Question about GE GBS18HBR Bottom Freezer Refrigerator
Freezer works fine but refrig is 66 degrees. What could cause that? Is there a fan that could not be working?
    Champion:
  • 245 Answers
It could be your defrost thermostat and heater. Also check your coils underneath for build up and the condensor fan behind rear access panel is blowing. If you have ice on the coils in your freezer it is definately the defrost heater and thermostat. Hope I helped you. Good luck, rate me if I am correct.
Posted on Aug 26, 2010
Whirlpool Frig/Freezer - Frig side too warm at 60 degrees
Check for another fan to cool the fridge side. It could be bad.
murf427
Aug 01, 2012 | Whirlpool Refrigerators
I have a Kitchenaid S x S KSCS25INSS00 refrig/freezer. We lost power for 30 hours, it worked fine before the outage, now it won't cool the fridge below 48 degrees, or the freezer below 43 degrees. ...
Try replacing the circulating fan first. If it's not turning, it's more than likely bad. However, the fan might not be your only problem. The problem may lie with the icemaker. The icemaker is essentially the brain of the unit. It tells when to cool, when to defrost and when to maintain temp. Your icemaker may be stuck in defrost mode.
Sep 04, 2011 | KitchenAid Superba Architect KSCS25INSS...
Kenmore 18tfa top freezer refrig model # 72852101 freezer works, no cool air going into the refrig part. Ice machine works fine too. fan is on.
Possible fan not blowing the air into the fresh food compartment or your freezer could be frosted up. Need more input.
Jan 29, 2011 | Kenmore Refrigerators
Hi..our maytag msd2351HE side by side is only making small amounts of ice..we are able to get water..Any suggestions?
I would suggest pulling the refrig out and removing the lower panel . On the right , there is a black box ( condensor ) . The fan pulls air thru the coils and dust , lint , etc , can block the air flow , causing the freezer to not get cold enough ( 5 degrees ) for the ice maker to work . Also check to make sure the fan there is working . If the fan is working and the coils are clean , try turning the freezer control slightly colder . If the fan is not working , replace the fan motor .
Aug 01, 2010 | Maytag MSD2351HE Side by Side Refrigerator
Frigidaire refrigerator with a broken freezer
He is correct. The temp in the refrig controls how often and for how long the refrig runs. Lets say the temp in your garage is 34 degrees, and you have your refrig set to 36 degrees: The refrig will never run, the fresh foods section will cool to 34, and the freezer will warm to 34. Even if the temp is 45 in the garage and you set the fresh foods to be 33, the refrig will not need to run long enough and often enough to keep the freezer temp cold enough. You will most likely need to have the ambient room temp at least 55 degrees to get satisfactory refrigerator performance. Insulating the refrig will not help. (by the way, outdoor beverage vending machines use an internal heater in cold weather to prevent liquid beverages inside from freezing,..... so using that info, you could put a low wattage heater in your refrig to make your refrig run enough to make the freezer section work. The %&#* with that, just move it into the house!)
Feb 06, 2010 | Frigidaire FRT17B3A Top Freezer...
GE PROFILE REFRIGERATOR-PSC25MSTA NOT WORKING
check to see if the fan by the compressor is working when the compressor is running if not you have the problem control board .....replace board
Jun 30, 2009 | GE Profile 26.6 cu. ft. Side-by-Side...
Maytag Refrigerator is 69 degrees
You must check the evaporator fan motor in the freezer.
Is it running?
You may need to push the door switch with the freezer door open for fan to run with drawer open.
Next check the damper in the fresh food section.
Is it open?
Air circulating through?
If not, replace your damper control and thermistor.
Feb 21, 2009 | Maytag MFD2560HES Bottom Freezer French...
Whirlpool refrig not cooling
is the fan in the freezer working when compressor is on? if not you need to replace it. do you have a large frost build up on the back wall of the freezer? if so you have a defrost problem, or back to the evaporator fan. If the fan is working you have a defrost problem which could mean a bad heater, timer, or bad defrost thermostat....
Jan 03, 2009 | Whirlpool GS6NBEXR Side by Side...
Amana Refrigerator
Is fan in freezer running? If not it is bad and needs replacing. Please leave feedback.
Nov 27, 2008 | Amana Easy Reach AFD2535DE Bottom Freezer...
Hot Point Side by Side. Freezer works, Fridge not cool enough
check freezer for frost build up and if fan blowing, check condenser make sure clean, and fan blowing, check vents in refrig. make sure no blockage, freezer control should be in the middle setting, you can try turning that to Warmer Freezer allowing MORE air to refrigertor side.
Aug 27, 2007 | Refrigerators
GE GBS18HBR Bottom Freezer Refrigerator Logo
Top Refrigerators Experts
Sal DeAngelo
dweatherby
