Question about KitchenAid Architect KBRA20ERSS Bottom Freezer Refrigerator
Top refrigerator is not cooling. However, freezer works What needs fixing?Motor?
    Champion:
  • 245 Answers
Try the evaporator fan in the freezer. your fridge air vent could also be clogged! Rate me, thanks!
Posted on Aug 26, 2010
Hi, I have a Samsung refrigerator and the top part isn't cold enough and the freezer is working perfectly fine. I need help fixing the fan.
Check out these tips...they can help you figure out what is going wrong withyour refrigerator and why it is not cooling
Refrigeratornot Cooling or Fridge not Cooling
How to Defrost Refrigerator DefrostTimer Problem
WaterRunning in refrigerator from Freezer
Refrigeratoror Freezer not Cooling or Getting Cold
heatman101
Sep 03, 2011 | Samsung Refrigerators
THE TOP PART OF THE REFRIGERATOR AND THE FREEZER IS NOT WORKING (COOLING) ONLY THE BOTTOM PART ON BOTH IS SENDING COLD AIR. COULD IT BE A MOTOR?? THANKS,
heatman101
Aug 17, 2011 | Refrigerators
Freezer works, it's cool nolt cold in the refrigerator, fan motor doesn;t seem to be working
Check out these tips...they can help you figure out what is going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Oct 19, 2010 | Roper RT14DKX Top Freezer Refrigerator
I have a side by side refrigerator/freezer where the refrigerator is warm (not cooling) and the freezer only cools down like a refrigerator on top by the ice maker, and the bottom freezes. Can anything be...
Question one.... is there frost on the back wall ???? If yes then you most likley have a defrost problem.
If No ..... Make sure your fan is working in the freezer ((( this is called the evaperator fan motor )))) Open freezer door and listen for fan motor sound ((( if you have a light switch for the door press it in and listen )))) No sound 75% chance fan is bad.
One of these sound like your problem. Should be under $200 to fix
Sep 08, 2010 | Whirlpool 25.3 Cu. Ft. Side-by-Side...
My top freezer will not cool the motor is running but freezer stays hot ,the bottom is cooling ok
My guess would be that the defrost is sticking on...
Check out these tips...they can help you figure out whats going wrong with your refrigerator and why it is not cooling
heatman101
Sep 06, 2010 | Kenmore 64802 Top Freezer Refrigerator
Freezer has stopped freezing, the fridge isn't cooling anymore but motor still runs. how do i fix this?
it sounds as though all the refrigerant has leaked away possibly from a cracked pipe joint will need regas and new compressor.
May 09, 2010 | Frigidaire 20.6 cu. ft. Top Freezer...
Refrigerator section does not cool; freezer works fine
Check the settings first. They should be set to the factory settings in most cases. Otherwise check the back of your freezer to see if it is icing up, you may need to remove the back panel to see the ice. If this is the case the ice may be preventing the fan to circulate the cold air into the freezer and you will need a new defrost timer. However if there is no ice and the fan never kicks on you may need a new fan motor.
Jul 05, 2009 | Kenmore 73752 / 73754 Top Freezer...
Refrigerator stoped cooling
Ok, if the unit compressor will not run and just clicks on and then off, this will confirm a low charge state ad you will need to recharge this unit. the refrigerant level is low.
Purchasing a recharge kit and recharging the system will fix this issue.
May 15, 2009 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Inside refrigerator is warm - but freezer seems to be working.
friend .
you need to have check of your condenser.
either the condenser has gone down.so the gas is not there to cool.
see that u can hear the sound of motor running.if it works.
i am sure the cooling problem may be due to this.
Mar 28, 2009 | Kenmore 14.8 cu. ft. Top Freezer...
Maytag MTB2156GEQ Top Freezer not working
The compressor not working, relay switch on compressor not working Had repair man put new switch in .Last year put in new fan motor in freezer compartment the cool air was not circulating both problems made the fridge not to cool and drip water
Nov 30, 2007 | Maytag MTB2156GES Top Freezer Refrigerator
KitchenAid Architect KBRA20ERSS Bottom Freezer Refrigerator Logo
20 people viewed this question
Top KitchenAid Refrigerators Experts
John Tripp
John Tripp
vince
geob91
Are you a KitchenAid Refrigerator Expert? Answer questions, earn points and help others
