Question about Lincoln Conveyor Oven - 1132-000-A
Lincoln impenger gas model#1116-000-A, Problem: conver runs does not heat up. Also top oven fluctuates tempuature 70 degrees all the time after it heats up. What is problem where to get parts in central california?
  • Lincoln Master
  • 22,326 Answers
Do what i done and build a brick one ,use the metal grills from an old refridgerator,oven on the side with a metal door ,trying to repair some of these type of BBQs after they have been in the garden all winter and rusted up ,then trying to find the local agent ?? for a weekends work you will have a BBQ that will cost little to build and last a lifetime
Posted on Aug 26, 2010
Lincoln Conveyor oven Md. 1000 Suddenly turns off
Check the burner-blower centrifugal switch (S5 on the wiring diagram).
Jun 19, 2010 | Lincoln Conveyor Oven - 1133-000-A
When set to bake eg: 350 degrees the audio alarm will indicate it's reached temp but the oven is 50- 75 degrees lower. Must wait another 15 min for it to reach the proper temp. Have tried to adjust the off...
If you are monitoring the oven temperature with an analog style thermometer you may actually be ok, but seeing the thermometers slow reaction time.
Some newer ovens actually do pre-heat beep prior to reaching temp in an effort to conserve eelectricity.
A good home test is to try your oven at several different temps to see if there is any variation in internal temperature. Try it one day on 300, the next at 375 and another day at 450. Give your analog style thermometer time to catch up (usually just about 15 min) and leave it on for a half an hour to see if the temp maintains.
Also Beware of aluminum foil AND THE NEW OVEN LINER MATS as they can alter oven performance bay absorbing and blocking the ovens natural heat radiation and convection air flow currents that happen in all ovens, not just convection models.
Another interesting fact is that older ovens used a thermostat in them that operated much like your thermometer and was very slow to react making the oven typically about 100 degrees hotter than where the customer set it. This was just a fact of life before the advent of electronic temperature management and became noticeable when people began trying to bake older "hand me down" recipes in the newer ovens with less than stellar results.
You can mimic the older oven performance by preheating the oven about a hundred degrees higher than called for and after it reaches temp, re-set it to the correct temperature and put the items in right away.
If you find your temperatures fluctuating ask your servicer to replace first the temp sensor and as a last resort the control board as this part is usually pretty expensive.
Good Luck with this!
Jun 14, 2010 | Ovens
I'm a landlord and my tenant's oven will not heat up to the proper temperature intermittently. I had a guy come out and test the oven and it works fine, yet my tenant is still complaining the oven is not...
Absolutely. That is the first thing I would think that would cause such a fluctuation of temperatures. BUT if it is a gas oven (WITH A PILOT FLAME) then FIRST consider the thermocouple needing to be changed. If the thermocouple keeps faulting it will shut off gas sporadically and keep the gas off until it resets temporarily on its own.
Mar 13, 2010 | Ovens
Ovens wont heat to temp
The reason to this problem can be due to the faulty
thermostat.
Sep 02, 2009 | Lincoln Conveyor Oven - 1133-000-A
Oven heating issues.
bake ignitor is coming on but it will be weak. about $70 for part
Aug 21, 2009 | Frigidaire FGB24S5A Gas Single Oven
Amana Oven ARG7800E - Oven will only heat up to 150 degrees.
u sure the flame is lighting sounds like it isn't make sure u physically see the flame u might just be seeing the glow of the igniter if it doesn't light more than likely the igniter needs to be replaced
Jun 27, 2009 | Ovens
Oven will not heat past 300 degrees
300 far. or cels if its celcius its to high they should run at about 260 or the high temp sensor will shut it down how fast is your belt running it should be 6.30 to 7.00
Jan 28, 2009 | Lincoln Conveyor Oven - 1133-000-A
Lincoln Impenger 1100
hellow my name is ash i sale linclion ovens and repair they have only one burner and they only go up to 600 degree F make sure that the impenger plates one on top and one bottem are possion prapley, 2nd set temp at 500 and 530 f time 6.5 m if still under cook blow use plates with holes
Apr 27, 2008 | Lincoln Conveyor Oven - 1133-000-A
Creda oven
you might have already thought of this, buy an oven thermometer you can pop in the oven.
I bought one from my local cook shop
I have a the same cooker and similar problem - mine gets hotter by 50 degrees so I set the temperature 50 degrees lower than needed.
I noticed the problem a few years a go and luckily hasn't got any worse.
maria
Jan 02, 2008 | Ovens
Oven temperature
you guys should check your tempurature sensor. Our oven has been acting weird like saying it has heated up to 400 degrees in like 1 minute haha. Well after a few months of this happening on occasion we get an F2 error flashing..
did some research on it and apparently for GE ovens this is a temp sensor gone bad. Im looking to buy one now which is how i found this post, i just thought id tell you all what i found out and maybe you should look into that as well.
Oct 30, 2007 | Viking VGS0166 Stainless Steel Gas Single...
Lincoln Conveyor Oven - 1132-000-A Logo
137 people viewed this question
Top Lincoln Ovens Experts
Dan Webster
Dan Webster
jasbo
jasbo
Colin Stickland
Colin Stickland
Are you a Lincoln Oven Expert? Answer questions, earn points and help others
