Question about Frigidaire FEF326 Electric Kitchen Range
My stove, oven and digital panel has no power unless I turn any knob on for my elements but there's no heat and as soon as I turn the knob off no power anywhere???
5 Suggested Answers
watugot
  • 290 Answers
SOURCE: Element Problem
I believe the range you have has a relay board mounted on the rear of the unit. The element switches tell the relay board when to turn the element on and off. You probably have a stuck relay on this board.
This type of set-up is fairly new and not a whole lot of people have worked on them. They will throw a good repairman for a loop the first time he tries to diagnose one.
(I speak from experience)
Posted on Oct 27, 2007
SOURCE: oven elements dont work / stove top works fine
Repair person also shut the power off before replacing the fuse...
Posted on Dec 20, 2007
SOURCE: GE Profile Electric Stove, no heat, looks like it needs a reset
my oven doesent work and my key pad is locked
Posted on Sep 05, 2009
SOURCE: frigidaire model fef336ece.oven and broiler wont
thermostat possible open check not sure if this model has a resettable or not
Posted on Oct 21, 2010
My stove poped and went off. I tripped the breaker and now the oven will not heat. Neither the top or bottom unit.
First I would look at the heating element in the oven and make sure it is all in one piece. there are usually one on the bottom and one on top. sometimes they will burn apart and short out to stove. if they look ok then do a quick check, I would turn off all knob on the stove top and oven. then try to reset the breaker. hopefully it resets ok. then turn on one at a time and see which burner or oven element has a short. when you find the bad burner or stove element it will trip the breaker again.
hope this helps
Jan 09, 2012 | Kenmore Kitchen Ranges
I have a Simpson electric oven with stove top elements, and one of the burners will only cook at the highest level, I cant figure out how to change it, any suggestions?
You need to change the "Simmerstat", take the model number to your local electrical parts supplier/parts counter at your local stove retail shop that sells Simpson stoves and ask for one for that model, make sure you get the right one for the position as some control a single element and some control dual elements.
*** TURN OFF THE WALL SWITCH AND ENSURE NO POWER IS APPLIED TO THE STOVE BEFORE PROCEEDING ****
Remove the upper back panel of the stove. Swap wire for wire of the old simmerstat to the new one, remove the knob from the old Simmerstat, undo the nut securing the simmerstat in the oven control panel and discard, fit new one, secure, fit knob, fit back panel, turn on wall switch and test.
Some countrys/states require registered electricians perform this task on electrical appliances so you must ensure you can do this legally before you start and take the relevant safety precautions and don't electrocute yourself.
Apr 13, 2011 | Ovens
Onece the range selector is turned on the light comes on but soon goes out, if you move the selector a little the light comes back on, this stove was made around 1952. Thank You, Dave
Are you talking about the oven temperature control? When turned on to the selected temperature the oven indicator will light and the element will work. When the oven reaches the desired temperature the power will shut off to the element and the indicator light will go out. When the oven cools slightly the indicator light and the element will again turn on. When it does turn off and you turn the knob slightly to increase the temperature the indicator light and element will come on again as you are asking it to heat to a higher temperature. This is normal oven operation.
Mar 10, 2011 | Kitchen Ranges
Stoves 720 EF Electric Double Oven Model No 059040415 -when you turn the grill knob there is no light and it doesn't do anything at all - the grill is not working. However, the element must be working as...
First things first. The oven element is totally separate to the grill element. The clock has to have a time set for either the top or bottom oven to work, whereas the grill will work without the clock being set.
The control knob for the top oven is the ONLY control that will turn the top oven lights on, the grill does not turn the lights on. ( If you want to watch your toast, you have to turn the top oven switch on to the first setting as well as operating the grill control).
To prevent the grill being operated with the door shut, there is a micro-switch on the door hinge that allows the grill to operate ONLY when the door is down. The grill control also does not illuminate unless the door is down. There are two options on the grill control - right or left. One way is the inner element only and the other is both inner and outer ones.
So if you have done all that and it still doesn't work, then the micro-switch could be faulty.
Best of luck
Nov 23, 2010 | Stoves 720EF Electric Double Oven
Kenmore ultrabake lights up when stove top is on but wont heat up
Hard to know...First thing I'd check is the power supply to the unit.  Turn off both breakers.  Check wiring all the way through for tightness.  Turn both breakers on.  Next, you'll need to check the elements for continuity...with the power off.
Nov 28, 2008 | Kenmore 40494 / 40495 / 40499 Electric...
Display is blank, no heat no bake
The oven control panel has failed. For more tech help with this issue and a place to order parts I suggest you go the link below, it is where I go for parts and help. You will need to model number available. Appliance Parts Lawn Mower Parts Heating Cooling Parts 365 day returns
Jun 28, 2017 | GE Monogram ZET3058SHSS Stainless Steel...
Stove will not turn on
The power connections to your stove or the wiring at the plug are incorrect. The neutral connection is missing (White wire)
Jun 26, 2008 | Frigidaire FEF376 Electric Kitchen Range
Wierd problem with ge eletric oven / no heat
check the electrial connection at the back of the range, also check the breaker
Mar 31, 2008 | GE JKP15 Electric Single Oven
Oven stopped working while cooking a meal
it sounds like it burnt one of your main wires in the back of range. by turning a knob on you are getting a feed back. turn the power off remove back panel take a visual check of your wiring.
Nov 23, 2007 | GE Profile JKP18 Electric Single Oven
Frigidaire FEF326 Electric Kitchen Range Logo
50 people viewed this question
Top Frigidaire Kitchen Ranges Experts
Ismael Rodriguez...
Paul Carew
Justin Duby
Justin Duby
Are you a Frigidaire Kitchen Range Expert? Answer questions, earn points and help others
