Question about Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+
My garage door jumps about 3 or 4 inches and then moves smoothly when opening. I have disengaged the opener and run the door by itself and it runs smoothly. What I have noticed is that the top of the door flexes when the door is opening. It is like the opener is pulling the door backwards instead of up. When I open the door by lifting at the bottom this does not happen and the door run smoothly. Any assistance in sorting this out will be much appreciated. Thanks.
  • John Soogrim Aug 27, 2010
    If the issue is the mounting of the motor itself why does the door flex? I did not mention that this is a belt drive unit not a chain drive one. Should the door have a metal brace across the top? I have seen those braces on some doors. My door is a 4 section wooden door.
  • 3,153 Answers
This is not uncommon on many openers.
When installed some contractors just use minimum bracing for the motor unit.
I tend to add a small amount extra. If you have the motor unit mounted directly to your garage roof then it should be fine but i that case I would be checking the gear chain wheel to ensure it is secure to the shaft
Do not put your fingers anywhere near the unit whilst testing and go for a visual inspection only !
Next ensure power to the unit is off and try work the gear to check for any play. If there is play then check the screws that lock the wheel to the shaft and the motor mounts
If it is suspended from the roof then add extra bracing on the diagonals to firm up the drop legs or even an extra brace out from the rear of the unit.
There are two schools of thought on this practise of extra bracing and it is not always recommended but from practical experience and long term usage I have found it to save money.
Bob
Posted on Aug 27, 2010
  • Project NOMAD
    Project NOMAD Aug 27, 2010
    The door should not really flex especially in the middle as this tends to try and pul the guides inward slightly.
    That would cause the small **** you see as the drive has to pull a little harder to overcome the bit of resistance
    I have seen older (better built) wooden doors that DONT need a top brace simple because they used better materials.
    Most GOOD metal doors dont need them either as the way the metal is folded give it a strong edge from which to pull
    cheaper wooden doors should have either a metal top rail to prevent centre flex or I have even seen people use a hardwood 2x3 screwed to the top.
    stand close to the door and operate the door and if you see any flex near the middle then YES get a top rail or devise one yourself. You may have to watch it a few times to be sure and also watch the wheel rails around the curve and see if they are tending to pull in a little.
    A possible temporary fix is to re-grease the curves with somthing suitable for your climate.
    If that helps at all then it is most certainly the flex that is causing the problem
    With belt units it is also possible that the belt has gotten a stretch point and there is a small amount of slack and some units can operate a little quicker on the uptake until the extra belt is taken out and this too can cause a **** but it is unusual to see that except on cheaper ones.
  • Project NOMAD
    oops forgot to mention why good mounting is important.
    If the drive can be pulled toward the door slightly then it has to work harder to start pulling up the door.
    That too can cause a flex on the door in a tug-o-war fashion the mountin will normally win but only after it has given way a little.
    Watch each part of the system to see where it moves and if the mounting moves fix that FIRST its also the cheapest fix to try as all you need is a couple of bolts and some more universal angle.
    If it is dropped from an extra high ceiling then add a rear diagonal from down near the drive at least 45 deg out to the back of the garage.
    Just did a twin garage with 12 foot ceilings and had to put twin diagonals on both drives or else the mountings would have just pulled thenselves to the door.
    I have presumed you checked the tracks and that they are running parralel and dont have any dings etc in them and they are mounted firmly
Hi there my merlon garage door lifer will not lift the garage door , the motor is running but the belt is not moving , can you help me with this ? Thanks chris
It's probably a stripped gear caused from an unbalanced door. The door itself has springs to counterbalance the weight. Depending upon how many cycles your door goes through in a day will determine how long they'll last. Springs SHOULD Last You Between 5 To 10 years. Sounds like u need work. OR....the opener is disengaged from the door. Pull cord for black outs. Good luck.
Jan 04, 2016 | Building Materials
Tip
Inspecting a garage door opener.
<p>Use the pull cord and disconnect the opener from the garage door. <br /> <p>Operate the opener and let the carrier slide back away from the door. <br /> <p>Is the carrier moving smoothly when disconnected?<br /> <p>Operate the opener into the down position, does it run smoothly? <br /> <p>Next, lift the door by hand from the bottom to the top. Is it moving smoothly?<br /> <p>Run the door down, ensuring that it moves smoothly. If not, lubricate the axles of all the rollers on both sides of the door.<br /> <p>Check the cable pulleys at the top sides of the door channel, lubricate them as well. <br /> <p>Are the two cables in all four of the pulley grooves?<br /> <p>Are the cables hooked properly to the bottom of the door?<br /> <p>Now, connect the opener to the door and try it.<br /> <p>After checking those things, there is an "up force" and a "down force" adjustment on the opener, try increasing the whichever is needed by by turning the adjustment in the direction of MORE force.
on Jan 09, 2011 | liftmaster Chamberlain Garage Door Opener...
It takes 4 or 5 attempts to open first 2 or 3 times it opens a couple of inches then closes light on control flashes red then 2 amber back to red then on about the 3 or 4 attempt it opens a couple of feet...
If you release the garage door manual does it move smoothly up and down or is there some resistance if so your rails my need cleaning or spray oil or the rollers my need replaced if ok then check your chain on the track is to loose and needs adjustment
Mar 24, 2015 | Building Materials
I have a craftsman 3/4 hp 315 mhz garage door opener model 13953990ds when ativating it to open it only moves 6 to 8" forward and back and stop. i have tried all steps in the manual can get it solved
If you've readjusted the opener, and it still isn't working, you need to have a trained door technician come out and adjust the tension on your springs. To determine this, pull the red release handle to disengage the opener from the door, and try to lift your door by hand. You should be able to move the door easily, and it should stay at the half open point without falling or rising. If the door is hard to move, excessively heavy to lift off the ground, or will not stay open, the door itself is the culprit. If the door is fine, the opener will need to be serviced.
Sep 02, 2013 | Sears Craftsman LiftMaster Chamberlain...
I have a 1/2 HP Craftsman Garage Door Opener (41A5389E 11/04) that, when opening, stops about 18 inches up and reverses. When I disengage the opener from the door bracket, the door operates smoothly. The...
indicates that the door is not running freely or there is a problem in the control board
what is happening is that the sensor is registering and overload situation( car in the road or already up or jammed and is reversing off the object
mat need a simple reprogramming
call the technician to diagnose the fault
Aug 20, 2017 | Kitchen Ranges
Have replaced drive gear on Craftsman GDO. Everthing engages and chain moves but door only opens 3 inches are so. Have ajusted opening cointrol on side to max and only 3 inches. When I unlatch GD from...
Loosen the chain enough that you can remove it from the pulley on top of the motor unit. Now with the door closed run the motor until the pulley turns in the clockwise direction and stops. Put the chain back on the pulley and tighten. You may have to tweak the up and down limits now.
Nov 14, 2009 | Sears Craftsman LiftMaster Chamberlain...
Door starts and stops immediately i sprayed the tracks and it worked for about a week but now it's back to starting and stop[ng prematurely
With most garage door openers, you can look under the light bulb cover and you'll find two numbered knobs. These knobs set the motor torque/speed ratio. Basically, if the door is really smooth having the knob turned down will make the motor go faster. Turning the knob up will give the motor move "oomp" but it will move a little slower. One knob adjusts the power going up and the other knob adjusts the power going down. This basically depends on how good the springs are working on the door itself. So just adjust the knobs until the motor is running each direction "comfortably".
Nov 01, 2009 | Sears Craftsman LiftMaster Chamberlain...
Craftsman garage door opener 1/2 hp will not open door
It sounds like your chain is out of sync with the limit switches. Loosen the chain enough so that you can remove it from the sprocket on top of the motor unit. Now run the opener until the sprocket runs counterclockwise and stops. Now with everything attached and the door in the open position replace and tighten the chain. You are now in sync. You may need to tweak the up and down limit controls which are on the side of the motor unit.
Aug 16, 2009 | Sears Craftsman LiftMaster Chamberlain...
Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+ Logo
677 people viewed this question
Top Sears Building Materials Experts
Glenn Mayer
Glenn Mayer
Mike
Are you a Sears Building Material Expert? Answer questions, earn points and help others
