Can the top be removed and the tub pulled out of a Kenmore 80 Series washer model 110-24822200? If so, how (before I do to much more damager
    President:
  • 1,937 Answers
If you take it slow and easy, there isn't a problem. These machines are relatively to repair.
First, see the Sears Parts Manual for your washer:\
http://www.searspartsdirect.com/partsdirect/getModel!retrieve.pd?modelNumber=110.24822200&pathTaken=partSearch
Next, see the following:
http://www.american-appliance.com/catalog/newsdesk_info.php?newsPath=16&newsdesk_id=137
See the section on removing the agitator(s) and the tub.
You don't have to buy a special spanner wrench ($20) to remove the spanner nut. I've used a short 10" pipe wrench (about $9.00 also good for cracking walnuts) hooked over one of the tabs on the spanner nut, tap the handle with a hammer and it should loosen.
Also, don't directly hit the drive block with a hammer. Use a short piece of wood under the drive block and tap up on the wood.
Also, see the following Whirlpool / Kenmore Service Manual for topload, direct driive washers.
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/f7e2147fa98b28cf85257122007475cb/$FILE/L-55.pdf
Posted on Aug 27, 2010
Kenmore 80 Series washer wont turn on from the push-pull knob.
On this type of washer, you have to push it in to engage the dial and rotate it slightly clockwise then pull it out to start filling.
Feb 11, 2017 | Kenmore Washing Machines
Washer tub level
if you could post the model number found just inside the lid, I will be able to provide a more precise description of what you need to do.
Sep 27, 2007 | Kenmore 3.2 cu. ft. Top Load Washer
Kenmore washing machine 80 series won't spin or add water to the tub
Plug on motor (Multi-plug) may have a burnt out wire as it has different speeds. Remove and check the plug (top comes off). Any burnt wire needs to be cut back to clean copper and refitted into plug.
Dec 07, 2013 | Kenmore Washing Machines
Kenmore 80 series Model 110.28812790 - water leak inside tub
It's quite possible. First see the Sears parts list for your washer with diagrams of all major parts.
http://www.searspartsdirect.com/partsdirect/getModel!retrieve.pd?modelNumber=+110.28812790&pathTaken=partSearch
Then see the Whirlpool / Kenmore Service manual for these washers and check the troubleshooting section.
Mar 26, 2010 | Kenmore Washing Machines
My ken,ore 80 series washer agitates ok and seems
This assumes that you have a basic Kenmore / Whirlpool top load, direct drive, neutral drain (it doesn't spin until the pump removes most of the water) machine.
First, see the Sears parts site for your washer:
http://www.searspartsdirect.com/partsdirect/index.action
Enter your model number (###.######) and you'll see a list of major sub-components with diagrams and parts.
Two things to check.
It sounds as if the tub isn't getting full power from the transmission for spinning and/or the pump/hoses are damaged or blocked.
1. Remove the cabinet.
See the following.
http://www.american-appliance.com/catalog/newsdesk_info.php?newsPath=16&newsdesk_id=134&osCsid=7777818c689b6ece38ca9884721fffc7
and check the hoses / pump.
2. If they are OK, the problem may point to the Motor Coupler. See the following for how to check it.
http://www.american-appliance.com/catalog/newsdesk_info.php?newsPath=16&newsdesk_id=135
3. If the pump and Motor Coupler are OK, the problem could point to the clutch.
See the following for how to pull the pump, motor and transmission.
You don't have to remove the tub!!
If the clutch bands are worn, you don't have to replace the entire clutch. Sears / Whirlpool have a band replacement kit, a lot less expensive and easier to install than a new clutch.
Jan 17, 2010 | Kenmore Washing Machines
How many cubic feet are in the Kenmore Washer Model 110 80 series
The cubic feet of the Kenmore washer model 110 heavy duty is 2.8 cubic feet. Measured to the top water line 14.5 inches and using the radius of the tub of 10.375 inches.
Oct 26, 2009 | Kenmore 3.2 cu. ft. Plus Top Load Washer
I have a Kenmore Series 80 washer and the tub
i would check the motor coupler
it sits behind the motor before the transmission
this model
thre piece part that drives the transmission
Oct 15, 2009 | Washing Machines
My Kenmore Series 80 washer model 23832100 spins slowly
It probably is your clutch. You will need to remove transmission to repair this.
May 12, 2009 | Kenmore 22422 Top Load Washer
Kenmore washer
depends some modles have 2 clips under the front left and right you stick your putty knife in there and pull the console up, also there could be end caps get a screw driver and pop them off then there will be 2 screws remove them. Then some models have 2 screws directly behing the consol remove them pull consol forward and up. Once you have got the consol situated there are 2 copper brakets push down and out with your screw driver this will release the cabinet soyou can replace the lid switch
Dec 26, 2008 | Kenmore 22622 Top Load Washer
Sheet stuck under washer agitator.
remove agitator top remove 7/16 bolt to remove agitator. tub mounting hub may be worn which allows the tub to drop down. the hub is located on the center post below the agitator.
Dec 20, 2008 | Kenmore 23822 Top Load Washer
Washing Machines Logo
97 people viewed this question
Top Washing Machines Experts
