Question about Xerox Office Equipment & Supplies
ERROR MESSAGE: 1332843;29970 is displayed on our church's copier. What do i do?
    President:
  • 2,072 Answers
Do you have the model number?
Posted on Aug 27, 2010
Wat is an LSU error on a phaser 3200 MFP
Change the toner cartridge , i have many units phaser3200 and this is one of the problem , but only if the toner cartridge is very old and many time refilled , if not , change the Laser unit .
  1. Remove a misfed document if the copier displays a message reading "Document Jam." Lift up the document feeder cover and turn the roller to remove an Exit Misfed document. Lower the document feeder back into place and feed the document through again. If the document is jammed on the Input side, open the cover and gently pull the misfed document to the right and out of the feeder.
  2. Pull out the paper tray and lift the tray to release it from the copier if the copier displays a message reading "Paper Jam O." Remove the jammed document, and open and close the side panel of the copier to clear the error message.
  3. Unplug the power cord and plug it back in again if the copier displays a message reading "Fuser Error, Open Heat Error, Heating Error and Overheat." If the problem persists, call for a service.
  4. Remove the toner cartridge and shake it from side to side if the copier displays a message reading "No Developer Cartridge." If this does not do the trick, you may need to replace the cartridge. Pull the release latch to open the side cover, and open the front cover. Twist the cartridge locking-lever upwards and remove the toner cartridge. Insert the new cartridge and lock the lever into place. Shut the front cover and the side cover.
  5. Power off the unit and power it on again if the copier displays a message reading "LSU Error." A problem has occurred with the Laser Scanning Unit. If the problem persists, call for a service.
Jan 04, 2011 | Xerox Phaser 3200MFP/N Laser Printer
The error indicator is staying lit constantly on Toshiba e-studio
The drum counter reaches 25000 copies , it's time to change the drum and reset counter .
Enter the reset mode by pressing : # - * - c - * .
then press : 20 - start -01- start - CA - CA .
Hope this will help .
Feb 28, 2010 | Toshiba e-Studio162D Copier
Functioning problem with aficio 1033 or 2033,not sure, church cop
You must check the display for a code like SC-542 or something loke that.
Sep 17, 2009 | Ricoh Aficio 2022 Black and White Copier
ERROR CODE 805
If you take the back cover off the copier and look on a bid board that says "dc controller" it should have a fuse labeled (fu200). If this fuse is blown then it will cause this message to appear. See if that helps.
Aug 27, 2009 | Canon imageRUNNER 400S Copier
Our church has a Sharp Copier with an H4 error we do not have a manual and I do not know how to fix the error, can anyone help me?
It is the fuser, but sometimes it is just a false code. to reset enter buttons clr, exposure, clr, exposure, the display will blank, enter 14, press prnt button, then clr several times to get out and thats it.
good luck.
Jul 23, 2009 | Office Equipment & Supplies
CANON D860 copier display error message E0000
...usually the problem is in the fixing unit...
Jun 26, 2009 | Canon Office Equipment & Supplies
System error H4-00
H4 indicates a heating problem in the fuser. The roller never reached a specific temp. Make sure the fuser is free of any left over paper pieces (maybe from a paper jam). Check to make sure its clean.
Try reseting the the error in service mode.
To enter the test command mode, press the keys as
follows one after the other :
[#] key [*] key [C] key [*] key then enter 14 and press start/copy key. this clear error counter. make sure to restart copier afterwards.
May 19, 2009 | Sharp AR-168S Copier
Error message E 7
Try these steps to cancel the error, press the buttons continously
STEP1. Press CLEAR key then EXPOSURE key then CLEAR key then EXPOSURE key
STEP2. Then you are inside the simulation if the display turns OFF if not, do again step 1 until the display turns off.
STEP3.press 14 then press print button
Jan 29, 2009 | Sharp AL 800 Copier
Copier: Konica 3135 p.81 Insert key counter
you have to be in the service mode.To be exact the 25 Mode.To enter turn power off,Hold down the "2"&"5"keys while turning power on.Then press the "p"key.Change the number you see to 57. So now you should see P57in the display.Then change the value from 1 to 0,then press Print.That holds it in memory.Then just turn off and back on.
Oct 16, 2007 | Office Equipment & Supplies
ERROR ON iR1018J CANON COPIER
good morning i have one problem whit my copier machine IR 1018j
the copier display error system 247 .
anyone can help me?
Sep 18, 2007 | Office Equipment & Supplies
15 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Xeroxrep
Level 1 Expert
Philip Hughes
CheckitRight
CheckitRight
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
