Question about Pioneer AVIC-D2 DVD Nav/6.5" Screen/AM/FM/CD Player Car Video Player
Bad Navigation I just bought a lincoln aviator with a avic-d2 and the navigation is not working properly. It constantly says my car is facing the wrong way and won't give me proper directions. I restored to the factory settings and reset the unit but it constantly says I'm facing the opposite direction.
  • kloeck Aug 21, 2008
    I'm having this same problem. When I am headed north the compass points west.
    When I go into diagnostics, it says that the antenna is not hooked up. I haven't had a chance to tear into my dash yet, but that's probably where I'm going to start.
Try pressing the red/white little arrow looking buttons on the bottom right, that' flips the screen.
Posted on Jul 09, 2008
Avic-d2 question
sometimes i notice the touch screen calibration is a little bit off...Try to push the okay button a little bit to the left or right working your way from the okay button to the edge of the screen
Jun 07, 2010 | Pioneer AVIC-D2 DVD Nav/6.5"...
Need help on how to test pioneer avic d2 on a car battery
with high output stereos you shouldn't hook them up without speakers hooked up my shortout the outputs
all you should need for power is
acc
bat+
ground
Dec 21, 2009 | Pioneer AVIC-D2 In-dash Car Audio Stereo...
Don't know how to set the clock on the Pioneer AVIC-D2 head unit
drop by your local car stereo dealer and ask them NICELY to reprogram the time for you...then, a NICE person would but the guy lunch, what $10?
Good Luck
Jun 15, 2009 | Pioneer AVIC-D2 In-dash Car Audio Stereo...
AVIC-D2 bad navigation?
what i did is, i went into the destination window and pressed the settings tab, then i pressed the hardware information after that i pressed the 3d calibration and then i cleared the section where it said hybrid 3d. after a while it worked fine.
Aug 21, 2008 | Pioneer AVIC-D2 DVD Nav/6.5"...
Some buttons don't work
Pioneer AVIC-D1 Touch Screen Recalibration
If your pioneer AVIC car navigation unit does not register your touches or the wrong button is “pressed”, you need to re-calibrate your screen’s digitizer.
1-Hold the Eject button down until the face of the unit drops all the way
2-Using a pen hold down the reset button (just above the joystick) and the navigation disc eject simultaneously.
3-Release the reset button.
4-Release the dvd eject button next. The display will read “press reset”
5-Push the joystick up two times.
6-Push the joystick down twice.
7-Press the joystick in.
8-The service menu will appear after a short pause. You can navigate the service menu using the joystick.
9-Chose the first menu option and press in on the joystick.
10-Trace the screen with a stylus.
11-"P.ADJ" is the back button
12-Chose the second menu item in order to calibrate the touch screen. Use a stylus again and tap the "+" sign on the screen. (You may have to touch slightly off center if the digitizer is damaged. In which case things will still be off but it will be much better.)
Jul 27, 2008 | Pioneer AVIC-D2 In-dash Car Audio Stereo...
The navigation is off track or something
there should be a vss wire hooked up that helps the unit know where it is.. go to the connection check screen and make sure the speed sense is pulseing
Feb 22, 2008 | Pioneer AVIC-D1 Car Video Player
Pioneer Avic D2
I suggest u to take it for a general service, this includes lubricating and cleaning and alignment.
Hoping a rating from you...!!!
Thankyou
Feb 15, 2008 | Pioneer AVIC-D2 DVD Nav/6.5"...
DVD WON'T PLAY ERROR CODE 17 &12
the d2 does NOT play dvd's,the dvd rom slot is for the navigation disc ONLY. you must hook a dvd player to the RCAs.
Oct 02, 2007 | Pioneer AVIC-D2 DVD Nav/6.5"...
Navigation
This is because it hasnt callabrated yet !! Go into the settings menu and look at gyro screen once you have travelled around 50 miles it will work correctly.
Jul 02, 2007 | Pioneer AVIC-N2 Car DVD Player
Pioneer AVIC-D2 DVD Nav/6.5" Screen/AM/FM/CD Player Car Video Player Logo
264 people viewed this question
Top Pioneer Car Audio & Video Experts
Are you a Pioneer Car Audio and Video Expert? Answer questions, earn points and help others
