Question about Maytag Portable Air Conditioner M6P09S2A
Aur conditioner goes from cold to hot while should be on cold. Air conditioner is vented, cleaned, etc.
  • 1 more comment
  • reid_dianese Aug 26, 2010
    Air temp in room is 85 degrees. Unit is set for 65 degrees and compressor goes on and off at about 10 minute intervals. Is this a faulty thermostat or what?
    Where in Sacramento can I buy parts?
  • reid_dianese Sep 01, 2010
    Thank you for your help. Things better but not fixed totally.
  • Maytag Master
  • 17,129 Answers
If the compressor is running and you are not getting the cold air to blow or the cooling pipes are not cold after a good begining then it is possible that there is low gas pressure.
If so refill gas and check for proper gas pressure.
However if the compressor is shutting down after blowing cold then the pressure limit switch might be faulty and is acting in advance. try to overide to check the running of the comrpessor.
Also if the thermostat is also detecting wrong or is malfunctioning ,the same faults can be seen.
So check in this order and confirm..
Posted on Aug 26, 2010
  • Donald DCruz
    Donald DCruz Aug 27, 2010
    Please increase the temp settings and see if the compr runs for longer time. If so the thermostat can be defective but you can set the temp up for the time being for the compr to run. But if not the timer is having the fault.
  • Donald DCruz
    Please check with some old stores if one can be salvaged of the similar type but only if the higher settings are not acting.
Why when I start my car is there an odor coming from vents that smells like something is burning, and my Air Conditioner still blows, but it only blows out hot air. 2008 Chrysler Sebring. Help?
have an accredited ac shop as an ac cannot produce hot air only cold air so that means that the ac is not working (leaks low on gas etc). The hot air is from the heater in the car and the smell is probably wire overheating or the resistors are burning.
Aug 16, 2014 | 2008 Chrysler Sebring
Water gurgling in heater, heat is warm, air is very light coming out of the vents, sometimes air goes cold then comes back warm.. a bump will make it go cold
it's look like the a/c evaporator is block by dirt,oil look at it ..It should be clean as this one
hope it helps
Apr 04, 2014 | 2000 Chevrolet Blazer
99 air conditioner switch
im not sure what fails here.
no air, from all vents. no cold air , no hot air.
tell me what you want.? hot or cold air. (or defrost)
does the blower blow on high?
did you check all fuses. 1st.
if real serious. on DIY repairs, try the FSM.
or a great subs. alldata.com
Jan 01, 2014 | 1999 Toyota Camry
The heater in my 1999 Land Rover Discovery Series 1 won't blow cold.
As per your problem mentioned.There are few solved help links to troubleshoot these problems.Go through the list and Click the link below:----
Air conditioner blows air but not cold air http://repairhelpcenter.blogspot.in/2012/07/air-conditioner-blows-air-but-not-cold.html
Car overheats and Air blows hot at idle? http://howtobyme.blogspot.com/2011/11/car-overheats-and-air-blows-hot-at-idle.html
Heater blows cold? http://schematicsdiagram.blogspot.in/2012/02/heater-blows-cold.html
Heat blows cold on drivers side and hot on passenger side? http://schematicsdiagram.blogspot.com/2011/12/heat-blows-cold-on-drivers-side-and-hot.html---------- Hot air on the driver's side vents only? http://repairhelpcenter.blogspot.com/2012/01/hot-air-on-drivers-side-vents-only.html
2005 Chrysler PT Cruiser: A/C Blows Warm? http://whoisbyme.blogspot.in/2012/06/2005-chrysler-pt-cruiser-ac-blows-warm.html
1992 Toyota Camry: A/C Control light Flashing and A/C not Blowing Cold? http://technoanswers.blogspot.in/2012/04/1992-toyota-camry-ac-control-light.html
No heat, blower blows only cold? http://technoanswers.blogspot.in/2012/02/no-heatblower-blows-only-cold.html
These will help.
Thanks.
Nov 22, 2012 | Cars & Trucks
Left Vents blow warm/hot air when calling for cold air
Usually a sign of a faulty blend door under the dash.
The blend doors direct air thru the ac and heater core along with the upper and lower vents.
Sep 12, 2012 | 2009 Chevrolet Silverado 1500
The air conditioner is blowing hot air, there is no water to drain
if it is also blowing cold air out of the other vents you need to vent the hot air its blowing outside
Sep 30, 2010 | NewAir ACP-1000E Portable Air Conditioner
I have a 2004 Chevy Tahoe with dual zone air conditioning plus rear air conditioner. My problem is on the 2 driver vents only it keeps going from cool air to hot air. After you drive for a while it is all...
If the truck has a dual zone temperature control in the center console then this is most likely your problem as alot of times when these go bad the think the driver side is too cold and turn the heat on to warm it up thus giving you warm air through the vents on the driver side.
May 27, 2010 | Heating & Cooling
Stand up airconditioner
To your question the answer is YES, generally vented to the outdoors through a window. Generally speaking there are two hose connections for cooling the refrigeration end of the A/C. one should supply cool air from outside and the other should discharge the hot air outside. If not vented to the outdoors your build heat instead of cooling.
May 17, 2008 | Maytag NMPEB08F2A Air Conditioner
Heating & Cooling Logo
359 people viewed this question
Top Maytag Heating & Cooling Experts
Rick Johnson
Rick Johnson
Bill Long
Are you a Maytag Heating and Cooling Expert? Answer questions, earn points and help others
