Question about Psygnosis G-Police for Windows
The Game G-Police doesn't recognize my USB joypad, even running on Compatibility mode. I'm currently using a generic USB PS2 controller adapter. I already tested it with a few old games such as Jazz Jackrabbit 2 and worked fine, but G-Police doesn't seem to recognize it at all.
Iomega floppy usb-powered external floppy drive on windows 8
Hi, Sounds like driver related problem to me. Try use this tool to update the drivers: Driver Update Software for XP Vista 7 8. Wish you best of luck.
Nov 30, 2012 | Iomega Floppy USB-Powered External Floppy...
Tip
Playing PS2 Games on a PS3 - Check Backwards Compatibility
Not all PS3 consoles have the capability to play PS2 games. Sony have removed PS2 compatibility altogether from the new PS3 slim and the later version PS3s only have limited capability to play PS One games.
This Tip is written to help you determine if your console is backward compatible for PS2 games.
First locate the model number of your PlayStation 3 system by finding the bar code sticker at the back of the console. Underneath the bar code you will see the 11-digit serial number followed by the model number which begins with "CECH".
Models that have PS2 game compatibility are first generation consoles and the versions are 80GB, 60GB and 20GB. These PS2 compatible consoles will all have 4 USB ports which is another useful identifier.
See below for a breakdown of the model numbers that are compatible with running PS2 games;
1) Model No: CECHE01 - These are 80 GB models with 4 USB ports. (Please note 80GB models with 2 USB ports are not compatible).
2) Model No: CECHA01 60 GB models
3) Model No: CECHB01 20 GB models
Another important factor here is the PS2 games themselves.
Even if you have one of these consoles, a PS2 game may run fine on one version say the 60GB but may not work on the 80GB.
If you have identified that you have one of these consoles and want to check if a particular game is compatible with it use the link below. You can enter the exact console you are using - then enter the PS2 game you want to play;
http://www.us.playstation.com/Support/CompatibleStatus
This will give a definitive answer on compatibility between a particular PS2 game you want to play and the actual console you have.
I do hope this Tip has clarified the issues for you.
Please help by registering your vote using the buttons below and many thanks for using FixYa.
on Dec 28, 2009 | Video Game Consoles & Games
My win 7 os cannot recognized the crusb10075 3com adapter.
1. Don't plug your WLAN USB adapter until setup finish and reset the computer
2. Download XP driver from 3COM in below link... make sure to select the correct one depending on the serial number of your adapter (starting with 0100/0200/0300)
http://www.wireless-driver.com/3com-officeconnect-wireless-54mbps-11g-compact-usb-adapter/
3. Double click and it will automatically unzip and may ask you again after unzip use recommend settings and click yes to use recommend settings and click yes to all to overwrite again the folder unzipped again but if didn't ask it is OK.
4. In the unzipped folder right click on the setup file and click properties then go to Compatibility tab. InCompatibility mode click "Run program in compatibility mode of" then chose Windows XP (Service Pack 2) and OK.
5. Click setup now and after installation finish restart your computer.
6. After reset plug you USB adapter and will take some time to install the driver.
Apr 20, 2011 | 3Com (3CRUSB10075) 802.11g/b Wireless...
Performance monitor extencion dll for clr.this can only be used on windows nt.yahoomessenger-could not load on non-windowsnt sistem
Run properties of the file (c:\Program Files\Skype\Phone\) Skype.exe, (e.g. right mouse button on the file in Explorer) and uncheck the "Run this program in compatibility mode for:" option in Compatibility tab. Known fix is to choose Run this program in compatibility mode for Window 95.
Mar 02, 2011 | Amstron LG Electronics LS50-AGHF1 Laptop...
MY WEBCAM INTEX IT-305 WEB CAM IS NOT RECOGNIZED ON MY USB PORT EVEN AFTER INSTALLING THE DRIVER. ERROR ON CONNECTING IT TO USB PORT IS WINDOWS CANNOT RECOGNIZE THE DEVICE CONNECTED TO THE USB .
It sounds like you have a USB port(s) problem. Did you check them in Device Manager to see if they work ok? Did you try a different usb cable? You surely need Windows Service Packs installed in order to get USB 2.0 compatibility and speed. Without the service packs you will only get USB 1.1 compatibility and speed. But of course, the USB controller must be a USB 2.0 Controller before it can attain USB 2.0 compatibility and speed. There is no software that will make a USB 1.1 controller a USB 2.0 Controller. If your current USB controller is only 1.1 compatible, you will need to obtain a high speed USB 2.0 controller card or bus card. The easy way to tell if the current installed usb controller is 2.0 is to open Device Manager and click the + button next to USB Controllers. If you see the word "enhanced" anywhere beneath, then the controller is a USB 2.0 controller.
Sep 09, 2010 | Computers & Internet
External keyboard doesn`t work
hiiii ther
how r u ??
1st i don't recomand teh vista to ur machine
it's not VERY comabtble even acer co. say it's ok
ur problem it could be one of two reasons
1 the adapter is makeing a conflict
2 the vista not recognizeing the USB device
so 1st try to make sure that the vista recognize USBs device
than try to change the adaptor
if u need any further assistance email me
u take care and have fun
salammmmmm {bye in arabic }
p.s rate me thanks
Nov 20, 2008 | Acer Aspire 7720 Notebook
Ps3 joypad doesnt respond
Your controller may be broken. These controller dont last forever even though they dont use batteries. Sony says the controllers will breakdown in a few couple years. Hope i helped you out
Aug 01, 2008 | Sony Playstation 3 (PS3) Console
Mad cats mc2 with pedals
The easiest way to do this is to go online and order a PS2 controller to PC adapter on amazon.com or some other site. I have a Madcatz MC2 and a Ps2 controller to PC adapter (a cheap one -_-") and it works okay (I'm having a lot of trouble with the pedals though).
May 28, 2008 | Mad Catz MC2 Universal (6320) Wheel And...
PLAY PS2 GAMES ON PC
Ok, you want a full procedure here it is. First of all if your computer does not meet the following specs stop reading cuz you'll be wasting your time trying to get it to work and will be very disappointed by the quality of game play:
Minimal Specs:
AMD 64 or Intel Pentium 4 (VM Build will not work with non SSE2 CPU's)
512MB of RAM
Pixel Shader 2.0 supporting card
Recommended Specs: (For reasonable performance in many games, but not all)
AMD64 X2 or Intel Conroe E6600+ (Multi Threading is supported in PCSX2)
512-1024MB of RAM (more RAM allows for VM mode to be stable)
Pixel Shader 2.0 supporting card (recommended GeForce 6600-8800 or equivalent ATi card)
Possible Ideal Specs:
64bit OS such as Vista or winXP64, to allow for future support of 64bit recompilers.
Future AMD or Intel Quad Coremaybe needed, but currently the support of 4 threads is not handled byPCSX2, and the effect of threading out EE / VU is not yet known.
We don't forsee you requiring a GPU more powerful than the current generation of cards, up to and including the nVidia GeForce 8800.
Also note, if if have just a standard AMD Athlon (non64) don't even bother trying to run this emulator. It does work but is very very slow.
If you meet at the very least the minimum specs go here and download PCSX2 Binary. .::CLICK HERE::.
This is the BEST PS2 emulator currently on the net. There is NONE better.
Next: as with any emulator you need a BIOS in order to use it. There are several methods to getting a PS2 BIOS. You can google "PS2 BIOS download" or check torrent sites like this one .::HERE::.and do a search for "PS2 BIOS". At any rate, get 1 or many BIOS(one for each different area ex. Japan, US, Europe)
Next: Un-7zip the PCSX2 7zip. Take the BIOS.bin files you downloaded and place them all in the folder, "bios" in the PCSX2 folders you unzipped.
Next: You'll notice two icons that look the same one is called pcsx2.exe and one is called pcsx2t.exe. I have had no luck getting anything to play worth a **** on pcsx2.exe. I use pcsx2t.exe. According to the person who made this program, pcsx2.exe is a faster emulator version, but he says that AMD people have had better luck using pcsx2t.exe. So, if your computer has an AMD processor try the pcsx2t.exe first. But keep what I said in mind cuz you may have to use the other one instead. In either case, choose one and run it.
Next: When the program opens, it will have to be configured. Look at the top of the program and click the, "config" menu option. Next click the, "configure" menu option. You are now faced with several configuration options. I'm not even going to bother explaining what each option does, go .::HERE::. it explains what everything does. 9 times out of 10 when pcsx2 won't work, it's cuz of a bad configuration. SO MAKE SURE YOU READ THAT WHOLE PAGE.
As you can see there two ways you can load a game. Either by turning the game itself into an ISO or from using your DVD-ROM drive.
As far as controlers go, you can purchase USB PS2 look alikes from most computer stores. You can also get PS2 to USB converters that you can plug directly into your computer. And there is even a SIAXIS driver floating around on the internet that will run a PS3 controler as if it was a standard computer game controler. If you don't have money for a controler or what not just use the ZeroPAD option under, "First Controler" and start binding keyboard keys to assigned slots.
As with any emulator nothing is perfect and this will not play every single PS2 game out on the market. However, this is the most current emulator in production atm and is the furthest along. When you get everything up and running you'll want to look ..::HERE::. at the compatibility list to make sure your game is registered to even work with this emulator.
Hope that helps,
L8er
May 22, 2008 | Sony PlayStation 2 (PS2) Console
Pac man
you can bye ps2 joypads from any games shop or directly from sony just make sure it usb compatible
Oct 13, 2007 | Sony PlayStation 2 (PS2) Console
Psygnosis G-Police for Windows Logo
96 people viewed this question
Top Psygnosis Video Game Consoles & Games Experts
James Wishart
Are you a Psygnosis Video Game Console and Game Expert? Answer questions, earn points and help others
