Question about Sharp AR-5316 Advanced Digital Imager Copier
The probrem am having with my sharp copier AR-5316 is that it always displays the toner indicator light when power which will not make the copier to be ready for work. please i also need other codes for the machine
    Habit-Forming:
  • 96 Answers
You have to check the toner gear in the end, it is not a code reset problem.
enter in the simulation mode and reset with 16 start 1 CA than.
Posted on Aug 26, 2010
Sharp AR 5316 Maching Toner LED Light 3 Min. Blinking, and them start. Please Toner Curm reseting code.
Have you tried to replace the toner???? Are you sure the light that is blinking for the toner?????
Jan 13, 2013 | Sharp AR-5316 Advanced Digital Imager...
My sharp ar5316e is showing a red triangle blinking light and no key is responding nether the start button
That indication is Toner Indication.You should change the toner,Now May be the toner chip also damaged. whether the machine worked after changing the toner then no need to change the toner chip,other wise the same indication still, then you change that one also.
Jul 08, 2011 | Sharp AR-5316 Advanced Digital Imager...
My sharp AR-5316E is displaying Error F2
An F2 indicates a problem with either the toner cartridge chip that tells the machine that the correct cartridge is inserted, or the developer housing chip is defective. I would believe changing the toner cartridge will eliminate the problem.
Aug 19, 2010 | Sharp AR-5316 Advanced Digital Imager...
Sharp AR-5316
The toner cartridge comes with on-chip sensor that counts the toner life. If you allow it to go empty completely that is it gives red triangle which is steady to warn that toner is near empty. You should replenish toner at this time but if you allow it to blink red triangle, that means its completely over and can't be refilled. REPLACE A NEW TONER CARTRIDGE.
May 06, 2010 | Sharp AR-5316 Advanced Digital Imager...
Olivety
F2 means that an improper cartridge has been installed. Look for the exact type that you used before and it will work.
Mar 26, 2010 | Sharp AR-5320 Black and White Copier
Copier
The problem is that the toner sensor is not recognizing that type of toner. All toner is not the same you will cause more damage to the machine. Use the specified manufacturer toner.
Ar-5316 showing error ch
CH steady means cover is open. Close either front or right cover well.
CH blinking means developer unit or toner cartridge not installed. Remove and return well and firmly.
Nov 22, 2009 | Sharp AR-5316 Advanced Digital Imager...
SHARP AR-5316 MAINTENACE RESET
To reset maintenance codes requires going into service mode. This should only be done by an authorized trained technician as changing or adjusting something in this mode could create all sorts of problems you dont want to deal with.
Mar 17, 2009 | Sharp AR-5316 Advanced Digital Imager...
Add toner still blinking of sharp AR-5316
the best you can do is to replace the toner cartridge itself. It won't work if you just refill it.
Oct 31, 2008 | Sharp AR-5316 Advanced Digital Imager...
Sharp 5316 toner Indication
go into your menual bottom on display and go to clare count and selecte( yes ) and it will go off or selecte new toner.
Mar 31, 2008 | Sharp AR-5316 Advanced Digital Imager...
Sharp AR-5316 Advanced Digital Imager Copier Logo
98 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
k24674
CheckitRight
CheckitRight
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
