Question about Kwikset Powerbolt/Electronic Deadbolt- Polished Brass
Have a AccessOne Model 898. Trying to reprogram. No beeping occurs when validating reprograming. Red light stays on the door lock. Need to find MASTER CODE for this model, if possible. Thanks
  • 963 Answers
SOURCE: I need to change the code on the lock . I just
Here is a link to the installation and programming instructions for kwikset Powerbolt:
http://s7d5.scene7.com/is/content/BDHHI/kwikset-smartcode
Here's the main product page:
http://www.kwikset.com/Products/Categories/Electronic-Locks.aspx
Posted on Mar 05, 2011
  • 963 Answers
SOURCE: need to know how to
Here's a link to the Frequently Asked Questions page for the Powerbolt 1000:
http://www.weiserlock.com/Support/Faq/50160000000HhhZAAS.aspx
The instructions for reprogramming the code can be found there. Good luck!!
Posted on Mar 06, 2011
SOURCE: do you know how to reprogram digital code??
1) Remove back cover (instructions usually are stuck on the inside of the back plate cover .. if not continue next ...
2) Make sure all batteries are fully secured.
3) Press the square Reprogram button
4) Press the keypads of your code. If you do not hear any sound when pressing the buttons, then it means your batteries are not fully secured.
5) After entering your code, press the middle keypad (lock) once.
6) To double check things are working right, then press the keypad buttons again and then when you see the deadbolt is unlocked, then press the middle keypad (lock) again to ensure the deadbolt comes out to lock.
Recommend periodic lubrication of the deadbolt lock for less strain on the batteries ,,, and lubricate the key lock occasionally as well.
Posted on Mar 12, 2011
  • 963 Answers
SOURCE: I'm using a kwikset smartcode
I have reviewed the installation instructions for the Kwikset 907-11P; here is a link to it:
http://s7d5.scene7.com/is/content/BDHHI/40486-02
I would recommend verifying that the batteries are new and installed correctly. I did not see anything about an insertable/removable battery pack or the need to hold a lock button while changing the batteries. Under normal circumstances there is no need to reprogram the lock codes when batteries are changed.
I did see that if the bolt does not extend when the lock button is pressed that you need to reprogram the handedness of the door (see Step 4.9).
On page 9 of the installation instructions is Troubleshooting tips and a contact number for Kwikset USA :
1-800-327-5625. I'd recommend calling them directly if, after going through the installation instructions, that you have the same problem.
Posted on Apr 26, 2011
SOURCE: i have a kwikset deadbolt
I had the same question as my son installed the lock. Instructions should be printed on the cover you remove (inside the house). They need to make removing that cover MUCH easier, I'm always afraid I'll break it. Anyway, you press the button once for the first number. To enter a "guest" code, press the button twice then enter the 2nd code in the keypad and press the lock button. Now try both main # and guest #, both should open ttthe lock.
Posted on Sep 30, 2011
Ultra starter model 1270 keeps trying to lock doors
you will need to get the manufactures instructions or wiring diagram to wire the circuit correctly.
It appears that the circuit has an open short somewhere.
Jan 18, 2014 | Ford Cars & Trucks
Reprogram toshiba se-ro329 remote
  1. Press and hold the SETUP button until the red indicator stays on, then release the SETUP button.
  2. Press and release the desired Mode button (TV, VCR, etc.). The red indicator blinks, then stays lit.
  3. Enter the 4 digit code from the code tables. Note: after a valid code entry, the red indicator turns off. For an invalid code, the red indicator flashes.
  4. With your device on, press CHANNEL UP. If the device responds, no further programming is required. Note: If some buttons do not operate your device, try one of the other codes for your brand.
Aug 11, 2012 | Televison & Video
Car Alarm beep Problem
Sometimes tow beeps when locking means that one of the door is not properly closed or is ajar. If that is not the case, get it reprogrammed.
May 30, 2012 | Proton Cars & Trucks
I have a Defiant Electronic deadbolt from home Depot. model G1X2D01. ive lost the manual and i need to delete some old codes from it.
Snap off the back cover (opposite where you punch the numbers) by pinching the sides and pulling off. Do not press a pen or anything into the small light, you do not need too. Just pinch and yank off cover. You will see a small light and beside it is a small SET button by the batteries, it is labelled.. Press this Set button for 2 seconds. The red LED will light on the front code side and beep twice to indicate you are in programming mode. Enter your current code that you want to change (factory set is 12345) and then press the button that looks like a little lock on the keypad. Enter the digits "10" and press the lock button again. Enter the new code (must be six digits) and then press the lock button again. The red light should go on continously for 10 seconds. The code should be effective.
Note: if you have problems like we did, you can also remove one battery and press the "set" button simulataneously when you reinsert the battery. This resets the factory code of 12345. Then you can start over. For some reason our old code was only 4 digits, but it would not let us reprogram a 4 digit code. It didn't work until we did a 6 digit new code.
Apr 15, 2012 | Locks & Locksmithing
I'm using a kwikset smartcode lock. When I follow the directions, holding the lock button while inserting the battery pack, instead of two beeps after a while, I get a beep, then 5 seconds later a long...
Apr 26, 2011 | Kwikset 907 907-11P Venetian Bronze Smart...
Need to reprogram sears garage door remote opener
Click below to get to the manual you need. Just scroll through till you get to your model number.
http://www.managemyhome.com/mmh/owner_manuals/search?query=GARAGE+DOOR+OPENERS&find=
Hope This Helps,
RSMITH972278
P.S. PLEASE RATE ME
Nov 15, 2009 | Locks & Locksmithing
Need to reprogram door locks for 2004 Toyota Camry
I recently replaced the battery on my 2004 Toyota Camry. When I installed new battery the door locks will not stay unlocked once opened with remote. How do I reprogram?
Feb 21, 2009 | 2005 Toyota Camry Solara
Kwikset Powerbolt/Electronic Deadbolt- Polished Brass Logo
186 people viewed this question
Top Kwikset Locks & Locksmithing Experts
Jim Thurston
Mike
J.D. Browning
J.D. Browning
Are you a Kwikset Lock and Locksmithing Expert? Answer questions, earn points and help others
