Question about Magic Chef CMV1000B Microwave Oven
I have( had) A magic chef microwave model MCD11E3W I must have had a power surge in kitchen refrig and oven turned off circuit breaker turned off.. All other appliances came back on but the Microwave,, NO POWER, unplugged etc moved plug nothing happens, I really have no extra money at this time, is there any solution that I did not do? If not I will try to save for a new one eventually,
  • Magic Chef Master
  • 17,129 Answers
It ispossible that the secondary transformer has failed which is the feed of the voltage for the processor timer/clock unit. So check this out with a multimeter and you can get to buy the transformer as it is a step down low voltage type., normally mounted on the processor board.
Check also if the fuse has blown if so replace.
I dont think there could be any further damage.
Credit me if this helps.
Posted on Aug 26, 2010
How to find the fuse in 2007 magic chef over the range microwave
It is fused through the house fuse/circuit breaker box.
Feb 09, 2017 | Magic Chef Microwave Ovens
WHERE IS THE FUSE LOCATED ON MY MAGIC CHEF MCO165UW MICROWAVE
Unplug your microwave and turn it around and remove the screws holding cover on and then remove the cover. Look for where the power cord goes into the back of the unit and follow the black wire from the cord to where it ends. It should stop an either a circuit board or a fuse holder. Make sure that you replace the fuse with the same amperage fuse as what you take out. You will find the amp rating stamped on one of the silver collars on each end of the fuse. Good luck!
Mar 02, 2015 | Magic Chef Microwave Ovens
Parts diagram for magic chef microwave model MCD790SW
Please go to this web address and read the service manual on how to put on the spring:
http://kitchen.manualsonline.com/manuals/mfg/magic_chef/mcd795sw_1.html
Jan 05, 2015 | Magic Chef MCD1110ST Microwave Oven
Where are the fuses in my microwave oven,?
Inside behind the display panel on a small circuit board.
Jan 01, 2013 | Magic Chef MCO160UB Microwave Oven
Have a magic chef mco160uw microwave. Had a recent
No! there is no reset, the power surge has more than likely damaged the keypad controller, and on the back is a circuit board that has the microprocessor with additional components that controls the vital areas of the microwave oven. If that is gone, it is cheaper to replace than to repair.
Feb 06, 2011 | Microwave Ovens
The light is off on my Magic Chef MCD11E3W Microwave Oven how do I replace it?
Since the owner's manual doesn't cover it, you'll have to remove the outer wrapper.
See these files:
http://wwww.microwavedisplay.com/safety.txt
http://wwww.microwavedisplay.com/disassembly.txt
Most bulbs can be matched up at hardware stores, home improvement centers, and places like Wal-Mart or even large grocery stores.
Nov 28, 2009 | Magic Chef MCD1311ST Microwave Oven
Micro ios totally black . Had to reset the breaker ; is that a clue/
It has a fuse inside. Check the door switches while you're in there. The one in series with the fuse can weld in the "on" condition and blow the fuse and/or the circuit breaker.
Jul 23, 2008 | Magic Chef MCD990W Microwave Oven
Magic Chef mco153ubf
I had the same problem. My Magic Chef, MCO153UBF Microwave had similar problems. The Magnatron, Cooling fan, Turn table and under hood lights were not working at all after hearing a pop sound under the control panel. Thought it was the fuse but the fuse was fine after testing and replacing. I checked the circuit breaker wired to my house and saw it had a break to my kitchen outlets so i flipped the switch to get back the kitchen outlets. Then I checked the microwaves Control Panel ( Printed Circuit Board) underneath and saw to traces were burnt. I soldered the two trace lines and the fixed the problem.
Nov 19, 2007 | Magic Chef CMV1000B Microwave Oven
Microwave stopped working completely
Fan turned on after cooking because a thermostat got to hot and tripped turning on the fan to try to cool the unit.  The unit went completely dead when thermal fuse tripped which is located above the cavity on the left side.
Oct 30, 2007 | Magic Chef CMV1000B Microwave Oven
Magic Chef CMV1000B Microwave Oven Logo
211 people viewed this question
Top Magic Chef Microwave Ovens Experts
William Miller
William Miller
Shehu Pro
Shehu Pro
charles
Are you a Magic Chef Microwave Oven Expert? Answer questions, earn points and help others
