Question about Refrigerators
Ice Maker is clogged with ice - Refrigerators
    Champion:
  • 245 Answers
Defrost the water tube running to your icemaker and replace your inlet valve behind your fridge underneath the rear access panel. Hope I helped you. Rate me If I did.
Posted on Aug 26, 2010
Ice maker ice dam
turn the ice maker off, take out the ice box and let all the ice melt try a knkfe in the ice maker to chip away whats clogged. it worked on mine but its not permanent. good luck
Aug 27, 2012 | Whirlpool Refrigerators
I have a whrilpool refrigerater the ice maker will not fill with water?
Bonjour,
Ice makers can clog. The water valve can stick open or closed or even not work at all. The water fill nozzle can clog with ice or food. If the unit has been moved the water line could be kinked or the water filter may be clogged. Maybe the water valve for the ice maker water line is turned off. Is there one under the sink? Inside most ice makers there is a thermostat that tells the ice maker that the water is frozen and it's time to dump the ice cubes. That starts a geared motor running to dump out the cubes. And in some cases a mold heater is turned on to help break the ice cubes loose. A lot of ice makers have a cam attached to the motor that turns with the shaft. When the ice cubes are gone the cam starts a timer to refill the ice maker with fresh water to make some more ice cubes. Most "fill" cycles of ice makers are "timed fill". The fill cycle has to start and stop to get fresh water into the ice maker. There may be another thermostat that monitors the air temperature where the ice maker is mounted. If that thermostat thinks the air is not cold enough to freeze water nothing happens. If all the steps don't happen at the right time no ice cubes are made.
Jul 11, 2012 | Refrigerators
Ice maker makes ice but freezes before it can be dispensed so the dispenser is always clogged with frozen ice. Cleaned out the ice maker and started over but same results. The temp is set at 38 for the...
Hi, The freezer should be "0", the possible clogging you have could be a leaking water valve or an over filling ice maker. I would have the ice maker checked for volume of water dispenser during harvest, should be 5.5 oz. (2/3 cup), if more the 6 oz. the ice maker is bad. If fails to stop filling or leaks/drips, replace the water valve behind the unit.
I hope this helps.
Aug 27, 2011 | KitchenAid KBFA25ER Bottom Freezer French...
Icemaker not workin water dispenser is working fine
Looks like your fridge is not very old. Common problem is a clog inside the ice maker. It's a pain to do, probably easyer to get it fixed unless you have a long time to wait for a service call or live in an area without service. Anyway clog is most likely about an inch from the in take line inside the ice maker.
Take out the ice maker or turn off the freezer untill it thaw's then use a tooth pick or THIN ice pick to push the clog through to the actual freezing tray, wash out the tray and re start the ice maker.
Good luck....
Aug 01, 2010 | Whirlpool Refrigerators
Model #ed5ftgxkq01 ice maker stopped working
Hi
Hope this helps.......
Ice maker won't let in water.so it won't make ice.
clogged tube to the ice maker from the valve...or bad valve. As long as you see the ice maker turning and no water comes in, it is one of the 2.
take the head off the ice maker and put a jumper wire between the letter
l and the letter v...stick the wire in the 2 holes...make sure the part you are holding is insulated. Water should go right into the icemaker....if not you have a bad valve or clogged tube
Nov 12, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
Ice Dispenser clogged with frozen ice
I have the same problem. Found this posting:
http://www.applianceblog.com/mainforums/sears-kenmore/10491-kenmore-ice-maker-dispenser-door-shute-clogging-missing-heating-element.html
Maybe our heater is not working?
Jul 05, 2009 | Kenmore 5553 / 655532 / 55534 / 55539 Side...
No ice from ice maker
sounds like the inlet valve is defective. you should have a dual water inlet valve, one side for the dispencer and the other for the ice maker. I would check to be sure the inlet for the icemaker is not clogged, also check to be sure that ice has not clogged the water line near the ice maker, or the valve could be defective.
Feb 20, 2009 | Frigidaire Refrigerators
Ice maker
ice tube for ice maker keeps clogging with ice . I repeatedly remove and clear it only to find it freezing again. This only happens when the ice maker is turned off for a couple of days.
Oct 18, 2008 | Frigidaire FRS6R5EMB Side by Side...
Refrigerators Logo
42 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
