Question about Motorola Mobility Z9 Cellular Phone
My motorola z9 phone won't charge when i have the charger plugged in
damanone
  • 77 Answers
SOURCE: Motorola i880 white screen flashes i880 won't charge
the i880 & the i885 needs a quality charger, if you get a original Motorola charger IT WILL WORK. There are some aftermarkets that will work, but not many.
Posted on Aug 02, 2009
SOURCE: Motorola RAZR won't charge
don't buy a razr v3 because they obviously suck
Posted on Jan 22, 2008
fossildude
  • 832 Answers
SOURCE: I would like to disassemble Motorola Z9 phone. Any
hello! thanks for using Fixya.com
you may follow the instruction below:
First, turn off your phone:
  1. Push the battery cover up, towards the top of the phone to release it
  2. lift up and remove the battery cover
  3. Pull the tab on the label near the hinge, then remove the battery from the
    phone.
  4. Remove the sim card and the sd card
  5. There are two screws you need to remove
  6. Using a Torx driver with a T-5 bit, remove the screws at each side of the phone.
    Retain the screws for reassembly.
  7. Turn the phone over so the keypad is facing upward.
  8. Use the disassembly tool to remove the bumper pad below the keypad
  9. Then remove the two screws under.
  10. turn the phone over so you see the back Release the first housing latch by inserting the flat edge of the plastic
    disassembly tool at an angle through the slot on the rear housing then push
    away to disengage the two front snaps.
Good luck!!! Cheers!
Posted on Feb 18, 2009
issikiki
  • 563 Answers
SOURCE: my brand new motorola razr v9 would not charge,
If it is a brand new phone, it will not cause this problem. You should return it or exchange it for a better phone ( if you still have the warranty card). The problem here is your phone's battery. Your phone's battery is not functioning well either it's old or corrupted. The solution is to change your battery.
Posted on Jul 27, 2009
SOURCE: my motorola hint phone says "unauthorized charger"
my dogs chewed up my charger. i figured id connected to my lap top and let it charge that way. but it keept saying un.charger. after i put in a memory chip i pluged it in again and it charged ok. remember to make sure your usb connection is on the mass storege option on your settings. not a solution to the problem. but its an option.
Posted on Jan 19, 2010
My Motorola electrify won't turn on or charge. It
maybe your battery or your phone os .... try a new battery if nothing happens... try re flash your phone
Jun 02, 2013 | Cell Phones
Motorola cellular w376g, battery won't charge
If possible test with another charger like a car charger if you have one
also try removing the battery plug in the charger and put the battery back in (don't touch the contacts/gold pins)
if it works with other chargers then the charger is bad
if it doesn't work with other chargers charging port/battery/phone is bad
May 27, 2012 | Cell Phones
My phone won't charge ?
You really only have two choisces here, the battery is defective or the phone is. The more common issue would be the battery.
Jan 15, 2012 | Motorola Cell Phones
Unlock motorola z9
Using codes you can unlock your mobile because its safe for your mobile.......
Get the unlock code for your motorola Z9 model mobile here Simpleunlocking.com , it gives the easy instructions to get your mobile as unlocked........
Dec 15, 2011 | Motorola Mobility Z9 Cellular Phone
My motorola Blur won't charge, I've tried other chargers and nothing, it will catch a charge for a second and then nothing, now my phone is dead
My Motorola Blur would not charge kept saying Connect Charger. I tried various power connecters including the Original one that came with the phone and the USB to no avail. This morning I took the phone apart and clean it and still would not recognize the charger.
Fix: I lifted up the connector where the charger plugs into on the actual phone and now it is making contact and appears to now be charging my phone.
Sep 15, 2011 | Motorola Mobility CLIQ Cell Phone
I only have had my Motorola Z9 for two weeks and it just turned off of me the other day, when it had a full charge. I tried taking out the battery and putting it back in and keeping it plugged into the...
try taking the battery out plugging in the phone to the charger see if it turns on if it does then plug in the battery . let me know if that worked i have other ideas but thats a start
Mar 26, 2011 | Motorola Mobility Z9 Cellular Phone
Turn it on, the screen says ATT then shuts off
Check the battery if it needs to be replaced. Borrow same phone from a friend and use your battery on the other phone and check if it will turn on or will just do the same thing and shut off after the ATT... if it did the same thing...replace your battery.
May 12, 2010 | Motorola Mobility Z9 Cellular Phone
I just bought a motorola E815 cell phone and it will not charge
Remove battery, clean contacts between battery and phone, also be sure to use an original Motorola charger instead of one of those "universal" type chargers.Hope this helps!
May 08, 2010 | Motorola Mobility E815
Plug up to charger and it says unable to charge
Remove battery, clean contacts between battery and phone, clean charging port, also be sure to use an original Motorola charger instead of one of those "universal" type chargers.
Jan 18, 2010 | Motorola Mobility W385 Cellular Phone
Motorola Mobility Z9 Cellular Phone Logo
117 people viewed this question
Top Motorola Mobility Cell Phones Experts
Rami Obeid
Level 1 Expert
D. E. Hev
Lawrence Oravetz
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
