Question about Kenmore Heating & Cooling
My kenmore window unit AC started blowing a white smoke like substance. It seems to be cooling fine. What is this and is it a concern?
    Problem Solver:
  • 6 Answers
The two things it could be, #1 - evaporator leaking refrigerant - unlikely if unit is still cooling o.k. because window units do not hold a lot of refrigerant and if there is a leak bad enough to blow smoke it would have stopped cooling by now. #2 - the humidity is high and the unit has cooled the air right at the discharge down below the dewpoint, a common occurence in window units and automobiles due to the short duct distance from the evaporator to the air outlet whereas with central air systems having longer duct systems the air gains more heat before being discharged into the room.
Posted on Aug 30, 2010
  • jarrett vachon Oct 01, 2013
    so is it bad to keep running it?
  • KERO87 Oct 01, 2013
    Nope. If it's cooling and there's no foul/burnt/unusual odor, it's perfectly fine.
Blowing white smoke
If you have overheated your car recently, then you possibly have a blown head gasket. Take off your oil fill cap (with engine off) and inspect to see if there is a milky substance underneath the cap. If so, bad news- head gasket. You can also check the oil dipstick for the same substance to verify bad head gasket, but usually it has to be pretty bad (gasket) or driven for a while before exhibiting any signs. The oil fill cap is a pretty good indicator. With the car cool, you can open the radiator cap and look and smell for anything other than coolant (fuel smell or oil slick). If so, probable head gasket.
Oct 24, 2015 | 2003 Nissan Sentra
I have 2002 GMC Envoy. Didn't over heat but when you turn it on it blows out white smoke and when you accelerate it blows out even more. I pulled over when this happened my gauges showed all was fine and...
White means coolant in the cylinder. With high mileage, the head can crack without over heating. Check the oil filler cap for a milky brown substance to prove there's coolant and oil mixing.
Jan 22, 2015 | GMC Cars & Trucks
Smoke comes out ac unit in my car
yes your not seeing things im ase certified in auto ac,ford,chevy honda, also. what is happening is fine dust from the ac evaporator ,inside the air tubes and sometimes fog and moisture all can come out you only need to worry if the system starts blowing out ice crystals or it gets worse then it will need to be looked at.
Jul 29, 2012 | 2002 Ford Focus
My window ac looks like it is blowing out a fine foggy looking substance but it is cooling ok and I cannot smell any smoke or burning wires. We had a cool front move through with lots of rain this morning....
Shirley, it's just a harmful mist. This usually occurs on hot, high humidity days. Keeping the air intake filter clean, will help to reduce it.
I hope this helped you and thanks for choosing FixYa.
Aug 10, 2011 | Goldstar R1203 Air Conditioner
I have a fac 127 it,s blowing out smoke when the
dont really think its smoke just water vapor, the difference in temp causes this. iassuming it doesnt do this all the time may be alittle dirty when you can pull the unit out take it to the car wash and give it a bath dont spray the controls and let it dry good before starting it back up make sure your filter is clean and remember ac units remove heat they dont add cool i know this sounds confuseing but thats how they work and dont worry about the vapor its normal when you fire it up.
Jul 11, 2010 | Frigidaire FAC126P1 wall/window Air...
My T1760 blows white smoke for 60 sec when starting
it could be your choke stuck, but check you oil level and smell it does it smell like fuel. if so have your carb check out. Little lube on the chock lever. you may want to have your compression check and a leak down test done.
Oct 11, 2009 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Rpm drops while adling causing 'grinding' sound while white smoke flows from behind or below radiator.
You should replace the cooling fan. With the ac on and no cooling fan, high pressure builds in the condensor and compressor bogging the engine down. When it gets too high a relief valve dumps and you get what appears to be white smoke. It's actually freon, hence the smell. I've replaced several PT cooling fans with the same symptoms.
May 16, 2009 | 2007 Chrysler PT Cruiser Touring Hatchback
Hello, I have a Kenmore 580.75124500 ac/heater
It is probably the compressor. You will need to check if the compressor is being called to come on. Do you hear the compressor running? If you do, I would remove the unit from the wall or window, and wash it down real good with a hose being careful not to get the electronics wet. If not and the unit sound different than it did before, it's probably time to buy a new one.
Mar 31, 2009 | Frigidaire FAC125P1A Window Air...
Lexus ES300 White smoke out the exhaust no milky substance in oil
It could be the intake gaskets or even still the head gasket. How about the coolant ? Did you refill with same type coolant ? Have you noticed if it's thick and gooey ? mixing coolants will sometimes produce a thick gooey coolant that clogs up the cooling system. If the car ran hot it could also be a cracked head or block. Warped heads also. Somehow the coolant seems to be getting into the cylinder(s).
Feb 08, 2009 | 1992 Lexus Es 300
2003 Dodge Durango A/C started to smoke
There are a lot of variables with A/C concerns. Without being able to answer these, the smoke you saw was originating from the clutch? If so, can you see any kind of oil seeping from the seal behind it? You might also look for oil stains on the hood blanket above the compressor. If there is oil present, you may have a seal leaking causing premature clutch failure. Since you were in traffic at a stop, you might want to check the condensor and the radiator for any kind of obstruction. Also that the fan is coming on when the pressure starts to rise. If you have an oil leak it might be a good time to replace the compressor. If not, it could be just an early clutch and bearing failure. Also, don't forget to check the belt for overheat damage.
Jul 25, 2008 | 2003 Dodge Durango
Heating & Cooling Logo
3,121 people viewed this question
Top Kenmore Heating & Cooling Experts
Ronny Bennett Sr.
Ronny Bennett Sr.
1STHVACMAN
Bill Long
Are you a Kenmore Heating and Cooling Expert? Answer questions, earn points and help others
