Question about Elinchrom Cameras
I need to change the fuse on my Elinchrom 500 head....does it need a special key? I can't seem to open the holder which I believe is where the synch lead screws in. Help please! Am in the middle of a shoot... AManda
  • 4 Answers
I'm guessing this is way too late now- but it's not near the screw in point for the synch lead. It's to the left of where the mains lead goes into the unit-a black plastic slide out panel with a fuse and room for a spare fuse too. It's the reason I keep a swiss army knife in my lights bag-for prising the plastic tab out without breaking any finger nails by using the screwdriver tool!
Posted on Apr 22, 2011
Model light not working in d-lite rx 4
Make sure the bulb is not broken, they tend to burn out especially at the highest setting. Next, check the fuse (that is part #3 in the picture). It may need replacing. You can follow the directions in the manual, available from the Elinchrom website, to do that. Be sure to scroll down to the Manuals section, they have a lot of information available.
Feb 16, 2014 | Elinchrom Cameras
Hi when I turn my high beam on it blows my head lamp fuse? But when I use the low beam works perfect whats wrong and how can I fix it
This can be due to two reasons and must be checked.
1. A possible SHORT of wire or holder contacts in the headlight holder. remove bulb and check.
2. Possible that the wiring to the relay is faulty or there is a short here or in the main switch inside the handle. You need to remove the switch disconnect the lead and see if the fuse fails so as to confirm.
Aug 24, 2011 | 2005 kawasaki Ninja 500 R
Blown 100amp fuse under hood. main fuse. mazda 6 1993, cant get old fuse out
you need to remove the sides of the holder, when you do you'll see a small bolt on each side of the fuse,, these fuses have legs that get bolted down, I believe its a 10mm head on it,, take care when removing them, they disapear quickly as they are so small, and keep track of which wires attached to them go on which side
Jul 10, 2011 | Mazda MAZDA6 Cars & Trucks
I'm a mother trying to change the headlight beam fuse in my young son's 2007 mustang.....well, i see the place on the passenger side-I believe??--I opened it and don't see fuses??--Help
head lamp fuse is either under the hood close to battery or inside under driver side dash look at owner manual it will show you wich one cause some cars the sticker on plastic comes off
Jan 13, 2011 | 2007 Ford Mustang GT California Special...
How to use fxr 400 lights
You can see any you tube video to use Elinchrom FRX 400 lights, you can get some ideas.
Source: For your photographic needs; visit here
http://www.arihantdigi.com
Jul 28, 2010 | Elinchrom D Lite4 400 with S Monolight
Power Lock doesn't work
i have a 2001 sienna xle,,, the power locks fuse box is under the dash to the left of the seering wheel behind the change holder..... changing the fuse should reactive the locks....also u have three fuse boxes under the hood..good luck
Jan 09, 2009 | 2001 Toyota Sienna
Acer LCD (AL1917W)
After removing the back cover screws that you saw, ok, there is a screw under the stand holder. Remove the cover that covers the stand holder joints. you can remove it using a flat head screw driver, it is removeable only it appeares stuck to the back cover. After you unscrew, use flat head screw driver and carefully by pushing to the side of the LCD bend. Carefull you might break the cover. Good Luck.
Oct 03, 2008 | Acer AL1917W LCD Monitor
Cameras Logo
314 people viewed this question
Top Elinchrom Cameras Experts
Are you an Elinchrom Camera Expert? Answer questions, earn points and help others
