Question about Sharp 32C-240 32" TV
I have had my sharp tv for a while now just because i refuse to throw it out. The tv worked perfectly for just over a year then it started to fail badly. I can turn the tv on for about 10-20 minutes then it will shut off on it's own. After it shuts of I can turn it back on and it will turn right off again. Like it is overheating but it is not hot at all. Now it just sits in a corner until i can figure it out.
  • 70 Answers
Actualy what happen is when it worked over 20 min the set will worm and the circuit little bit bent so some power supply component or cable connector losen and disconnect the power to the some section.
pls re solder all component and cable connectors spacialy horizontal out put system control and power supply
Posted on Aug 26, 2010
Sharp LCD TV Takes Too Long to Turn On
Your TV main board is failing, soon it will not turn on at all, plan on buying a new one soon.
Aug 12, 2016 | Sharp Televison & Video
I have a 32SC260 32' sharp tv. The tv has work perfect till tonight. I had left it on in my bedroom while cooking and when i came back it was off. I tried to turn it on and it just clicks. What is wrong...
Unfortunately, your TV has a serious problem. The Power Supply has died. The problem is either your low voltage power supply has failed or something is the load has failed causing the low voltage power supply to fail. You will have to have a TV repairman to fix this problem. Price of part and labor is around $125.00. If the TV is over 5 years old. Recommend you buy a new one. Sorry for the bad news. Handy Henry
Jul 26, 2009 | Air Tools & Compressors
Sharp Aquos LC-32D41U pictures problem
I have had exactly the same problem. Sounds daft but by not using the remote, and only using the power on/off switch on the TV itself, it is working perfectly...no idea why
Use the remore for changing programmes etc but not for on/off
Try it anyway because I know how annoying this is
Mar 29, 2009 | Sharp LC-32D41U 32 in. LCD Television
Cyber home dvr 1600 problem
Hi. I have one of these units with the same problem
Mine will play audio CD's OK but DVDs are troublesome. I asked around on various forums and it appears that the DVD laser in the unit has failed or is on it's way out. (There are usually 2 lasers: one for reading normal CD's and one for DVDs).
I have noticed that my unit gets quite hot when in use and has very poor ventilation. Unfortunately any build up of heat can cause the laser diodes to malfunction and eventually fail and I think that's what has happened with mine.
If you still have a guarantee on your unit you could try and get it repaired otherwise it will be an expensive job and it may be cheaper to get a new unit.
Hope this helps
Sep 01, 2008 | Cyberhome DVR 1600 DVD Recorder
Way too dark screen during night scenes on sharp 32" standard screen
patrioticdog-I have just answered a similar problem, you can remove the back and find the flyback transformer. The big part with the round rubber plug hooked to the pix tube. there will be two controls on the flyback one for focus one for screen. turn up the screen ever so slightly,your screen will brighten up.Also if you check the main pcboard ass'y there may be a sub bright control same thing small adjustments. maybe tell the guy to give a bit off cause of repair ,good luck let me know. cooltek Feb15/08
Feb 13, 2008 | Sharp 32F540 32" TV
Toshiba 43vs9ua rear projection tv picture problem
I also had a same one but had the same problem. Thinking of throwing it away!
Dec 25, 2007 | Televison & Video
Sharp 28JW73H Green tint with lines across screen
Note: unmatched Make / model info........please clarify...T.
Nov 16, 2007 | Panasonic PT-52LCX66 Projection Television
Sharp TV/video toggle problem
FLYBACK TRANSFORMER FOR SHARP TV MODEL 21 REQUIRES REPLACEMENT WHERE CAN IT BE URGENTRLY OBTAINED
Jul 11, 2007 | Sharp DVHR300U 109-Hours Video Recorder
Sharp 32C-240 32" TV Logo
47 people viewed this question
Top Sharp Televison & Video Experts
Jaime Hernandez
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
