Question about Sharp MX-3501N All-In-One Printer
I have a Sharp MX-3501N. I have it all connected to the network and have no problem printing from anywhere. My problem: if you try to scan and email, it returns the following message "communication with selected server is lost while sending image" any help would be greatly appreciated as I have exhausted all my ideas. Thanks, Bobbi
SOURCE: Sharp MX-2300N trying to send image to email address gives error
The new fire wall was set up with a password, free the password on the server setup, that should eliminate block.
Posted on Dec 19, 2008
  • 34 Answers
SOURCE: what is error code f9-00 on sharp mx-3501N
f9 means your control panel needs to be replaced..chances are part is not covered and if it is the only way you can obtain it is through having service
Thanks,
CF
Posted on Jun 25, 2009
  • 8 Answers
SOURCE: I got call for service code: h5-01 I already took
press these keys
#, *, c, *, or
#, *, c, #
if input correctly copier will ask for simulation code
type in 14 then start
01 then start
if it ask are u sure after inputing 14 then start hit yes or 1 for yes or execute. copier will restart. all will be fine untill the next three jams
Posted on Aug 17, 2010
  • 8 Answers
SOURCE: HI HAVE SHARP MX 3501N COPIER , TORE TRANSFER BELT
You really dont want to do this. It is tricky. The new belt can be pinched and ruined extremely easily, and you are required to apply it with a special lubricant. In case you really want to, The supply item is MX-4501Y1. That is just the belt. There is another kit for the transfer rollers inside. If you want to buy. $150 email me.
Remember, kit wont work without lubricant
just4fixya@gmail.com
  • 120 Answers
SOURCE: how to clear error code
If you power the machine off and on and it comes back, try replacing the whole transfer belt unit. If it still comes back, sorry dude you're out of luck. Your copier can't swing the hinged portion of the transfer belt on and off your color drums because a badly designed gearshaft for your transfer lift motor has worn out and probably ate up a bearing or bushing as well. This is a known problem and Sharp has published a service bulletin addressing this. It may be motor rebuild time for you, with the new edition gearshaft.
Posted on Feb 24, 2011
Sharp MX-3501N will not accept envelopes
here is a walkthrough for printing on envelopes. basically you have to set the machine for envelopes then set your print job for envelopes.
How To Print on Envelopes or Labels on Sharp Printer
Copier Collin Houston TX Copier and Imaging Expert
Jun 30, 2014 | Sharp MX-3501N All-In-One Printer
How do I clean the printhead on Sharp 3501N?
Hi, Go into printer properties. Click on clean printer chartridge.
When you do this it will run automatically. Do this several times to make the color come out clean. Good luck.
Apr 01, 2014 | Sharp MX-3501N All-In-One Printer
Sharp mx-350n will not print in color from the network
Which model is it? The MX-350N is black and white, the MX-3501N is a color model. I'll assume it's the MX-3501N.
Either it's defaulted to print B&W in which case you just go to your printing preferences of the print driver in the printers menu in the control panel, and uncheck the "black and white print" box, or you have account/user codes that you need to enter in your print driver in order for it to print color. Instructions for adding a user code to the printer driver are found here.
Setup and Manage User Codes Account Control on Sharp Copier
Feb 03, 2014 | Sharp Mx-3501n Color Copier Printer...
Macbook can't connect wirelessly to sharp 3501n copier
I think you don't have the right driver for connecting it. Check it with other comp once or cellphone.
Engine Performance Chip
Aug 08, 2012 | Sharp MX-3501N All-In-One Printer
How do i print a big envelope in a Sharp MX 3501N printer? Which option should i select?
Select the heaviest paper setting available and only use the right-side manual feed tray.
Jan 17, 2011 | Sharp MX-3501N All-In-One Printer
How to setup SHARP MX 3500N, to use it for printing wirelessly.
Buy a wireless print server. Which ever company you buy from will have a help line and guide you through set-up. They are priced $60 to $100
Aug 13, 2010 | Sharp MX-3501N All-In-One Printer
I am connected to the sharp mx-3501n via a network and i have been printing in color for some time now, however, recently it only allows me to print in black and white while other people on the network are...
In the properties menu of the printer. Click on the tab of job handling. Make sure your user information and password for the copier has been entered. Without this you can only print black and white.
Jul 28, 2010 | Sharp MX-3501N All-In-One Printer
Get network error ce-00 on the sharp mx-3501n when i try to scan to network.
CE-00 means ther is a bad destination entered or the copier is not seeing the server check the IP address
Jan 08, 2010 | Sharp Office Equipment & Supplies
Sharp MX-3501N All-In-One Printer Logo
522 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
CheckitRight
CheckitRight
jasbo
jasbo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
