Question about Stoves 1000DFDL Dual Fuel (Electric and Gas) Kitchen Range
This gas cooker only had the gas connected oct 2009 since then i have had trouble with 6 out of the 7 burners staying lit. now i only have one of the wok burner working sometimes one of the others will light for a while then will go out the gas supply has a bull bottle connected at present
Having same problem. Only have stove 'sterling' going about 2 months now only the small ring will work. Runing on bottle LPG.
Posted on Sep 15, 2010
My ignition exploded after I spilled soup over it, now nothing works on my gas cooker
Hi Ruksana:
Your gas cooker will either have a pilot light (flame) that stays lit all the time, or an electronic spark that continues to function until a sensor tells it that the burner has lit.
In either case, if you spilled soup on it, the function has been compromised.
I would suggest that you turn off power and gas to the stove, and then thoroughly clean it. Then turn the power and gas back on and try to start it.
If it works, Happy Happy.
If it does not work, since both gas and electricity can be dangerous, I would suggest that you enlist the aid of a qualified service person.
The costs will be small compared to hurting yourself.
Stay Safe!
Cheerfuls.
Apr 26, 2016 | Kitchen Ranges
Technique model 89759. Where can I get a user's manual?
pressure cooker manual & recipe booklet library ' hip ...
www.hippressurecooking.com/pressure-cooker-manual-library/
Dec 14, 2015 - Free downloadable copies of pressure cooker instruction manuals for stove top ... Farberware Quick Cuisine Pressure Cooker Recipe Booklet .... SunbeamPressure Cooker Manual; Technique Pressure Cooker (see Deni); T-fal ... Tower (see Fagor for similar models); Tramontina Pressure Cooker Manuals ...
Technique Oval Talking Electric Pressure Cooker Manual ...
www.hippressurecooking.com/technique-oval-talking-electric-pressure-c...
Oct 7, 2009 - Technique Oval Talking Electric Pressure Cooker Manual. 44 ... ForTechnique Pressure Cooker model numbers: 99800, 99801, 99802, 99803, ...
Technique by Cook's Essentials Digital Pressure Cooker ...
www.hippressurecooking.com/technique-by-cooks-essentials-digital-pres...
Oct 18, 2009 - For Cook's Essentials Model Number: DYB350 Please wait a moment for ... Technique by Cook's Essentials Digital Pressure Cooker Manual.
Jan 19, 2016 | Home
I hav whirlpool accubake.oven wont stay lit.it ignites then flame goes right back out
Whirlpool oven won't light - Appliance Repair Forum
forum.appliancepartspros.com/oven.../225907-whirlpool-oven-wont-lig...
May 19, 2011 - 10 posts - ‎2 authors
I have a Whirlpool Accubake oven (SF362LXSS0) that doesn't seem to be consistently turning on, and the problem's getting worse. ... If I try to turn it on to bake, I hear several clicks, but not that "gas oven turning on" sound and no heat comes out (but a slight smell of gas is ... Whirlpool Gas Oven won't stay lit
1 post
Oct 25, 2012
whirlpool oven won't stay on
1 post
Aug 13, 2012
Whirlpool Gas Oven Will Not Stay Lit
Jun 20, 2012
whirlpool accubake oven will not stay lit
1 post
Nov 9, 2009
More results from forum.appliancepartspros.com
Whirlpool Accubake Model # GW395LEGQ4 - Oven won't Start ...
Dec 12, 2015 | Stoves Ovens
Pilot light lit but not igniting to heat water
pilot lit on gas furnace, but the burners won't light (Home ...
answers.angieslist.com > Home > HVAC
Oct 26, 2013 - i have a gas furnace with a lit pilot, but the burners won't light. ... if the thermocouple does not sense the heat of the pilot it prevents the gas controller fromturning on the burners. ... clamped onto the outgoing hot water pipe, if huydronic system) that is telling the furnace it is too hot, whether or not that is true.
Nov 18, 2015 | Water Water Heaters
I'm having problems keeping the grill lit on my BEKO dvg593-mk2 gas cooker. This has been a problem almost since new, i have to depress the gas knob, and keep it pressed for about 5-8 min's after ingn
Here is the owner's manual or try calling customer service at 0870-241-1321 for help. http://www.manualslib.com/manual/15108/Beko-Dvg593.html?page=3#manual
Feb 12, 2015 | Grilling
We have a Big Easy oil-less turkey frier & it won't stay lit. It's 37 degrees out. Would that be an issue? When valves are open, can't hear gas coming through. We've only used the propane tank one...
Yes, the outdoor temperature and any wind could play a role in it. Check to be sure that there's enough gas in the tank, to sustain the burner flames. These cookers use a lot of gas. Also, check the air intake shutter valve (where the tank hose connects to the burner). It may need adjusting to get the proper mixture of gas to air ratio. Consult your Owners Manual for the proper setting.
Hope that helps. Please let me know.
Rich
Feb 06, 2011 | Char-Broil The Big Easy 4638235S (LP)...
Burner lites but goes out after 2 or 3 min.
the white rodgers gas control needs to be replaced;
the way it works is: the thermocouple opens the pilot gas circuit and, holds it open
when it heats up by creating a magnetic field in the gas control then: when you turn
the knob on the gas control to "on" a valve inside the gas valve opens the main gas circuit and, electricity supplied by your RV keeps it open.
the main gas coil inside the gas valve is defective and, can not hold the main gas circuit to the burner open anymore.
Jul 24, 2010 | RTO Atwood DSI-RV Water Heater-6 Gallon
Burner not staying lit on rinnia rice cooker
If the rice pot is not in, burner will not light.
if that's not the case
Replace the thermal sensing unit
Nov 16, 2009 | Rinnai RER-55AS 55-Cup Rice Cooker
Imperial gas fryer problem, when the burners are
You have a bad gas valve. It's not reading the signal from the thermostat. The gas valve is stuck open.
Oct 19, 2009 | Imperial IFS40 Deep Fryer
Burner ignites but doesn't stay lit
The Thermocoupler is faulty or has a bad connection - once the burner is lit, it heats the thermocoupler which then send a small signal to the valve to stay on - at that time you release the knob and the valve stays on ( supplies gas). If you give me a model number, i can get you a part number and price.
Jan 23, 2008 | Miele 23 in. KM360G Gas Cooktop
Stoves 1000DFDL Dual Fuel (Electric and Gas) Kitchen Range Logo
102 people viewed this question
Top Stoves Kitchen Ranges Experts
Paul Carew
Ismael Rodriguez...
wayne murphy
Are you a Stoves Kitchen Range Expert? Answer questions, earn points and help others
