Question about Xerox Office Equipment & Supplies
My Xerox 3060 copies are blank. No image on paper. No error codes.
  • 52 Answers
Remove the chargers wash it with water and soap dry it ,replace the corona wire, and clean up the machine.
Posted on Aug 27, 2010
Xerox printing all black pages
You have no light output. The system places a charge, the image will remove charge (without image processing, the system leaves full charge ) (removes charge where no image is if negative processing)
EX: a copier has platen closed makes a copy because the cover has a white surface the light is reflected and removes charge from Drum. If you make a copy with platen open out put will appear black. Charge was not erased, toner is attracted to charged area.
Most systems use a small wire to place charge, depending on what development (pos or neg) with broken wire will also result in either a black or blank output. I would look for a broken charge wire.
Mar 05, 2014 | Xerox Corporation Xerox ColorQube 8900X...
Why do we have blank copies on Xerox XC830?
is it problem when you try to copy vis adf or its aucord in platen glass also?
Sep 17, 2012 | Xerox Office Equipment & Supplies
Xerox 4150 my paper is a light shade of grey, what can it be thank you
Giacomos,
Is the paper a shade of grey with no image? or is there an image with a grey background?
If there is a image with a grey background you should try a new toner module. If that doesn't resolve the issue, clean the xerographic drum, make 10 blank copies, if the cleaning doesn't resolve the issue than install a new xerographic module.
Hope this help.
Apr 05, 2011 | Xerox WorkCentre 4150 Black and White...
I just received a Xerox 5334 copier. We moved it to our house, powered it up, and ran a test copy (just a sidebar thought...it spit out one copy and a blank paper). I left it on to go retrieve the work I...
Code U4-1 is Over heat or under heat, even if you solve this problem you mentioned that you have a copy from the machine which is Blank, the reason is that the print cartridge is dead, it is not holding charge, and even if you find a new one in a box sealed, I am 99.9 present sure that it is not going to work either, it is an old expired cartridge, basically do not waist your time and money, I serviced these machines and I know.
Mar 23, 2017 | Xerox Office Equipment & Supplies
Xerox 7700. Paper is jamming at lower tray and bypass tray. Will print one page fine but multiple pages it stars jamming
Hello. The Error 11, polygon motor failure is usually caused by the motor controller chip going bad on the mirror motor. We found some of the contorller chips and had them replaced. The refurbished laser units can be seen at: http://www.lpscomputer.com/p-3060-1-116-1110-00-laser-unit.aspx
Nov 18, 2010 | Xerox Phaser 7700 Laser Printer
Hello, I have a problem with my copier (xerox dc 432st).
On this machine, the image is transferred by a black roller on the side door.
Check to see if this roller is in place correctly. If it is too old you may have this problem, and needs to be replaced.
If you can run a copy pull the door when it makes the copy half way on the drum, then pull out the drum and see if there is any image on it. This will show you the xerographic part of the copier is ok.
Pull out the cartridge and check for the grounding contacts make sure they are in place correctly.
When the door is closed there is a black plunger on the inboard end that pushes in. Make sure it is pushing in all the way and not stuck.
Check inside the view of the exposure box just above the copy cartridge, make sure there is no paper in there blocking the view of the image to the drum.
When you close the side door make sure the door is fully closed on both inboard and outboard side.
Other than this, call Xerox for a repair.
Apr 01, 2009 | Xerox Document Centre 332 DC Printer
XEROX CopyCentre C20-Blank stripe going down side
Open the cover and put a piece of paper on only half the glass, and make a copy. BLOCK the left side of the glass with the blank paper.
See where it is blank. Most of the times that is a dirty or haved up mirror in the scan head. One of the small mirrors in the black assembly under the lamp. When a digital copier scanner optics become dirty, the image in that area becomes very light .
Mar 18, 2009 | Xerox CopyCentre C20 Black and White...
48 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Michel
Xeroxrep
Level 1 Expert
Philip Hughes
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
