Question about SanDisk Sansa e260 MP3 Player
Sansa e260 mp3 player
When i plug the usb to the usb port, i keep gettin a message that says, "usb device not recognised". what can i do, if anything, to get the pc to recognise it...it just recently started doing this.
  • Anonymous May 08, 2008
    i conect my mp3 pleyer to my conputer and the mp3 said conected but i go to my computer to open the mp3 folder,but in my computer no't apier eny mp3 files and my mp3 said that is conected
My e260 sansa mp3 player dont recognized by computer what to do
Posted on May 06, 2008
Sansa e260 mp3 not recognised as a device on my computer
An Update: that yellow square means that it is not recognised, I missed it on the first read through. It means you do not have the required driver to run this application. First port of call is Microsoft Support and see if they have any thing, else Google it and try to find a free one that supports your player. Sorry about my previous post.
Jan 01, 2010 | SanDisk Sansa e260 MP3 Player
Sansa e260 player not recognized by window
(http://mp3support.sandisk.com/sansa/Installer/1082/SansaUpdaterInstall.exe) . download and install Copy and paste click run to install follow instructions make sure your sansa is in msc usb mod in the settings in the sansa
Jun 07, 2009 | SanDisk Sansa e260 MP3 Player
My XP system does not recognize Sandisk Sansa e260
The XP did not recognize the device because I used a after- marked USB expander board that did not provide enough power to the device. Plugging to the Motherboard - attached USB port solved the problem.
Mar 20, 2009 | SanDisk Sansa e250 MP3 Player
Not charging and down loading form computer
Just had the same problem, found solution on another thread
Switch Off
Put side switch to hold
Press in middle button, keep holding in while you plug into usb port and keep pressed for a few seconds after.
Computer should recognise it and will keep charging.
Worked for me
Feb 04, 2009 | SanDisk Sansa e260 MP3 Player
My Sansa e260 Mp3 player isn't recognised by Windows and will not show up as connected.
e200 is the generic name for the entire e-series including the e250, e260, and e280. The only difference between the models is the amount of internal memory. The e200 driver is used for all models in the series, and the e200 manual likewise covers the series.
Oct 23, 2008 | SanDisk Sansa e200 MP3 Player
Mp3 player won't turn on/won't charge
make sure the hold switch is in the unlocked position. otherwise the player will not charge or be recognized w/ the USB port plugged in.
Jul 10, 2008 | SanDisk Sansa e260 MP3 Player
Blue ring of death
Either the device is bad, the pc port is bad, or the software is faulty. Try connecting to different usb port, then a usb port on a different pc with a compatible os. If still not recognized, then there is physical damage to player.
Try this: disconnect the player from the computer, turn it off, hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware.
Wizard
Jul 05, 2008 | SanDisk Sansa e260 MP3 Player
How do I get my Sansa e260 to appear in Windows Media Player (v. 11; Vista)?
Try this: disconnect the player from the computer, hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard.
May 12, 2008 | SanDisk Sansa e260 MP3 Player
Sansa e260 says connected but device not recognized
I agree with the above suggestion. Try setting the USB Mode under "Settings" on "MSC" on the Sansa. My computer would not recognize the e260 when the mode was set to "MTP"; works fine on "MSC".
Dec 27, 2006 | SanDisk Sansa e260 MP3 Player
SanDisk Sansa e260 MP3 Player Logo
69 people viewed this question
Top SanDisk Audio Players & Recorders Experts
Gyula Lacz
Computer Repairing
Computer Repairing
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
