Question about Aluratek USB Internet Radio Jukebox MP3 Player
I plug in my Aluratek Jukebox USB but it fails to automatically load its software AIRJO1F
How do I get"connected to computer "off screen on my 8" Aluratek digital frame?
pluging in a usb cable from a computer that allready has the device driver loaded , should send the photo frame into accept mode automaticly , then its all done via the connected computer , nothing on photo screen should matter , till usb cable is disconnected , sorry you cant leave cable connected .
Dec 31, 2014 | PANDIGITAL 8.0" Digital Photo Frame...
Charging my juke with a usb cord
Fully charge the battery to maximize playing time. However, it is not necessary to fully charge or completely discharge the battery each time. You can charge the battery by connecting the jukebox either to the AC power adapter (fastest) or to a USB port on the computer. The battery icon in the upper right corner of the screen indicates the remaining battery charge.
  1. Connect the USB combo cable to the AC power adapter, and then plug the power adapter into an AC power outlet. Or, you can connect the USB combo cable to a USB port on the computer.
  2. Plug the combo cable into the jukebox. Make sure that the top of the plug (the side with the arrows) is facing the same direction as the front of the jukebox.
    View Picture
  3. If you are charging your jukebox from the computer's USB cable, turn your jukebox off. If your jukebox is on, it cannot charge from the computer's USB cable. Note: If you are charging your jukebox from the AC power adapter, you can leave your jukebox on as it charges, but it will take longer to charge.
  4. If the jukebox is on, the power cord icon appears in the upper right corner of the display. The keypad's backlight turns on while the battery charges, and then turns off when the battery is fully charged.
  5. When your jukebox battery is finished charging, pinch the two side buttons on the plug, and then pull the plug out of the jukebox.
Feb 25, 2012 | Samsung SCH-U470 Juke Cellular Phone
How do I music onto my Aluratek ereader?
First hook your Aluratek to the computer with the USB cord that came with your Aluratek. Then make sure your Aluratek is on. Go to start menu on your computer. Open the computer file it should list your Aluratek along with your computer hard drive. Left click on your Aluratek drive. It should say open. Open it then click on the file that says the type of files you want to move. Books, pictures, mp3's. Now drag and drop the files to your open file. You can also do the same with the SD card rather than the internal memory both will show up as separate devices.
Jul 07, 2011 | Aluratek Libre eBook Reader PRO Black
How do i download things to the aluratek libre?
Jun 25, 2011 | Aluratek Libre eBook Reader PRO Black
I loaded a book on my sd card then put it in my reader then it tells me that it is incompactable I can not figure out how to read it off the sd card or how todownload it from the computer to the sd card...
First make sure your SD card is formatted for your Aluratek. You do that by hooking your Aluratek up to your computer. Turn your Aluratek on with the SD card inside the Aluratek. Go to start menu. Open file named computer. There should be your computer drive your Aluratek and the SD they will be lettered left click on the one for your SD card. It should list format. Click format. Use safe to remove hardware remove your Aluratek and SD card. Now press the reset button on your Aluratek with a paper clip or needle do not use a ball point pen. Now it should be ready to load with anything you want on it. To do that you hook up your Aluratek to your computer open the drive as stated before in your SD or your Aluratek. Now drag and drop your files into the drive you have open. It should now be compatible. I know this works I had the same issue with some of my mp3's.
Jun 15, 2011 | Aluratek Libre eBook Reader PRO Black
My usb radio doesn't work since I have windows 7
Hi johnny fata...
You will probably have to go the the players website and see if they have drivers or firmware that is compatible with Windows 7...
May 29, 2011 | Aluratek USB Internet Radio Jukebox MP3...
How to save music files in my philips jukebox?
you need cable interface to connect from your mp3 jukebox to a computer. your connection interface is thru USB (mini USB to USB cable). plug it in and your computer will automatically detect that new device. follow the on screen, open that device folder and download the music you wanted from your computer local drive to your philips jukebox. then you can download music (such as mp3 format) from your pc to mp3 philips jukebox. let us know.
Apr 16, 2009 | Philips GoGear HDD060 MP3 Player
Aluratek went away and won't show up
I have the same problem with my Aluratek AHDDS100F Sata to usb 2.0 docking unit. It will only work now if I connect it via usb 1.1. I am using a Iomega usb 2.0 pci card.
Aug 16, 2008 | Aluratek AHDU350 USB 2.0 Hard Drive
Software
SV-AV25 & SV-AV50- SD Jukebox Ver. 4.0, SD Moviestage Ver. 2.5, USB Driver SV-AV100- MediaStage, USB Driver SV-AS10- SD Jukebox Ver. 4.0, SD Viewer Ver. 2.1, USB Driver
Sep 01, 2005 | Panasonic SV-AS10 Digital Camera
Aluratek USB Internet Radio Jukebox MP3 Player Logo
161 people viewed this question
Top Aluratek Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you an Aluratek Audio Player and Recorder Expert? Answer questions, earn points and help others
