Question about Canon PowerShot A610 Digital Camera
Canon A610 Problem - there appears to be condensation or something similar on the inside of the lens which effects every picture taken. Is it difficult to dismantle the lens and clean? Rick
  • Anonymous Jul 29, 2008
    Looks like some contamination/condensation got into the lens. It forms a translucent spot that disappears when the zoom is about midway and up.
    CANON WAS NOT VERY HELPFUL WITH THIS PROBLEM.
    How to disassemble the lens assembly would be helpful.
  • 36 Answers
I wouldn't recommend taking this camera apart unless you are quite skilled with electronic repair. Even then camera lens assemblies are somewhat of a specialty area. So I guess the answer to your question is yes they are difficult to repair. A good camera repair shop should be able to help you for around $70.
Posted on Jun 13, 2008
Halo around main subject
Check for dirt on the front element of the lens. I am always amazed that almost every point and shoot digital I see has a filthy lens.
This can also be caused by condensation inside the lens or on the rear element
Feb 03, 2013 | Canon PowerShot SD550 / IXUS 750 Digital...
Hi, I have a Cannon Powershot A610 and when I take a picture the picture comes out too dark. How can I adjust the it? thanks
"Too dark" or do you really mean "totally black"? I'm asking because a stuck shutter is a very common failure mode for your particular model camera.
The symptoms of a stuck or "sticky" shutter are very similar to CCD image sensor failure. The camera may take black pictures (for shutter stuck closed), or the pictures may be very bright and overexposed, sometimes with lines, especially when taken outdoors (for shutter stuck open). To confirm a stuck shutter, put the camera in any mode other than "Auto", and turn the flash OFF (you don't want to blind yourself for the next step). Next look down the lens and take a picture. You should see a tiny flicker in the center of the lens as the shutter opens and closes. If no movement is seen, then you likely have a stuck shutter. If so, please see this link for further info and a simple fix that may help.
Apr 06, 2011 | Canon PowerShot A610 Digital Camera
Blank screen on Canon A610 Power Shot. Can't view pictures taken or from memory card.
Are the downloaded pictures also black when viewed on your computer? If so, a stuck shutter is another common failure mode for digital cameras. The symptoms of a stuck or "sticky" shutter are very similar to CCD image sensor failure. The camera may take black pictures (for shutter stuck closed), or the pictures may be very bright and overexposed, especially when taken outdoors (for shutter stuck open). To confirm a stuck shutter, put the camera in any mode other than "Auto", and turn the flash OFF (you don't want to blind yourself for the next step). Next look down the lens and take a picture. You should see a tiny flicker in the center of the lens as the shutter opens and closes. If no movement is seen, then you likely have a stuck shutter. If so, please see this link for further info and a simple fix that may help.
Apr 18, 2010 | Canon PowerShot A610 Digital Camera
Blank Screen on a Canon Powershot A610
A stuck shutter is another common failure mode for digital cameras. The symptoms of a stuck or "sticky" shutter are very similar to CCD image sensor failure. The camera may take black pictures (for shutter stuck closed), or the pictures may be very bright and overexposed, especially when taken outdoors (for shutter stuck open).
To confirm a stuck shutter, put the camera in any mode other than "Auto", and turn the flash OFF (you don't want to blind yourself for the next step). Next look down the lens and take a picture. You should see a tiny flicker in the center of the lens as the shutter opens and closes. If no movement is seen, then you likely have a stuck shutter. If so, please see this link for further info and a simple fix that may help:
Dec 30, 2009 | Canon PowerShot A610 Digital Camera
Cannon powershot610
Dec 28, 2009 | Canon PowerShot A610 Digital Camera
The powershot a610 will not take pictures screen is blank. it will show previous pictures but nothing new
Dec 18, 2009 | Canon PowerShot A610 Digital Camera
Canon A610 Lens problem
Unless you have prior experience dismantling a digital camera, it could be quite tricky.
HERE is a service manual that should help. Its not the A610, but they are similar.
If your camera has a plastic ring around the lens, then it should be quite simple. Use a jeweler's screwdriver and try to pry out the ring. Once that is done, it should be easy enough to remove the lens barrels.
However, like I said, if you are not too familiar with this, it is best that you get it done by a pro. If it costs too much, then try giving it a shot yourself (nothing to lose anyways), and if you should screw up, there is always the option of buying a new camera :)
May 09, 2008 | Canon PowerShot A610 Digital Camera
E 18 problem
broken lens on Powershot SD600
Feb 17, 2008 | Cameras
LCD black in shooting mode only
Defective CCD. Just happened with our A610 as well. Oddly enough just had our Canon ZR85 camcorder repaired about 1 month ago (for free) due to this same problem. Sounds like Canon isn't as forthcoming with the A610 tho. We called today and they said $100+ to repair or replace, but the following link seem to indicate that if you're persistent you can get them to fix for free. Now the battle begins ...
http://forums.cnet.com/5208-7593_102-0.html?forumID=58&threadID=243034&start=0
Dec 04, 2007 | Canon PowerShot A610 Digital Camera
Canon PowerShot A610 Digital Camera Logo
282 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
