Question about Nikon COOLPIX S60 Digital Camera
My Nikkon COOLPIX S60 makes a buzzing sound and the screen turns black when i turn it on
  • 6,831 Answers
Hello
The problem is that the lens has become stuck in the barrel after dropping it. There are some DIY solutions you could try, but the probability is that you will have to get it fixed by a professional.
Use these at own risk as it may further damage the camera.
Firstly , try connecting your ac adapter or usb cable.
Try holding the shutter button while switching on the camera.
Look at the lens , and if some of the lens 'circles' is misaligned or not concentric then try wiggling it (while holding camera lens down).
Try gently pushing or pulling the lens when it extends but this is risky as it may cause the lens barrel to slip out of its guidance system.
Another way to do this is to place the camera lens down on a hard surface and then power it up. Be sure to use a soft cloth or something similar as to not scratch your lens or casing. Let the lens push the camera up and down a few times and sometimes the little resistance provided by the camera is enough to get things going again.
Try hitting your camera near the lens on the body with the soft tissue on the palm of your hand.
Other than that , I would take the camera to a repair center for a evaluation to see if it would cost more to repair than to replace the camera.
If it is still under warranty I would suggest you take it in before trying any of these steps and remove any off-brand batteries or accessories as some stores are really fussy about warranty repairs on camera's with non-brand accessories.
Hope the advise is useful.
Regards
Andrea
Posted on Aug 27, 2010
When turned on the screen is blank and makes a high pitch buzz
Samsung LCD TV with no video and high pitched sound - Digital TV ...
www.tomsguide.com/forum/54120-4-samsung-video-high-pitched-sound
Nov 8, 2015 - 25 posts - ‎12 authors
Our is the same model and has started making a very high pitched ... to acutally turn on and then when it does, the screen is still black and we ...
Is your LCD making a buzzing or high pitch noise ...
https://www.devside.net/blog/lcd-making-a-buzzing-noise
Dec 30, 2008 - In my case, the monitor was fine for the first two months. But then started making a buzzing noise... 1) when on, 2) worse when .... my Samsung TV ismaking high pitched noises even if its turned off. I will NEVER EVER EVER ...
TV not turning on; making high-pitched sounds - Tom's ...
Dec 13, 2015 | Televison & Video
When we turn on the S60 it makes a buzzing sound and stays on momentarily and then shuts down. What might be the problem?
It might be any number of things, but the buzzing would seem to indicate a short in the camera. It could be the battery or any one of a number of electronic components.
Jul 24, 2013 | Pentax Optio S60 Digital Camera
My nikkon coolpix s4100 wont turn on
Please verify that you have the correct option selected for the Charge by computer, MENU > SETUP MENU > Charge by Computer. Also, try it with a backup battery. If the problem persists you need to send the camera and the charger to be evaluated.
Jul 23, 2011 | Nikon Coolpix 4100 Digital Camera
I have a nikon coolpix s60 and when i go to view the pictures, the screen turns black and i cant turn the camera off unless i pull the battery
What name brand memory card do you use? I recently discovered myself that Nikon only supports SanDisk, Toshiba, Panasonic and Lexar. Try taking out the memory card and take pictures without the memory card inside the camera. If you can view the picture saved onto the camera memory then you will know that all you need is a new memory card, with one of the above mentioned name brands. Hope this helps.
Mar 01, 2011 | Nikon COOLPIX S60 Digital Camera
Hi.i m central excise and service tax inspector.i purchased nikkon coolpix s3000 on 04.05.2010 from chennai. today i chkd n found one black spot on the screen some whitish linings like on the screen...
why are you so worried, if it is a genuine nikon purchase it is still under warrant, problem becomes sever if you have dropped the camera or some water has entered the unit.
i beleive chennai has a nikon authorised service centre.
Dec 22, 2010 | Nikon Coolpix S3000 Digital Camera
Lens error, buzzing noise
try these:-
  • connect it to pc and on it
  • vaccum the barrel of lens
  • changing mem. card and batt. for 2min.
  • shake it.
  • on and off in different positions
  • hit the part near lens softly with palm (trust me this made mine work)
Oct 24, 2009 | Nikon COOLPIX S60 Digital Camera
Nikon Coolpix S60 Lens Error Message
since you said you dropped the camera the lenz array might have cracked. try tapping the device while the message appears, if it works then you are a lucky one. in no you have to take it to the service centre to get it done. it costs about (50-60)$
Jul 29, 2009 | Nikon COOLPIX S60 Digital Camera
Screen and photos are black
CCD is BAD !!
just call Nikon i am sure they will doit Free becoz it is a manufac fault all manufacturers are doing it Freejust call them and ask them about BAD CCD !!
Pls rate me WELL !
Jul 03, 2009 | Nikon COOLPIX S60 Digital Camera
Why is my car buzzing or humming after i turn the ignition off?
If it's buzzing when the car is moving. it could be the wheel bearing making the buzzing sound. it needs to be replaced. you can probably hear it as being inside the hood.
Feb 16, 2009 | 2003 Volvo S60
Nikon COOLPIX S60 Digital Camera Logo
56 people viewed this question
Top Nikon Cameras Experts
Steve
Jeff Marcus
Are you a Nikon Camera Expert? Answer questions, earn points and help others
