Question about Foxconn 6100K8MA-RS Motherboard
VIDEO SIGNAL WHEN I SWITCH ON THE SYSTEM MONITOR NEVER DISPLAY ANY THING ANY MONITORS LIGHT JUST BLINK
  • 25 Answers
In u r cpu u can hear beep sound
Posted on May 08, 2008
Blinking on/off light.
Here's some tricks I would try...
1. Verify the monitor's power cord is plugged firmly into the wall outlet and the back of the monitor.
2. Verify the monitor cable is firmly connected to the computer and the monitor.
3. Verify that you have turned the monitor power switch on.
4. If the power light on the monitor is not on, test the wall outlet (plug in a light or something you know works).
5. If the power light on the monitor is not on, try a different power cord.
6. If the power light is on and yellow or orange or flashing, but nothing displays, or the display is incorrect, borrow a monitor from a friend. If that works, your monitor probably needs replaced.
7. Also, you could try your display on a friend's computer. If it doesn't work, your monitor probably needs replaced. If it works properly on your friends computer, the problem may be with your computers video output port, motherboard video chip (or video card, if you have one), or drivers. Good luck.
Jul 06, 2014 | ViewSonic VA1913w Monitor
My monitor no display and light is blinking
if the monitor light is blinking this suggests that, there is no display signal coming from the tower. This could be because of the following .
1. Bad video card 2. Bad video software
To check,where the problem is , power of the system tower and remove the power cord from the back of the tower. Press and hold the power buttoon for 10 seconds and the reconnect the power cord and turn the tower on. Check if there is any display or the status of the light changes from amber to green for even a small instance.
If the light changes to green and back to amber the video port on the tower is bad
Alternatively you can connect the monitor to another desktop or laptop to check if the same is working correctly.
Thanks for using fixya
Proton
Oct 13, 2012 | Computers & Internet
Blinking with no signal video displayed,also blinking picture after started windows
"no signal" means exactly that. You monitor is not receiving signal from your PC. Recheck the video cable on both the monitor and the PC, make sure they plugged in properly.. Also try another monitor if you have it, and if it works with that monitor than more likely you have a frequency sync problem. In this case, using another monitor that works, and try resetting the video to basic 60Hz. In Windows, Start->Control_Panel->Display. Change the display resolution to the lowest, apply the setting, then change the monitor back to the questionable one. If it still doesn't work, then your video processor on your monitor is bad; RMA it if it's still warrantied.
Blinking picture problem, try suggestion above.
May 30, 2010 | ViewSonic VX1935wm LCD Monitor
There is no display on the monitor screen. The amber light on the power switch keeps blinking uselessly!
The monitor requires service The monitor is not receiving a signal from the computer
Apr 15, 2009 | Computers & Internet
Green light continously blinking in samsung sync master 753s
1. cpu problem. why because of there is no signal output from cpu to monitor. the led blinking means there is no vertical, horizontal signals from cpu to monitor.
2. your monitor connected to another system.
3. neck board dry points.
4. cheak the display cable. 13&14 pins are horizontal, vertical signals.1, 2, 3 pins , R G B , 6 ,7, 8 pins R G B ground ( coaxiler cable used , meshed wire is ground )
Oct 13, 2008 | Samsung SyncMaster 753S 17" CRT Monitor
When it's turned on, the light on my monitor blinks but the screen doesn't display anything. Why might this be happening, and how can I fix it? Monitor will go on for a split second, then screen will go...
they normally turn off like this when they aren't receiving a video signal from the pc (same as when you turn off the pc). make sure that it is connected properly, and that the video output is activated. try disconnecting from the other monitor while its on and connect the problem monitor...if it still isn't working then there may be a problem with the cable or the monitor itself. Try another VGA or DVI cable. Hope this helps
Mar 29, 2008 | Computers & Internet
Green light goes on and off
Hi, aside from the blinking green light, does it display something like "No Signal", if it is it might be possible that it's not your monitor that is on the brink, it is possible that your computer isn't turning on and therefore the monitor cannot display anything since there is no video signal from the computer. Perhaps you can try plugging the Philips monitor to another PC that is known to be operational to check if it will display something. If it does then the other PC is not working, if again no display or green light blinks, then the Philips monitor would require service. You might have to have a qualified service personnel to have a look inside and further diagnose the proble. I wouldn't recommend that you try opening the monitor since it's a bit complicated. Hope this be of some use to you and pls post again how things turn up. Kind regards.
May 18, 2007 | Philips 150S (White) 15" LCD Monitor
Foxconn 6100K8MA-RS Motherboard Logo
89 people viewed this question
Top Foxconn Computers & Internet Experts
Alun Cox
Rommel Balcita
David
David
Are you a Foxconn Computer and Internet Expert? Answer questions, earn points and help others
