Question about Cub Cadet Street Sign- tractor lawn riding mower parts
I have a cub cedet commercial tank 60 zero turn lawn mower, and i need to change lawn mower blades. Which way should i turn the nut to take the blades off.
  • 843 Answers
As viewed from the bottom, if the blade turns clockwise, then the bolt should have a left-hand thread. A possible exception would be if the blade cannot slip relative to the shaft. This could be the case if the blade (not the washer) has a D shaped hole in it.
Good luck, Al K
Posted on Aug 26, 2010
How to replace mower belt for ZTR cub cadet mower
Changing the Blade Drive Belts:
a.Set the parking brake. Remove ignition key and both spark plug caps.
b.Unscrew the wing nuts from the deck covers and remove both covers.
c.Using a 3/8" socket breaker bar or socket ratchet insert the drive end into the 3/8" square opening in the lower idler arm assembly and push the idler arm counterclockwise. While holding the idler arm back, loosen the blade drive belt from the pulley and slide the belt away from the pulley.
d.Remove tension of the PTO belt by moving the belt tensioning rod. Loosen the belt retaining bolt.
e.Pull the tensioner pulley away from the belt and remove the PTO belt then remove the blade drive belt.
f.Reverse the process to install the belt.
Jan 08, 2015 | Cub Cadet z-force 60
Why do the deck vibrate on my cub cadet z force zero turn when I engage the blade?
Anon any vibration is down to something being loose, like a nut or bolt. It's possible the blade has also become very damaged and it is not completely straight anymore due to hitting a rock or something.
Aug 19, 2014 | Garden
I hit a metal pipe with my cub cadet zero turn lawn mower today. Now it smokes under the deck when I engage the blades and it is not cutting the grass. Have I ruined my mower?
You'll need to look under the deck w/ the mower not running and see why the blades aren't turning. Most likely something is bent (maybe blade) and hitting something. The smoke is probably from the belt slipping and getting hot.
Aug 09, 2012 | Cub Cadet Riding Lawn Garden Zero Turn...
Cub Cadet zero turn. Cannot get the blades to turn when PTO switch is pulled. Belts are fine and attached. Please help. John
i had the same problem. there was a short in the relay just before the wire gets to to back pulley assembly.
Apr 28, 2011 | Cub Cadet Lawn Mower Blade Drive Belt CUB...
How to change mower blades
fine a way to stop blade from turning, put a socket with long handle and turn countercock wise, some will need a wench on nut at top of shaft to stop blade from turning, torque to 60 # on most 50" or lower width mowers
Mar 21, 2011 | Cub Cadet Riding Lawn Garden Tractor 25hp...
CUB CADET ZERO TURN Z-FORCE 3-BLADE CONFIGURATION
Under each blade is one single nut holding each blade on. It is not left-hand thread and there is nothing special about it.
Standard thread - Standard hardware - Standard tools. (If memory serves, you need a 15/16" socket to remove these.)
There is no need to index or time the blades. They cannot hit together unless something is bent or damaged on your mower deck.
Hope this helps,
Dolf-
Oct 14, 2009 | Garden
Z force cub cadet zero turn belt problem
Try this one. It may have what you're looking for. Without your model #, I don't know.... http://www.partstree.com/parts/ Click on Cub Cadet then enter you model # on the left.
May 12, 2009 | Oregon Scientific Oregon Gator Mulcher...
My cub cadet zero turn mower won't engage the blades with the switch.
I have a cub cadet zero turn z force 48 yesterday i was cutting lawn and i heard a clink, the mower stopped, i was ablet o start the mower again but when i pulled the pto knob to engage the blades the mower turns off by its self, when the pto lever is pulled up i can restart the mower what is causing this and how do i fix it
May 09, 2009 | Cub Cadet Street Sign- tractor lawn riding...
Cub Cadet Street Sign- tractor lawn riding mower parts Logo
210 people viewed this question
Top Cub Cadet Garden Experts
Tim Whalen
DarkfireVA
Level 1 Expert
Matt Olenzek
Matt Olenzek
Are you a Cub Cadet Garden Expert? Answer questions, earn points and help others
