Question about Mtd 22" Yard Machine Push Mower
It starts to studder like its not getting a good gas flow, then it dies.
  • Clyde Ottaway Aug 15, 2017
    Clean that carb. clears up a lot of problems
  • 1,631 Answers
Clean the carb.
  • Get a carb rebuild kit
  • Use a good carb cleaner
  • Use an air compressor, but be careful, turn down PSI
And check out the link to get the kit
Lawn Mower Parts Genuine MTD Parts for Outdoor Power Equipment
Posted on Mar 09, 2015
1995 Buick park ave dies at exactly 2000 Rpms
Have the charging system checked to make sure you are getting 14.25 volts when idle and everything on,blower on high and headlights on .if you are not getting at least 13.60 then replace the alternator,and or out put cable from alternator
Oct 31, 2014 | 1995 Buick Park Avenue
Why does my 1997 s10 truck keep backfiring and dying out or almost dying out
it is most likely a faulty injector if it has the throttle body type
Feb 22, 2013 | 1997 Chevrolet S-10 Pickup
Iwas driving my 1999 alero n it studdered for a second. I gave it some gas nand managed to drive one block before it died. I tried to start it but it won't start it turned over but that is all it did
Look for a light on the dash that says SECURITY after it doesn't start. These cars and many more GM's have had problems with the antitheft system. Parts in the system tend to fail and cause this "no start" situation. Symptoms range from stalling while driving, to starting for 1-5 seconds and then stalling. This link might help you if this ends up being your problem.
http://vatspasslockpasskeysecurityhelp.yolasite.com/
Dec 12, 2011 | 1999 Oldsmobile Alero
My 97 Legacy started to studder when stepping on the gas from a dead stop. It does not seem to studder at higher speeds. Do you thing the Fuel filter may need to be changed?
May 10, 2010 | 1997 Subaru Legacy
Truck died on me kinda studdering then just stoped
Not to be hurtfull,but, I would not use or listen to jiffy lube or a mechanic that discribes your vehicle issues as -gone. Find and use a good local repair shop. Perferably one with an ASE Certified Tech, that will be looking over your vehicle. Need more info or the vehicle. Could be a timing chain,fuel pump,worn out distributor etc.
Mar 12, 2010 | 1988 GMC Jimmy
96 Ford Explorer is studdering (misfiring) when going up hills
I have the same exact problem that just started immediately AFTER I got a tranny service where they changed the Trans Fluid, Trans Filter, Fuel Filter. Took it back and they say nothing is wrong with it. Took it to the dealer thinking I could get some REAL answers... they just told me to replace spark plugs, wiring & coil, for $900. Only studders when quickly accelerating above 40mph. I've check other forums, they say to clean the Mass Air Flow sensor. Haven't tried it yet. This seems the easiest before replacing spark plugs. Any other suggestions anyone?? Please.....
Oct 23, 2009 | 1996 Ford Explorer
2000 silverado will start but wont stay running just dies.
I also agree it sounds like a fuel pump issue. Its easiest to remove the box (6 bolts {need impact wrench} disconnect wires at plugs and disconnect gas filler hose) and lift box up. A hoist is easiest but 6 people can lift it easily. The fuel pump can easily then be replaced. Takes about 1 1/2 hrs. to do entire job this way and its so much easier!
Good Luck!
Jun 11, 2009 | 1999 Chevrolet Silverado 1500
1998 V70 Turbo stalls/won't re-start after engine hot
First change fuel filter and then change air filter. A turbo requires good air flow to spool-up correctly
Aug 18, 2017 | 2002 Volvo V70
Dies and has trouble starting.
need to have the alternator tested sounds like a bad voltage regulator.
Aug 28, 2008 | 1989 Honda Accord 4 Door
Mtd 22" Yard Machine Push Mower Logo
193 people viewed this question
Top Mtd Garden Experts
Roland W VanLue
Roland W VanLue
Tim Whalen
Phil Walker
Phil Walker
Are you a Mtd Garden Expert? Answer questions, earn points and help others
