Question about TruTech PLV16260 Television
Pretty sure I have a defective power supply board. The # on it is CGE00012408120. Any ideas who has it and how much? Thank you. Jesse Mann
    Champion:
  • 367 Answers
Any luck getting this fixed?Please let me know.Thank You very much!
Tyler
Posted on Aug 30, 2010
  • a1atelevisio Aug 30, 2010
    I'm waiting on the customers ok. Also I don't pay some concern to tell me where to purchase parts. Thats why you never heard back from me. Th ank you,
My Samsung LED 46" tv (UN46D6050TFXZA) won't turn on. The standby led blink twice 5 time in each cycle. all the capacitors on power board look normal.
In most of the case the problem is defective LED strips inside of the panel, please try this:
1. Unplug the cable between the main board & the power supply, apply the AC power to the power supply, if the back lights came on, the problem is defective main board.
2. if the back light do not come on, the problem in most of the case is the defective LED strips, you may get a new power supply module to test it again to make sure that the problem is not the power supply.
Aug 24, 2017 | Samsung Televison & Video
Heater was running and displayed ce code then it went to displaying water temp then stopped running and no display or lights on at all on the panel
There could be multiple things that could cause no lights to be on the panel and here are some of them, defective panel board, now power being supplied to the heater, defective power supply, etc. One way to resolve this issue is to get a schematic, volt/ohm meter and use it to make sure power is getting to the panel. If power is getting to the panel board then it is most likely defective. If there is no power getting to the panel board then you will probably need to call the Hayward technical support at 908-355-7995 and they should be able to help you figure this issue out. I hope this helps.
Please vote on this answer. Thank you.
Aug 24, 2011 | Hayward H Series Pool & Spa Heater 400k...
My Philips 42PF5421 tv keeps blowing the fuse. I have tried three in as many days but pop! I am replacing it with 3amp. ANy ideas?
the power board is what is my concern here.
Things to check
1. Buldging Capacitors
The power board is in distress if its poping that many fuses, I would just have you replace the power board.
Your full model number was not displayed is it a 21 D, B or C
you can find the part HERE
thanks and be sure to rate
Aug 20, 2010 | Philips 42PF5421 42 in. LCD Television
Hi my mother board is working but after 5 mintues it turn's off why its got 2.00gig of ram and anew power supply please help. Thank-You John
1. make sure that all motherboard fans are working especially the CPU fan. the motherboard shutsdown when it reaches a max temperature.
2. maybe your power supply is defective.
3. make sure that the CPU heatsink is properly seated in the processor
Jun 24, 2010 | Gigabyte GA-965P-DS3 (0818313003027)...
I NEED TO GET THE POWER SUPPLY OF THIS MONITOR. MAY YOU TELL ME THE FEATURES AND WHERE CAN I GET IT. THANKS
You should be able to get the power lead for your monitor from the manufacturer or online on auction sites for pretty cheap.
Hope this helps!
Feb 04, 2010 | Sceptre X9G Komodo IV 19" Flat Panel LCD...
E Machine ATX 250 -12E replacement PS
With emachine MOBO's you have to make sure you plug in the 20 pin plug from the power supply to the mobo. Also make sure all hard drives, cd/dvd roms, floppy drives, etc are turned on. Make sure the red switch on the PS is set to 115. Make sure the PS is plugged into a known working outlet. Make sure MOBO is properly in place with all grounds/screws in place and nothing metal near or touching board which may short it out.
You can review the E Machines PS replacement guide here for further instruction.
Good Luck,
Jesse
Jan 11, 2010 | Gateway Emachine Bestec ATX-250-12E PS...
InFocus LP120 that will not power on.
it project?..but in 10 sec.it off? im pretty sure that the lamp ballast of your projector is defective. but if deadset? check the power supply and your power cord. if still not working your power supply board is defective.
Oct 28, 2009 | InFocus LP120 / 1000 Lumens / XGA / DLP...
ProView PL926WBi
bad capacitors on the board, replace these and the inverters should get there power.
Dec 01, 2008 | Proview PL926WBi 19" LCD Monitor
Power board malfunction
There may be four (4) ways the repair could be done:
1. board - an entirely new power board maybe available from the monitor manufacturer or you can Google for OEM provider;
2. board - a refurbished/reworked board may be available, again you have to Google. Both 1 & 2 would require that you search for the actual PCB assembly number;
3. use the power supply board from an identical unit that has defective LCD panel, inverter or other problems/defect other than the PSU; and
4. component level repair - determine which components in the power supply are defective and needs replacement.
All of the above would require time. Time to look for the replacement board, time to determine which component to replace, time to do the actual repair.
Cost - depends on the tech. Of course board assembly would cost more to purchase but should be relatively easy to perform and therefore should not be expensive in terms of service. On the other hand, component level repair often would be cheaper in terms of parts purchases but would cost more in terms of service fees.
Taking into considerations the above factors, it may be more to your advantage to do the repairs yourself (no service fee). Still should you be uncomfortable on a DIY, then the cost of repairs might justify the purchase of a new LCD monitor instead.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
Mar 28, 2008 | Acer AL1711 17" LCD Monitor
Dyer
Jesse, does the door light come on? If not check the thermal fuse. You will have to open the top by pushing in on the two clips on each side. In back, on the right side of the heater you will see a thermostat and about 4 inches below the thermal fuse. Look at number 5 in the attachment. Makes sure to kill the power before going back there. You can either jump it out or ohm it out to make sure that is the problem. Part number for the fuse is LA1053.. Catriver..post back
Mar 11, 2007 | Crosley CEDC392JQ Electric Portable Dryer
TruTech PLV16260 Television Logo
Top TruTech Televison & Video Experts
Radames Pagan
Radames Pagan
Are you a TruTech Televison and Video Expert? Answer questions, earn points and help others
