Question about Bosch Freezers
The edge and top of my freezer is warm..is this normal??
  • 21 Answers
Yes you have heater wires or hot gas pipes around frame to stop condensation. hotter the day the hotter the frame is
Posted on Sep 02, 2010
Kenmore upright freezer hot on the sides, stop freezing
Without the model number I'm not sure how to answer your question. Does your model have fans that blow warm air on the outside bottom or a front kick plate? What is your model number? Kenmore has model numbers like this example=> 123.3214567 If the fan has a restriction that causes a lack of airflow it can cause the hot Freon liquid that normally flows around the Yoder Loop inside edges of the freezer door to prevent frost buildup to become very hot because the condenser fan is defective or coils are dirty with dust restricting airflow. If the outside is hot you may have a defective condenser fan motor. That will cause the freezer to ger hot. I am here should you want my assistance....Sea Breeze
Kenmore Freezer Parts
Aug 31, 2013 | Kenmore 14.1 cu. ft. / 399 liter Upright...
Our Thermador Freezer door seals so hard after being opened that you can't open it again. Why? Also Sometimes after opening it makes this weird gurling/bubbly noise.
thermodynamics: pressure differential when warm air cools causing a difference in pressure. after closing a freezer wait until the pressure equalizes usually within 10-15 seconds then reopen the freezer. as far as the gurgling this is normal. it is the drain tube usually a J type tube that prevents warm air from returning into the freezer.
Jan 15, 2013 | Thermador Freezer FREEDOM® T24ID80PLS
The side of the freezer stays hot all the time. I think the defrost cycle is on all the time
The sides are warm because the coils that used to be in back or underneath are now inside the walls of the freezer. It is normal for them to be warm when the unit is on.Hope this helps.
Jun 23, 2011 | Kenmore 20.3 cu. ft. / 575 liter Upright...
The outside of the freezer sides are extremely hot to the touch? Why? Freezing fine on the inside.
the coil normally on b ack of fridges is on sides of freezers under skin it is normal to be warm. The hotter the weather the hotter the skin.
Sep 02, 2010 | Frigidaire 20.3 Cu. Ft. Frost-Free Upright...
Describe your FFU2124DW12 Problem The freezer works very good and gets very cold, But the outside walls and top gets EXTREMLY hot
Freezers have tubes that run inside the walls and top of the case, these carry the refrigerant thru the heat exchange process, this will cause the outsides and top of the freezer case to get warm/hot some times, this is normal, but I recommend you to make sure there is at least 1 1/2" of ventalation clearance around the entire freezer so that it can exchange heat efficiently.
If you don't think the amount of heat present at the outside of the freezer case is NORMAL, then I recommend contacting Frigidaire directly and discuss this with there customer service people.
1-(800)FRIGIDAIRE
GOOD LUCK !!
Aug 03, 2010 | Frigidaire Freezers
Top of upright freezer is warm and bottom is a frozen
sounds like heating element has gone bad
Nov 24, 2009 | Freezers
Is it normal for the outsides to get very hot
No. If you feel the sides getting hot, it usually means that the ref. isn't cold enough inside. There us either an electric heater or a pass of the hot gas from the compressor around the edges of the doors as well as the mullion between them. If they feel hot, it's too warm inside.... Check the ice cream: It's the 1st to go.
Oct 25, 2009 | Frigidaire Freezer Refrigeration White...
My parents just gave us their old freezer. The sides and top are quite warm, though the cooling unit seems to be working inside. Is that normal?
No it's not normal. Make sure the condenser fan underneath near the compressor is running when the compressor run.
Sep 19, 2009 | Freezers
Frigidaire frostlfree upright freezer ice forming top interior door
Not sealing. warm air hitting cold air causing frost. also, door frame heater may not be working. most frames are "warm" to the touch. normally called an "anti sweat" heater.
Jul 15, 2008 | Freezers
Leakage and warm sides
The outsides should will be warm.  This is normal because the condensor lines run thru the cabinet from about half way up the sides and over the top.  Which is why the you shouldn't have anything stacked on top of the freezer and enough room on the sides of it for air flow.  As far as the water leak, tell me exactly where you see the water and does the bottom of the freezer (inside) have a sheet of ice on it.  If there is ice there then the drain behind the bottom panel in the freezer is frozen over and will have to be thawed out.  Let me know what you find.  If you have further questions I may need the entire model # on the sticker inside the freezer.
Oct 21, 2007 | Kenmore 14.1 cu. ft. / 399 liter Upright...
Freezers Logo
60 people viewed this question
Top Bosch Freezers Experts
Charles T Nevin
Charles T Nevin
Victor Nwachukwu
Victor Nwachukwu
Are you a Bosch Freezer Expert? Answer questions, earn points and help others
