My garmin nuvi 650 na keeps depleting its battery even though I just fully charge it on the computer. It also does not charge when I plug it in the cigarette lighter in the car. The screen turns dark after a few seconds after I turn it on. Can I replace the internal battery in the unit?
  • 864 Answers
Well if you have the factory car charger. There is a fuse inside of it. This is indicated in the manual. But it could also be the cigarette lighter fuse in the car is blown. I would make sure the cigarette outlet has power. If the cigarette lighter has power and you have the factory power cable that has a fuse try this. f the unit will not charge in your vehicle, you might need to replace the fuse that is located at the tip of the vehicle adapter.
1. to change the fuse unscrew the black, round end piece on the vehicle power adapter and remove it. inspect the fuse to see if it is blown. If not end here.
2. if determined the fuse is blown remove the fuse (glass and silver cylinder), and replace it with a 1A fast blow fuse.
3.ensure that the silver tip is placed in the black end piece. screw on the black end piece
let me know how this works by following up with a comment and i can instruct you on where to go from here. Thanks.
Posted on Aug 26, 2010
Screen Frozen Garmin Nuvi 650 NA
This is a common problem, caused by a touchscreen failure. I have personally replaced well over a thousand Nuvi 6xx touchscreens. More info about this problem can be found here:
http://www.sharc.net/gps_LCD_repair.htm
Oct 07, 2012 | Garmin Nuvi 660 GPS Receiver
MY GARMIN NUVI 650 NA SUDDENLY STOPPED WORKING. WHEN I TOUCH THE SCREEN NOTHING HAPPENS... (THIS MACHINE HAD BEEN WORKING SINCE 2007). PLEASE HELP
Is it charged? If you are using the cigarette lighter adapter plug, there is a fuse in the silver tip of plug...... unscrew it carefully..its spring loaded... check fuse
Oct 27, 2010 | Garmin Nuvi 660 GPS Receiver
Garmin gps powers off even when fully charged
If you're "recharging" via the car charger - you might want to try charging via USB jack on your computer - or AC adapter (if your GPS shipped with one) for 5 or more hours.
Many Garmin units develop this condition when used strictly in the car / cigar outlet power source. While connected to your computer, you should go to Garmin's website and download, install & run the "webupdater" software. When complete, your Garmin GPS will have the latest firmware and patches to the software (not maps!).
After charging via USB or AC adapter, your GPS should stay on. If your GPS turns on via a slide switch on the top, Slide the switch from OFF and hold in the ON position for 10 seconds before letting go of the switch. This should force a "boot" on the GPS.
If you're unable to get the device to power up, contact Garmin Support to determine if your device is affected by a a recent battery recall or if there are other suggestions they have to solve the problem.
I hope this helps!
Oct 08, 2010 | Garmin nuvi 650 GPS Receiver
Can you charge a nuvi 1300 with usb with computer and how long does the charging take??
I have just got a Nuvi 1300 and have plugged into my computer with the Nuvi switched off. A little icon (showing GPS unit and computer) shows on GBS screen and unit starts to charge. I reckon about 3 hours to fully charge. You have to unplug GPS though to see battery status.
Martin. U.K.
Oct 07, 2010 | Garmin nuvi 1300 Car GPS Receiver
My nuvi 1300 gps keeps shutting off after about 5 seconds though it is fully charged
the fault is from the battery. The battery cell is weak and cannot hold charge. Its high time you replaced your charger.
Take care.
Jul 20, 2010 | Garmin nuvi 1300 Car GPS Receiver
My GPS shuts itself off even when fully charged
Typical issue with a defective battery. It's not holding a charge and needs replaced. Please see this link:
http://www.sharc.net/gps_battery_repair.htm
- Jim
Apr 29, 2010 | Garmin nuvi 650 GPS Receiver
How do I replace the battery for a garmin nuvi 650
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} If your GPS unit powers down before it can fully boot up, the battery will need to be charged. Please charge the unit with the vehicle power cable or on a computer for at least three hours. After charging the unit, it should power on and function normally. If the unit will not charge in the vehicle, check the fuse in the power cable for the unit and the power outlet in the vehicle.
The nuvi 200 series, 300 series, 600 series, 700 series, 1000 series and the StreetPilot C300 and C500 series do not have user replaceable batteries. These units must be sent in to a Garmin approved repair facilities if a battery issue arises. Garmin and Raytech are the only Garmin approved repair facilities. Raytech is a repair facility for Canadian customers. To repair your device please contact the specific repair facility for your region. If your device is not still under the 1 year warranty, there will be a cost associated with the repair of your device.
Dec 12, 2009 | Garmin nuvi 650 GPS Receiver
How do I open Garmin nuvi 650 to replace battery?
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} The nuvi 200 series, 300 series, 600 series, 700 series, 1000 series and the StreetPilot C300 and C500 series do not have user replaceable batteries. These units must be sent in to a Garmin approved repair facilities if a battery issue arises. Garmin and Raytech are the only Garmin approved repair facilities. Raytech is a repair facility for Canadian customers. To repair your device please contact the specific repair facility for your region. If your device is not still under the 1 year warranty, there will be a cost associated with the repair of your device.
Are you sure you have a dad battery?
MAKE SURE to use a Garmin charger!!!!!!
Nov 10, 2009 | Garmin nuvi 650 GPS Receiver
My Garmin will not power up.
The batteries may be depleted. Try charging via USB cable connected to a computer if cigarette lighter method does not work. When connected to a computer, the device should power on but no maps will be displayed. Disconnecting from the computer should cause the 760 to reboot - if the batteries are charged.
After charging, slide and hold the power switch for 5 to 10 seconds to power on.
Get *free* help directly from Garmin Customer Support:
Monday - Thursday: 8 AM - 6 PM, Friday 8 AM - 5 PM Central Time (closed holidays)
US: 913-397-8200
US Toll Free: 1-800-800-1020
Canada: 1-866-429-9296
Sep 14, 2009 | Garmin Nuvi 760 Handheld GPS Receiver
Computers & Internet Logo
213 people viewed this question
David Payne
David Payne
