Can't connect my dymo EL40 to my new computer, can you help?
    Guru:
  • 82 Answers
Here is the software if you did not and also the manual
http://hotfile.com/dl/64895468/6d0586d/dymo_EL40_(_driver__manual).rar.html
Posted on Aug 26, 2010
How do i transport the address book from old computer windows xp to new computer vista
The easiest way would be to identify the location and the file your Dymo printer uses to store its address. Copy the File to a USB memory stick, copy the File on the USB stick to your your new computer, and when you start up your Dymo printing utility open the copied file as your default address library.
The problem you may run into can be caused by different versions of the Dymo printing utility. You may be forced (using the Dymo printing utility) to export the address book on the XP computer and then import the address book on the Vista computer. The picture below outlines this procedure using Dymo printing utility v.8
Also, if you have created any custom label designs you will want to transfer them as well
Jan 17, 2014 | Dymo LabelWriter 310 Printer
At the end of a set of labels, my 400 jammed so I had to take off the front section to clear the jam. When I loaded new Dymo labels, it now doesn't print. Not sure if when I took off the front...
Welcome to FixYa.
Reset the printer by doing the following:While the printer is on, unplug the printer power cord.Restart the computer.Plug back the printer. Make sure all connections are properly connected.Unload an reload the Dymo labels.Then restart the computer again.Try to print.
Thank you for using FixYa.
Jan 04, 2012 | Dymo LabelWriter 400 Thermal Printer
Our old computer crashed and when I installed Dymo on our new computer, the label size we always used isn't installed. I need label size 30336. Can you help?
I just looked through all the preconfigured labels on my Dymo 330 and did not see a 30336 label. Is it possible you configured this manually or had it inserted from some other program you loaded? It's easy enough to configure a label manually. You might also call Dymo tech support.
Jul 18, 2011 | Dymo LabelWriter 330 Thermal Printer
DYMO Label/Writer is not printing after replaceing labels
DYMO labelwriters use patented labels, anything else would not be recognised by the system. For help - call DYMO support from your country.
DYMO support
Apr 03, 2009 | Dymo LabelWriter 400 Thermal Printer
Dymo stamps doesn't see USB Dymo scale
You might try connecting the USB cable directly to one of the computer's USB ports.  My scale (DigiWeigh) showed as not connected when it was connected to a USB hub.  When it is connected directly to the computer, it shows the scale as connected.  Unfortunately, it still won't transfer weights to the Dymo Stamps software.
Dec 11, 2008 | Dymo DateMark Date/Time Stamper
Trying to reinstall dymo software onto a new computer
Does your new computer use WINDOWS VISTA? Go to: www.dymo.com, left click on SUPPORT, select your product from the list, and select DRIVERS AND DOWNLOADS. They should have a VISTA compatible driver you can download for free.
Aug 12, 2008 | Dymo Office Equipment & Supplies
DYMO THINKS ITS OUT OF PAPER ....
New versions of the Labelwriter 400 (original and Turbo) do not take Generic Labels. It is an issue with the firmware Dymo have installed - it will only relabelwriter400.jpgad the genuine labels made by Dymo. currently there appears to be no work around to solve this isses.
The Dymo OEM labels have lines print on the back, if you use labels without these lines, the printer gives an "out of paper" error
The only printers in the Dymo Range that will take our generic labels are the Dymo Twin Turbo and the Dymo Duo (both the more expensive from the range).
Dymo have only made this change in the last 6-8 months, old 400's will work with cheaper generic labels
Aug 09, 2008 | Dymo LabelWriter 400 Thermal Printer
Error: Will not print
Hello Sir,
To check the printer settings in Windows 95/98/2000
1. On the Windows task bar click the Start button, point to Settings, then click Printers.
The Printers window is displayed.
2. Right-click the EL40 or EL60 or EL Turbo icon and select Properties in the shortcut menu.
The Properties dialogue box is displayed.
3. Click the Details tab, then click the Port Settings button.
The Port Settings dialogue box is displayed.
4. Verify the following settings:
Bits per second: 19,200 (for EL40, EL60, XL, XL+) / 115,200 (for EL Turbo, XL Turbo, 330 Turbo)
Data bits: 8
Parity: None
Stop bits: 1
Flow control: Xon/Xoff (for EL40, EL60, XL, XL+) / Hardware (for EL Turbo, XL Turbo, 330 Turbo)
5. Click OK to close the Port Settings and Properties dialogue boxes.
6. Click the Close button in the upper-right corner.
The Printers window is closed.
To check the printer settings in Windows NT
3. Click the Ports tab, then click the Configure Port button.
Select the COM port and click the Settings button.
Bits per second: 19,200 (for EL40, EL60, XL, XL+) / 115,200 (for EL Turbo, XL Turbo)
Data bits: 8
Parity: None
Stop bits: 1
Flow control: Xon/Xoff (for EL40, EL60, XL, XL+) / Hardware (for EL Turbo, XL Turbo)
7. Click OK .
Thanks
Good Luck
Don't forget to comment
Cheers!!!!
Feb 20, 2008 | Dymo LabelWriter 320 Thermal Printer
Computers & Internet Logo
26 people viewed this question
David Payne
David Payne
