Question about Siemens SpeedStream Modem (4100) (SS4100)
The on/off switch won't turn on.(I've got it taped on now...)
  • 3,866 Answers
Its very possible you got a bad pad on the circuit board on this modem, the pad is not being pressed down and Tape would sure help this but never long term, /The modem would cost to much to have repaired, I would if i where you is to have the service provider get you a new modem or you can find these cheap on ebay. Its not worth the money to fix as you can get these for under $12 bucks on ebay.
thanks for your question please be considerate and leave feedback and ratings for your answer today.
Posted on Aug 26, 2010
No Audio When Importing from Canon ZR960
Do you have the leads plugged in correctly ?
Jul 04, 2017 | Canon ZR960 Mini DV Camcorder
Kenwood krf v73000d mute won't go off
Is there a "tape monitor" button by chance? If this is turned on, it will mute your audio as well.
Mar 22, 2013 | Audio Players & Recorders
Repairing Gas line filler tube
Simple, don't try to put gas in it. Actually you could get a siphon hose in past the filler tube and past the leak, putting gas in that way. Temporary? If at all possible to get a roll of tape around it where it's situated, I might try duct taping the **** out of it. I wouldn't waste my good Gorilla Tape on it, though. It won't really seal anything, might just stem the flow a little.
If it is cracked on one side, you could loosen the hose clamps, and see if you could turn the hose where the leak is on the upper side. That way it won't leak as much. I've dealt with this before. Nothing really works! Just wait for the new hose, preferably sooner. Keep your tank low with gas (1/4 full) and you be fine.
May 24, 2012 | 1999 Isuzu Rodeo
My Bose QC15 won't turn on, I've already tried replacing the battery. What could be the problem?
Mine did this as well, totally frustrated I kept on rapidly switching them on and off, and eventually it just switched on!
Mar 25, 2012 | Bose QC15 Headphones
I have a 2004 Silverado 1500. The rear lights won't turn off, pulled all the fuses associated with lights and they still don't turn off. In addition my right turn signal doesn't flash, both the...
Not sure, but I've heard a bad hazard switch can cause strange problems.
Also, if your truck has a body control module that controls interior and lights, that may be your problem, too. Good luck.
Jan 26, 2012 | 2004 Chevrolet Silverado 1500 Crew Cab
I put a tape in and it keeps flipping sides without playing and pops out and says Error. It even does it with a CD-Cassette Adapter. Before the Cln came up and I pressed on the eject button and that...
Cassette decks have sensors on the reels which tells the deck when the tape is at the end. When the reel stops the deck switches the direction of the tape and sometimes the position of the head(depending on the deck design). Most common problem is the tape is hard to turn, or the deck won't turn it ( deck thinks it's at the end, click, still won't turn, click, won't turn, click) you should fast forward and/or rewind your tapes from start to finish once in a while to keep them lined up(narrow spool/less friction), you shouldn't have to but it works. BUT,...your problem sounds like a slipping or broken belt/or dirt causing the problem. Take the deck out to have a look and clean the capstans(rubber rollers)belts,heads with alcohol and a Q-tip while your at it. Dirt's usually the main culprit and if you do have some other problem, cleaning it is always a win/win (It will also sound better clean)
Sep 20, 2011 | 1995 Buick Regal
Tape door won't close i get error message reattach power. i've reset , used different power supply, still tape door won't close any goo ideas? chuck
big problem with sony as you can see im a pro tech but had the same fault with mine. and it broke my heart 4 weeks old and sony dont give a dam ironicly a mate told me slam my fist under the bottom and it will close after hrs of trying to fix it i took his stupid advice and after many hits it closed and worked great for a few weeks
Sep 12, 2011 | Sony Handycam DCR-HC96 Mini DV Digital...
1995 geo tracker won't start. I've replaced everything except the ignition switch. It used to click when i turn the key, now it won't even click.
DISCONNECT YOUR BATTERY AND RECONNECT, THIS SHOULD RESET THE BRAIN.
ALSO...WHEN YOU TURN THE KEY, LISTEN TO HEAR IF YOU CAN HEAR THE FUEL PUMP COME ON...IF NOT, GUESS WHAT? HOPEFULLY NOT!... BUT,YOU MAY NEED TO REPLACE THE FUEL PUMP, IF YOU CAN'T HEAR IT WHEN YOU TURN THE KEY, AFTER YOU'VE RESET THE BATTERY!
HOPE THIS HELPS!
Aug 30, 2011 | Geo Tracker Cars & Trucks
Tv won't switch to "tv"
Your T.V. is programmed to store the last input you've selected. You have to manually switch it back to your T.V. channel input after each time you switch it to HDMI or any other input even when you turn it off. The "Source" or "Input" button on your original T.V. remote will change this.
Jun 24, 2011 | Vizio 42 in. LCD TV
Siemens SpeedStream Modem (4100) (SS4100) Logo
212 people viewed this question
Top Siemens Computers & Internet Experts
Prashant M
Prashant M
john smith
Are you a Siemens Computer and Internet Expert? Answer questions, earn points and help others
