Question about Toshiba e-Studio 161 Copier Copier
Display H and than 4.. please solve my problem with thanks.
  • 86 Answers
Call sercice and tell them that there is a problem with the Heat roller low temperature detection.
H4 00 Content Heat roller low temperature detection
Detail When the fusing temperature is lower than
150C° after 55sec from the start of warming
up.
When the warming up complete temperature is
not reached in 30sec from reaching 150C°.
100C° after 20sec from ready start.
145C° when printing."
Cause Thermistor abnormality
Heater lamp abnormality
Thermostat abnormality
Control PWB abnormality
Check and remedy
Use SIM 5-02 to check the heater lamp blinking
operation.
When the lamp blinks normally.
Check the thermistor and its harness.
Check the thermistor input circuit on the control
PWB.
When the lamp does not light up.
Check for disconnection of the heater lamp and
the thermostat. Check the interlock switch.
Check the power PWB and the lamp control
circuit on the MCU PWB.
Use SIM 14 to clear the self diagnostic display.
Posted on May 06, 2008
My cell nokia 3230 display white do not show any thing. When restart celle just some time show the display. Please tell me how can solve tha display problem. Thanks
To solve this problem.
* unless if the connector just lose the connection socket,just put it back
* corroded or rusty portion can be fix by cleaning each pin connectors using a rust solution.
* LCD is not repairable , possible to fix if there is a parts for replacement.
Procedure in dismantling
(need a T6 precision screw driver)
1. Remove the battery cover.
2. remove the upper block cover by flipping the border upward.
3. now you see 2 screw on top and 2 screw on bottom,unscrew it using the T6 screw driver.
4. Gently remove the front cover by sliding up the side borders.
5. now on the upper portion,remove the metal shield cover on lcd by unlocking the clips on the both sides.
6. Now gently lift up the lcd connector to release it from the socket.
Now do the procedure shown above to fix the display problem.
If you have any question,don't hesitate to reply.Thank you for visiting FixYa.
Jul 07, 2011 | Nokia 3230
My K850i sony ericsson when you turn on, no light,no display in the screen,but keypad light is ok..pls give me a diagram to solve my problem thanks.
In that case if you can receive the call then there is display Problem you should change your display,
If your not receive any calls then please renew the Phone Software
Both Can be done only in Sony Ericsson service center Please Visit your nearest Sony Ericsson Service center they will provide you solution.
Regards,
Harish
// Feel free to vote this answer with 4 thumbs up //
Jun 17, 2011 | Sony Ericsson K850i Mobile Phone
Can it solve 8^x=4 ???
You can use algebra to solve it.
Use the fact that 4 =2^2 and 8=2^3 and substitute in the equation
(2^3)^x =2^(3*x)
Then 2^(3*x)=2^2
By equating the exponents
3x=2 and x=2/3
Using the solve( function
With the calculator physical keys between square brackets, and the SHIFTed or ALPHA keys between parentheses, type in the following
8 [^ ] [ALPHA] [ ) ] (X) [ALPHA][CALC] ( =) 4 [SHIFT][CALC] (SOLVE)
Once the foregoing command entered press [=]
Display shows Solve for X on top line and probably 0.000 on bottom line.
Press [.] 5 to give 0.5 as a guess for the value of x
After a moment the calculator returns with the solution.
The display shows three lines
1st Line: 8[^] X =4
2nd Line: X= 0.66666666
3rd Line : L-R =0.
Your solution is 0.6666666. In fact the exact solution is 2/3.
Hope it helps.
Thank you for using FixYa and for rating this solution.
Dec 03, 2009 | Casio FX-115ES Scientific Calculator
HP Laser Jet 4 with an unreadable screen
It may be a coded error message. See here.
Otherwise, try following these instructions to reset the language options.
I hope this information allows you to resolve this issue. If you need further assistance, please post back with a comment to this thread.
If I've managed to answer your question or solve a problem, please take just a moment to rate this post....thanks!
Jun 24, 2009 | HP LaserJet 5550 Printer
Moserbare 4 gb Pendrive message " Please insert a disk in to dri
Just format the drive by left clicking on the same icon and selecting format drive.
Apr 25, 2009 | Microsoft Windows 98 for PC
Reverse display on china mobile sigmatel s3 please solve my problem is display proble or any hardware
china w550 display broken iam do this job for new display but display was revers order pls solve this problem thank u
Feb 15, 2009 | Handmark Software MobileLists (950142) for...
My graphic become blur
You need to switch it to 32-bit, not 16 bit. DX9 drivers shouldn't be an issue, but if all else fails re-installing you video card drivers might help.
Hope that helps,
erch.
Mar 15, 2008 | ATI RADEON 9550 Graphic Card
ZD7020US Display
sounds like you have the wrong monitor drivers installed,  download updated monitor drivers from the manufacturer's website,
also check your display settings,  as something is really wrong there.
Oct 17, 2007 | HP Pavilion zd7020US Notebook
Toshiba e-Studio 161 Copier Copier Logo
83 people viewed this question
Top Toshiba Office Equipment & Supplies Experts
didi2005
jasbo
jasbo
Branko Djurdjevic
Branko Djurdjevic
Are you a Toshiba Office Equipment and Supply Expert? Answer questions, earn points and help others
