Question about Samsung RS2534 Side by Side Refrigerator
Samsung Side by Side RS2544SL Freezer will not fill tray with water
Freezer worked fine, stored for a year. Reconnected and water line works fine dispensing water, but ice maker will not work. I have tried the ice maker reset button many times and the tray will turn over and cycle as designed. I can hear the pump try to send water to the tray, but without luck. Is there any other way to reset or prime the line?
  • maw9367 Jun 29, 2008
    Pulled the electric solenoid valve off the dual inlet water valve. It was leaking. On the bottom of valve it reads "case e/s xylon sse" It has a 3 wire plug (red, white, black) and inlet and outlet sides. The top is silver with 4 screws. Where do I find a replacement part for this?
  • 828 Answers
Your problem may be in the water supply. Where the water connects to the back of the unit there is an electric valve, not a pump. The electric valve inlet orifice may be restricted, Shut off water supply and clean or replace the electric solenoid valve.
Posted on May 06, 2008
Rs261mdwp samsung
Pull the water supply line a loose from the water inlet valve. Look in the end of the valve there is a screen in there that can stop up. If it is clear then there is no way to extend the water time it is built in to the ice maker head. It will need to be replaced.
Aug 06, 2014 | Kitchen Appliances - Others
Icemaker won't fill tray,
Was the inlet tube frozen. If so your water inlet valve on the back where the water supply comes in is probably leaking and when the water reaches the freezer it freezes, blocking the inlet tube. Replace the water inlet valve.
You can Try swapping the wires on the dual water inlet valve. Then try the water dispenser. The water should go to the ice maker. This will tell you weather or not the ice maker valve is working and if the line is clear.
Aug 29, 2009 | Samsung RS2630WW Side by Side Refrigerator
Icemaker for sub zero 632 is not working, tray will not fill with water,there is no water in tray, It worked fine before hurrican, we emptied the frig and freezer and shut off the breaker for the hurr
check the water pressure ... if you have a filter in the line it may be restricting the pressure ... I had the same problem and a new filter fixed it
Nov 06, 2008 | Sub-Zero 632 / S
WATER ON THE FLOOR UNDER FREEZER DOOR
dear jim
there is drain line get chocked up with ice.Please open freezer evaporator cover u will find there is ice blocked in drain tray,melt it with hot water,check drain heater attached to the drain tray,if defective replace it,it will work fine
regards
sandy
May 16, 2008 | Samsung RS2534 Side by Side Refrigerator
LG LRSC 26923TT Side by Side Refrigerator Problem with ice maker
We have the same problem with the ice cube tray. Repairman said the tray must be replaced every year as continual bending warps it out of shape. Replace every year and your problem is solved.
Jan 28, 2008 | LG LRSC-26922 Side by Side Refrigerator
Water overran ice maker tray
It could be one of two things. The fill cycle could be too long causing the water to overflow or the icemaker may not be ejecting all the cubes out of the tray. A normal fill cycle is very short. Maybe 6 seconds long. So I would check and see how long the fill cycle is and when it stops check and see how much the tray is filled with water. I would also check and make sure that all the ice cubes are ejecting next time you hear it harvest.
Jul 12, 2007 | KitchenAid Superba Architect KSCS25INSS...
Water leaking inside freezer ice maker
sounds like the line was frozen but the water fill indicator is faulty.
Jun 05, 2007 | Hotpoint HSS25GFP Side by Side...
SAmsung Service Manual
I fixed my problem with the fan not working in the refrigerator section. It ended up being the fan motor. The way I nailed it down was to temporarily switch the wires to the fan motors in the connector on the circuit card. This electrically powered the freezer fan from the refrigerator side and visa versa. The fan still worked in the freezer side (running of the refrigerator circuit) and was still inop on the refrigerator side proving that there was nothing wrong with the circuit card or possible other factors driving that circuit (other than the fan motor). I ordered and installed a new fan motor (about $50) and now everything works fine. It seems that the original problem caused the circuit card to shut down voltage to the bad fan motor that's why when you checked the voltage from the circuit card, it was nill causing you to falsely believe that it was not the fan motor. Yes, I did a resistance check on the fan motor and it was very close to being the same as the freezer motor (same part number).
Jun 03, 2007 | Samsung RS2630SH Side by Side Refrigerator
Ice Maker Not Making Ice
There is no pump per say.. the water pressure is all that fills the ice maker and provides water to the drinking dispensor. The solenoids are also different, one activates for ice maker and the other for drinking water. The fastest way to check water flow is to swap the wires on the solenoids so the drinking water "power" will now power the ice fill solenoid. Once the plugs are swapped and you press the drinking water lever the ice maker should pour water out the fill tube. If that works then you know the solenoid, tube, etc. are all fine. I'd suspect then that the ice maker fill solenoid isn't getting power when it is suppose to fill. Let me know what this test result is.
Jan 23, 2007 | Samsung RS2534 Side by Side Refrigerator
RS2556SH Side by Side - Icemaker not filling; fill tube not iced over!?
press the reset button (black) on the bottom of the icemaker, the system will go through a cycle, and water will pour into the tray.
Oct 23, 2006 | Samsung RS2630SH Side by Side Refrigerator
Samsung RS2534 Side by Side Refrigerator Logo
420 people viewed this question
Top Samsung Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you a Samsung Refrigerator Expert? Answer questions, earn points and help others
