the inside of the door.
  1. Close the window.
  1. Install the door glass top run retainer.
  1. Attach the watershield.
  1. Attach the door latch release handle.
  1. Connect the door speaker electrical connector (if equipped).
  1. Install the door speaker (if equipped).
  1. Install the side impact bolster.
  1. Remove the window regulator handle.
  1. Disconnect the door glass operating switch electrical connector.
All vehicles
  1. Install the door trim panel
Mar 11, 2009 | 2001 Ford Focus
CAN I USE ENAMELED CAST IRON POT ON MY NEW GE GLASS TOP RANGE
yes they can just cant slide them around cause of scratching but as far as performance they are fine
Dec 30, 2008 | GE Spectra JBP78 Electric Kitchen Range
How do you open the cook top
A glass top stove has a sealed top so you cant open it. Sorry for the bad news.
Nov 09, 2008 | Kenmore 79012 / 79014 / 79019 Gas Kitchen...
Dirt and grease between glass in oven door
i have taken the glass from the inside of the oven,and just cant get grease off, tried everything ,bleach,even lemon juice,
any ideas jimmy
Aug 01, 2008 | Ovens
Plastic melted on my glass cooktop
didi you try heating the burner slightly to soften the plastic a bit before trying to scrape off, cant see any reason why that wouldnt work, using a razor blade held flat will scrape just about anything off of the glass tops!
Apr 29, 2008 | Jenn-Air JED8430 Electric Cooktop
Top feeder of AL-1655CS
that is a dirty glass. The 1 inch or less wide glass on the left side of the machine has a very small spec on it.
You can clean it with a regular piece of paper and alcohol. Don't be afraid to clean it with some decent pressure.
The reason why you get the line in the feeder and not off the glass is that when you run a copy off the glass the lamp scans the immage, when you run through the feeeder the lamp parks under the glass and the movement of the document makes the print.
You may have some white out, or just some ink off an original on that piece of glass, but keep that clean.
Most people don't think that small piece of glass has a purpose, but it does. Sometimes the blot on the glass is so small you cant see it, and you need to remove that glass and hold it up with a piece of paper behind it to see the spot. It can be a very very small spot. But that is where your issue is.
Mar 10, 2008 | Sharp AL-1655CS Laser Printer
Frigidaire FEF366 Electric Kitchen Range Logo
Top Frigidaire Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Mike Carew
Are you a Frigidaire Kitchen Range Expert? Answer questions, earn points and help others
