Question about RCA D52W20 52" Rear Projection HDTV-Ready Television
I push power on, tv does not turn on. - RCA D52W20 52" Rear Projection HDTV-Ready Television
  • RCA Master
  • 17,129 Answers
The reasons can be many for a power failure, but check on:
1. start by checking the continuity from the plug to the main board.
2.Check the fuse on themain board, if fuse is blown check for shorted circuit. check on surge protector, rectifier, filter capacitor or the SM driver.
3. If the SM is not working then the oscillator IC can be faulty.
4. if the SM power supply works but the main board does not , check voltage to all circuits. check for pico fuses being open.
5. The microprocessor must work on the man board. if so the trigger or indiccation LED will light up.
If no trigger check mP then the drive stages of the projector.
Hope you follow on this advice.
Posted on Aug 26, 2010
Where is the power button of this aquos cardio vision tv? Is there any other way to turn on tv?The power button on remote can't work today.
First thing if there's a TV Button they pushing cause someone might of pushed the SAT or. DVD button. If that don't work check your battery's. some times I tap mine for hand hand lightly and then it works Good luck
Mar 19, 2013 | Televison & Video
Will not turn on?
the lightining battery is not working very well. You should exchange it, so the TV power could get to the Tv and let it Work.
Feb 28, 2008 | RCA F36685 36" TV
How do i program my remote
Hello;
Without knowing the codes for the specific brand names and models of your devices, this is how you program the Zenith MBR3447 for your TV, VCR, DVD Player, CD Player or Audio Receiver:
TV
1. Push the "Power" button on the TV to turn it on.
2. Press and hold the "PRG" button in the upper left corner of the remote. Release when the indicator light, located in the top center of the remote control, comes on.
3. Push the "TV" mode key located at the top of the remote.
4. Enter 0 -- 0 -- 0 on the remote's number pad, then press the "Enter" button.
5. Aim the remote control in the direction of the TV's IR sensor and push the "Power" button. Pause a second. If the TV fails to shut off, push the "Power" button again. Repeat until the TV does shut off. Each time the "Power" button is pressed the Zenith MBR3447 tries using a different TV device code from its code library to turn the TV off. Therefore, when the TV finally does shut off it's an indication that the remote is temporarily programmed with the correct device code to control the brand of TV you're using.
6. Press "Enter" to save the current code.
VCR
1. Push the "Power" button on the VCR to turn it on.
3. Push the "VCR" mode key located at the top of the remote.
5. Aim the remote control in the direction of the VCR's IR sensor and push the "Power" button. Pause a second. If the VCR fails to shut off, push the "Power" button again. Repeat until the VCR does shut off. Then press "Enter."
1. Push the "Power" button on the device your programming the remote to control to manually turn it on.
3. Push the "AUX" mode key located at the top of the remote.
5. Aim the remote control in the direction of the device's IR sensor and push the "Power" button. Pause a second. If the device fails to shut off, push the "Power" button again. Repeat until the device does shut off. Then press "Enter."
Mar 11, 2011 | Zenith MBR3447 Remote Control
MY Sharp LC46D62U wont turn on
Power and OPC LED lights flashes?Common on Sharp LCD tv.Tv is still useable.Tv have Tuner signal board problems.Every times Power and OPC LED lights flashes.Just push the remote power button again and wait.Sometimes Power and OPC LED light will flashes require push power again wait again Power and OPC will flashes two or three time push power button and wait.Must do this two or three time before the backlight will light up and tv work.
Jan 07, 2011 | Sharp Aquos LC-46D62U 46 in. LCD HDTV
Tv wont turn on used it for two months and one day it turns on then the power led light flashes and the opc led light ...
This tv still under warrenty?Yes take ur warrenty repair.This problems very common on Sharp LCD tvs.I have one too.This tv have a Tuner signal board problems.But this tv still use able.Just push power button again after the POWER and OPC flashes.POWER and OPC some will flashes again and wait just push the power button again and wait.Sometimes have to push power buttons and wait power button push out of three or four times power button push POWER and OPC flashes.Than tv will work again.
Jan 06, 2011 | Sharp LC-52D64U 52 in. LCD HDTV
Aquos model LC46D64U...approx 2 years old..Won't power up and get the power light flashing 3 times then the OPC light once..which is repeated...Any ideas...I believe this is quite common with Sharp TV's
I have a Sharp LCD 46 in.tv do this often.Yes,it is.This problems,the tv Tuner signal board have problem,but the tv is still useable.The POWER and OPC light indications flashes.Just push the power switch again,wait see tv turn,not POWER and OPC flashes again,push the power switch agian and wait.Have to do this like 3 or 4 times sometimes,than the tv backlight will come on,tv will work.Don't know but,if u require to pushing power button more 10 or 12 times,the tv Tuner signal board don't take an turn on the tv backlight get the tv to work.The Tuner signal board is dead,time to replaced the tv Tuner signal board.
Oct 18, 2010 | Sharp Aquos LC-46D62U 46 in. LCD HDTV
I have a philips universal remote and I need to program it to a Sanyo T.V.
is easy to program if you don`t have the # code turn on you tv and just hold the the code seach or set up button until the red ligth stay on and then selec what do you want to program tv,vcr,etc push and let it go then push power until you tv turn off then push enter to safe the code if you push one more time after turn off you tv you have to star over
Apr 12, 2010 | Sanyo DS31520 31" TV
Tv broken?
YOU WILL HAVE TO REPLACE THE POWER SUPPLY IN THE TV
Aug 24, 2009 | Samsung LN-T4671F 46 in. LCD Television
Model CS- 40307 40 inch Mitsubishi TV will not turn on
continue to push power button until light turns green. verie rate of push and hold
Jul 15, 2009 | Mitsubishi WS-65819 TV
Tv won't turn when you push power botton
What make,and model is your TV?Open the back of the TV,and look at the can shaped items on the boards.If any of them have the tops,or bottoms bulged out,they need to be replaced.This should get it working again.I hope this helps.If you have any questions,please let me know.Thank You very much!
Tyler
Nov 01, 2008 | Televison & Video
RCA D52W20 52" Rear Projection HDTV-Ready Television Logo
Top RCA Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
