Question about Carrier Heating & Cooling
Carrier Model # 50SS-030-301 Serial #: 2594G41362 Refigeration # 22 - 3.5 lbs 1.5kg does not have sufficient air flaw is that normal? Freon # 22 has the right amount of GAS FREON 3.5lbs I found out that the radiator is freezing on very the lower portion only not complete I also cleaned the fan area the only problem is that it is not cooling much and faster. Please advice.
    President:
  • 2,559 Answers
If any part of the coil is freezing then there is a restriction inside the line and the unit needs to be recovered and vacuumed and recharged to proper level
Posted on Aug 26, 2010
How much R22 should my unit hold when fully charged
If it has enough freon to freeze up then its not that low. Normally a 4-5 ton cooling only (non heatpump) will hold 7-9 lbs r-22 or 9-11 r-410a. Freezing can be caused by dirty air entering side of the coil also. Or slow blower
Jul 08, 2015 | Heating & Cooling
What type of freon 5695
Hello Friend, this is Z. Thank you for your post!
I understand that your inquiry is listed under Frigidaire Air Conditioner and that you would like to know what type of Freon 5695 is. You may typically locate information regarding the Freon on the serial tag (which lists your model number) of your air conditioner. You can normally find the serial tag behind the front grill by the air outlet or on the inside of the cabinet. Hope this helps!
Jul 14, 2014 | Frigidaire Heating & Cooling
I have ingaged my ac clutch i cant get the air cold i have put freon in it but it wont take more that 35 lbs any ideas
I sure hope you don't mean 35 lbs of freon !
When the ac compressor is running, the low side will read 30-45 psi under normal conditions. The high side should be around 250psi.
You need to be able to check both low and high to see if the system is full of freon. It holds around 4 or 5 cans total depending on make and model. Thats about 3 lbs.
Aug 06, 2012 | Cars & Trucks
Wiring diargram for copressor and capaciter for model number 50SS-030-311
http://www.docs.hvacpartners.com/idc/groups/public/documents/techlit/50hs,ss-c1w.pdf
Jun 08, 2011 | Carrier Heating & Cooling
I have arctic air commercial freezer m # F2CW11 s/n# WB338336 freon R134a what psig ? low side and high side when system on
Good day,
When running, the low side is usually about 2 to 4 lbs pressure. The high side is determined by the load and the temperature in the room or area. Minimum 125 lbs. maximum approx. 150 lbs.
Oct 28, 2010 | Arctic Air 22 cu. ft. Commercial Freezer...
Can ypu please tell me the weight of the next chiller: MODEL: 50TJ-028-6B1YA SERIAL: 2806U15500 Or technical information Thanks
DEAR SIR
CARRIER STANDARD EFFICIENCY AIR-CONDITIONER,S DATA ARE GIVING BLOW:
Specifications:
ELECTRIC/ELECTRIC, HEATING & COOLING 50 SERIES - CONSTANT VOLUME, VERTICAL SUPPLY AND RETURN
MODEL
NUMBER
NOM
TONS
NOM
CFM
NET
COOLING
(Btuh)
NO.
COOLING
STAGES
EER IPLV
TOTAL
kW
HEATING CAPACITY (kW)
(kW@ 460/3/60) WT
(lbs)
DIMENSIONS
(in.)
Length Width Height 50TJ028
25
7,200
268,000
9.3
30.9
32 / 55 / 80
1,850
86.125
83.5
47.25
HOPE ANSWER THE QUESTION
THANK YOU
PLEASE VOTE1
Sep 29, 2010 | Carrier 50TJ028 Rooftop Electric Cool Air...
How much Freon R-22 usually require to fill up an empty Air Conditioner. My AC model number is 38CKC060370. Thanks
On the manufactures tag, it will list the pounds and ounces, that is required, this usually includes, about 25 feet of line, usually add 1 1/2 ounces per foot past that.
Sincerely,
Paul
PS. It is best to weight the charge in with electronic scales designed for this,
May 10, 2010 | Carrier 38CKC036 Air Conditioner
Looking for freon capacity for 5 ton goodman package unit, cannot read serial or model number.. unit is 1998-2000 model ,, we just replaced the accumulator and we are not sure how much freon to put in.....
check low side which is the bigger of the two, make sure you tighten the hose good. your reading should be 65 psig.If not add refrigerant/r22 . if r410a 110 to 115.
Apr 14, 2010 | Goodman GPC1342H21A Air Conditioner
Instructions to charge carrier38ycc unit
You use the low side port to charge the system, you need to have a gauge set to do it however, if yo have a gauge set the low side is the smaller port than the larger high side the third port is a test port.
Aug 14, 2009 | Carrier Heating & Cooling
Heating & Cooling Logo
360 people viewed this question
Top Carrier Heating & Cooling Experts
Dan Webster
Dan Webster
Donni Steen
Bill Long
Are you a Carrier Heating and Cooling Expert? Answer questions, earn points and help others
